Holset users unite!
Old Jun 2, 2006 | 11:28 AM
  #1151
KeyserSoze's Avatar
Default Re: (J. Davis)
Don't be scaring me like that Blundy.........I sure hope that my hy35 doesn't fall on its face up top when I get tuned. Looking for 350-400whp and a stock bore gsr. Will probably have it tuned for 91 oct and 50/50 mix of 91 oct and LL avgas (~100 oct).
Off topic:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">For the GSR in your profile? I'd go for a .57, still efficient for a lower power level like that, but spools great and plenty of room to grow.</TD></TR></TABLE>
I am confused sometimes when it comes to the t3/t04e series of turbos. Many people suggest the 57 trim as opposed to the 50 or 60 trim wheels. Can you explain this to me (cause I'm retarded). I have looked at both comp maps and it seems that the 50 trim wheel outflows the 57 trim.........
50 trim......47lbs/min @2.6pr and 65% eff
http://64.225.76.178/catalog/compmaps/fig13.html
57 trim......42lbs/min @2.7-2.8pr and 65% eff
http://64.225.76.178/catalog/compmaps/fig15.html
So it seems (to my ignorant a$$ anyway) that the 50 trim outflows the 57 trim and would spool slightly faster as well. Am I totally looking @ this the wrong way? Maybe someone can edumacate me.
Old Jun 2, 2006 | 11:56 AM
  #1152
wantboost's Avatar
Who is Mr Robot?
Default Re: (QuarterMileMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuarterMileMaster &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, I've been looking and I'm trying to decide between these.
t3/t4 63 "V" Trim w/60 comp. and .48
t3/t4 57 Trim w/60 comp. and .63
I'm assuming since the first hasn't even been mentioned that the 57 trim would be best. Thanks guys and again, didn't mean to jack the Holset thread.</TD></TR></TABLE>
the first one is a t04b... dont even bother with it
Old Jun 2, 2006 | 12:39 PM
  #1153
SPOOLINmatt's Avatar
what is the website for holset turbos????
Old Jun 2, 2006 | 01:17 PM
  #1154
QuarterMileMaster's Avatar
Default Re: (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">
So it seems (to my ignorant a$$ anyway) that the 50 trim outflows the 57 trim and would spool slightly faster as well. Am I totally looking @ this the wrong way? Maybe someone can edumacate me. </TD></TR></TABLE>
I second that. I just looked at the comp maps and it looks like the 50 trim flows at 78% efficiency at the same power levels where as the 57 trim only flows at ~72%. And I'd think that the 50 trim would spool faster as well. I'd love to hear from an expert on this one to help out us tards. Here's a special ed version of a comp. map that I got my info from.
50 Trim:
57 Trim:
Old Jun 5, 2006 | 11:22 AM
  #1155
SL0WEGG's Avatar
i think i found what i've been looking for and its local!!!!
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Jun 8, 2006 | 01:39 AM
  #1156
Gold DA9's Avatar
Default Re: (boostedej1)
What do you guys think of a HY35 on a Stock D16Z6???I want to run 10-12 psi daily and 15+ psi on the weekends.
Also i saw that some come with a internal wastegate. Would I be able to use that or do I have to chop my ramhorn manifold for a external wastegate flange????
Eventually I will be building my Z6 up, prolly with 9.5:1 or 10:1 compression.
Let me know what you think. This is the current setup.
http://www.cardomain.com/ride/2327575
Old Jun 8, 2006 | 04:54 AM
  #1157
Paul_VR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">Don't be scaring me like that Blundy.........I sure hope that my hy35 doesn't fall on its face up top when I get tuned. Looking for 350-400whp and a stock bore gsr. Will probably have it tuned for 91 oct and 50/50 mix of 91 oct and LL avgas (~100 oct).
At the absolute worst case, it chokes and you have to drop $150 on a new 12cm^2 exhaust housing. Could be worse, you could have had to swap hotsides on a $800 turbo
Old Jun 8, 2006 | 09:58 PM
  #1158
KeyserSoze's Avatar
Default Re: (Paul_VR6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul_VR6 &raquo;</TD></TR><TR><TD CLASS="quote">At the absolute worst case, it chokes and you have to drop $150 on a new 12cm^2 exhaust housing. Could be worse, you could have had to swap hotsides on a $800 turbo </TD></TR></TABLE>
Yeah, thats true, but then I have to change my damn dp 2!!
A bit off topic........anyone have thoughts on the 50 trim vs. 57 trim question on the last pg 46?? Just curious.
Old Jun 8, 2006 | 11:21 PM
  #1159
blundar's Avatar
flow doesn't say it all. 50trims will spool a hell of a lot faster, 57 trims will flow a hell of a lot more exhaust leading to them making more power. That's my 10 second opinion
Old Jun 9, 2006 | 01:49 AM
  #1160
KeyserSoze's Avatar
Default Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">flow doesn't say it all. 50trims will spool a hell of a lot faster, 57 trims will flow a hell of a lot more exhaust leading to them making more power. That's my 10 second opinion </TD></TR></TABLE>
I thought that you could get the 50, 54, 57 and 60 trims all with the same hotsides (.48 or .63 a/r's). Maybe I am mistaken.
Old Jun 9, 2006 | 04:36 AM
  #1161
Paul_VR6's Avatar
Yeah, thats true, but then I have to change my damn dp 2!! .</TD></TR></TABLE>
Your 9cm have the 4" vband? I have a 12cm with the 3" band, but there might be a 12cm available with the bigger flange. Worth calling around.
Old Jun 9, 2006 | 07:51 AM
  #1162
blundar's Avatar
WHEEL matters as much / more than AR of housing.
A local guy stuffs HX50 internals into HX35 housings for diesel guys looking to compete in "stock" classes... and they have made 1200bhp on b1 (the familiar 5.9L) cummins motors with little more than a few hundred RPM spool difference.
Hmm.
Old Jun 9, 2006 | 08:43 AM
  #1163
Gold DA9's Avatar
Default Re: (Gold DA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gold DA9 &raquo;</TD></TR><TR><TD CLASS="quote">What do you guys think of a HY35 on a Stock D16Z6???I want to run 10-12 psi daily and 15+ psi on the weekends.
http://www.cardomain.com/ride/2327575</TD></TR></TABLE>
No one has any input????
Old Jun 9, 2006 | 11:04 AM
  #1164
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul_VR6 &raquo;</TD></TR><TR><TD CLASS="quote">Your 9cm have the 4" vband? I have a 12cm with the 3" band, but there might be a 12cm available with the bigger flange. Worth calling around. </TD></TR></TABLE>
Yea, it has the 4" v-band on it. 12cm w/4" flange huh? Might be somethin to check into.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">WHEEL matters as much / more than AR of housing.</TD></TR></TABLE>
I didn't realize that one could get different turbine wheels on the generic t3/to4e's. I know I'm a weetard.
Let me know what you think. This is the current setup.</TD></TR></TABLE>
You wouldn't be able to use the stock wastegate that comes with these turbos as they relieve @ like 20+ psi.
I would try to stick with lower cr's with this turbo as it is very happy at higher pr's.
Old Jun 9, 2006 | 12:49 PM
  #1165
SL0WEGG's Avatar
hx50's have 5" vbands
Old Jun 10, 2006 | 08:13 AM
  #1166
Gold DA9's Avatar
I would try to stick with lower cr's with this turbo as it is very happy at higher pr's. </TD></TR></TABLE>
Well the pistons im looking at now will make compression 8.5:1. Im looking for 300+whp on a D-series. So thats going to be 15+ psi so what turbo do you guys suggest? Was I right for saying the HY35 since it will prolly spool the fastest. Will it hold to a redline of 7500 or 8000??? Or should I be looking into the HX30 or HX35??? I really need to get rid of this IHI RHB5 Turbo. Want more power and tuning is free for me.
Damn should I cut and weld a wastegate in my ramhorn manifold or sell it for a log??? Hmm.... What to do.
Old Jun 10, 2006 | 09:25 AM
  #1167
lsintegra9's Avatar
just finished my setup a couple of days ago and started it last night. thought i would post some pics. big thanks to my friend jeremy for all his help!
B18a with Hy35w turbo
Old Jun 10, 2006 | 09:58 AM
  #1168
powerofdreams8's Avatar
Default Re: (lsintegra9)
NEW HOLSET ET...........12.1@121 on my daily driver 225 BFG DR's (shitty 2.1 60ft)
VX hatch 2066lbs
B16 stock bore wiseco/eagle 18 psi
hx35 w/ 16cm housing
Old Jun 10, 2006 | 11:14 AM
  #1169
Gold DA9's Avatar
Default Re: (powerofdreams8)
I need a holset!!! HY35 prefered for my D16. Will be pushing 15-20 psi.
Old Jun 10, 2006 | 11:16 AM
  #1170
SL0WEGG's Avatar
^^ebay is your friend.
Old Jun 10, 2006 | 12:19 PM
  #1171
Si Shane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerofdreams8 &raquo;</TD></TR><TR><TD CLASS="quote">NEW HOLSET ET...........12.1@121 on my daily driver 225 BFG DR's (shitty 2.1 60ft)
VX hatch 2066lbs
hx35 w/ 16cm housing</TD></TR></TABLE>
Do you fall out of boost when you shift? You shifting at 8k? And b16 tranny I assume?
Modified by Si Shane at 2:17 PM 6/10/2006
Old Jun 10, 2006 | 01:30 PM
  #1172
Default Re: (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">Do you fall out of boost when you shift? You shifting at 8k? And b16 tranny I assume?
Modified by Si Shane at 2:17 PM 6/10/2006</TD></TR></TABLE>
shifting at 8200, need valvetrain- I don't "fall out" of boost, but it does take a moment after each shift to come back to full power. I am sure it could be improved by switching to one of the 12 or 14cm turbine sides, but I will be revving it out to 10k soon so I don't want any top end choke.
yes, b16 tranny
Old Jun 11, 2006 | 09:35 PM
  #1173
Gold DA9's Avatar
Default Re: (TallKyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robus &raquo;</TD></TR><TR><TD CLASS="quote">While I'm at it I might as well post the H2C compressor map (from Holset). It's quite an old model! Got a brand new one for 150 bucks.
So you got a brand new Holset H2C turbo for $150???? Damn i need to find a deal like this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallKyle &raquo;</TD></TR><TR><TD CLASS="quote">I am going to use the Holset HC1 on a stock Y8 on like 8-10 psi. i hope it works. hahaha</TD></TR></TABLE>
Let me know how this works out. I want to put a holset on my Z6
Old Jun 12, 2006 | 06:20 PM
  #1174
TomRitt's Avatar
Does anybody want to trade any larger housings for my 9cm^2 housing? The wg flapper on mine is welded shut, because I use and external one, but I;d like to try out a larger housing!
Old Jun 16, 2006 | 08:11 PM
  #1175
boosted-EG6's Avatar
Default Re: (TomRitt)
hey can anyone point me in the directions on where i can find the 5 bolt flange with or with out the V-band for the hot side of the holset turbo
my turbo if it matters is the HX35W....
thank you i would love the info
