AZ_CIVIC'S Build, Testing Things, ETC.
Old Jul 19, 2019 | 10:40 AM
  #326
AZ_CIVIC's Avatar
Default Re: AZ_CIVIC'S Build, Testing Things, ETC.
Originally Posted by sikefcrx89
Hard to tell from the photos,but is your Rear setup as Staging Brake Only,or is it T'd/Y'd for all 4 corners to still be foot brake?
Staging brake only, also manual front breaks.
Old Jul 19, 2019 | 10:56 AM
  #327
Txdragon's Avatar
What's your suspension setup?
Old Jul 19, 2019 | 11:32 AM
  #328
AZ_CIVIC's Avatar
If you are just referring to what coilover setup I am using it would be Strange Engineering with 750lb Hyperco Coils in the front and 300lb rears.
  #329
sikefcrx89's Avatar
Loved
Because of the booster delete? I want a staging setup but I need to incorporate all 4 simply for limited street use. Are you still running a prop valve or a bias controller now?
Old Jul 19, 2019 | 11:52 AM
  #330
AZ_CIVIC's Avatar
Essentially a bias controller, I learned my lesson from having all 4 hooked up to the brake pedal and using a booster, especially in a drag car.
Old Jul 19, 2019 | 12:01 PM
  #331
Txdragon's Avatar
The full shebang; control arms, camber kits, etc. If it has to do with suspension, fill me in! Also, your coilovers.. They adjustable dampening? 24 way, 32 way, etc?
Your car is more suited to track so I'm trying to get an idea of the suspension and maybe meet somewhere in the middle for track/street.
Old Jul 19, 2019 | 01:02 PM
  #332
AZ_CIVIC's Avatar
Okay yeah: I think all the below basically fall into the suspension portion.
Strange Engineering Double Adjustable shocks with 10 extension and compression settings.
Kaizenspeed Rear Trailing Arm kit
Front Skunk2 Pro Series Camber Kit
Kingpin Spherical Front LCA's, Kingpin Spherical Compliance Bushings
MAKK transmission brace
NRG Tubular K Member
Hasport solid motor mounts
Old Jul 23, 2019 | 07:21 AM
  #333
AZ_CIVIC's Avatar
So I sold my flatbed trailer and went and took a look at this trailer. I've been wanting a enclosed for some time now and have really thought hard about a size. This is a 24 foot and I think it will give me the room I need, I think this will have to come home real soon.
Old Jul 23, 2019 | 09:34 AM
  #334
ohisofly's Avatar
Your breather setup using the stock filler neck as the vent is slick
I like that trailer. In for updates
Old Jul 23, 2019 | 04:25 PM
  #335
BoostHatchFreak's Avatar
24 works out really nice. we have one for a dirt track car's there a bit longer then are Honda's. there a lot cheaper back east. my family owns a transport company and a lot of people pay us to bring trailer to the west coast from back east. some company's even deliver.
Old Jul 23, 2019 | 06:40 PM
  #336
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
I think a 24 foot would be just fine, I’m squeaking by with a 16 foot but I’m a HB and don’t travel with much extra stuff . 24 foot should allow for plent of tools and spare replacement parts
Old Jul 23, 2019 | 07:03 PM
  #337
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Make sure it has an awning or two.
Also, a winch to pull the car in.
Lastly, a counter, and power, to make margaritas at the end of the day!
Old Jul 24, 2019 | 04:37 AM
  #338
AllMtrRex's Avatar
And recessed floor anchors for strapping the car while towing, wheel chocks, etc
Old Jul 24, 2019 | 04:55 AM
  #339
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Hey AZ, How’s the car coming along anyway?
Old Jul 24, 2019 | 05:59 AM
  #340
AZ_CIVIC's Avatar
Thanks man! My buddy did the setup on his Integra who was having the same overflow issues and it worked for him so I figured I would copy what works.
Old Jul 24, 2019 | 06:02 AM
  #341
AZ_CIVIC's Avatar
Yeah I've been looking online for trailers and Georgia seems to be pretty damn cheap but the delivery charges they want $2500 which makes buying one here the same price. LOOK has a manufacturing plant about 10 miles from me, however they don't sell to the public and the cheapest dealer to me is literally 5 miles from my house. This trailer out the door brand new was $7,600. I've seen good deals on Offer Up but I want something brand new.
Old Jul 24, 2019 | 06:04 AM
  #342
AZ_CIVIC's Avatar
The awning would be nice but my buddy has one on his 48 foot trailer. Winch would be nice and yes to the margaritas at the end of the day LOL.
Old Jul 24, 2019 | 06:18 AM
  #343
AZ_CIVIC's Avatar
I really haven't done much to it, made the new overflow tank and bought a couple small parts and that's about it right now. I was looking into a fire suppression setup for my car since my buddy has one for sale.
As for the engine my buddy has been looking into the headgasket issue, seems that the JE Pro Seal gaskets are just machined like ****. For example I have a Darton Sleeved 84mm block yet an 84mm JE Pro Seal hangs over the piston walls which is no good. Second issue is the machining of the dowel locations on the headgasket. When you try to place the headgasket over the dowel pins it is a very tight fit to the point that it almost bacons the headgasket. So we tried a Cometic head gasket and didn't like it so what we are doing is using the JE 85mm headgasket and notching the dowel pins to relieve the pressure.
We also have to notch the turbo manifold to clearance it, in some cases and it doesn't happen often with some blocks the head actually ever so slightly recesses on the block meaning the block stick out a little further then the head. So when I go to tighten the manifold it actually was putting pressure on the block and head basically trying to squeeze itself over the block causing stress that could also lift up on the head.
So we will see what happens once everything is back together and ready for the dyno.
Old Jul 24, 2019 | 07:05 AM
  #344
Autoworks's Avatar
I like that expanded catch can! I see you got that "Joe" filter port on there
Old Jul 24, 2019 | 07:28 AM
  #345
AZ_CIVIC's Avatar
Yeah the salt shaker, I've run those on his CNC so I was like I need some of those for my catch can projects.
Old Jul 24, 2019 | 10:06 AM
  #346
Txdragon's Avatar
Given you'll have p2w clearance machined in, shouldn't you order at least .5mm larger HG size anyway? I didn't have an issue there with my JE at 76mm, but the dowel pins.. Yup.. It didn't fit tight enough to distort, but I DID have to provide some encouragement with a 12mm deep socket over the pins to seat the gasket. **In Happy Gilmore voice** Just taaaap it in... Jussst taaaaap it in!! (Knock on wood) No issues so far after 1076 miles post startup and some RIGOROUS driving after 500 mile clutch break in.
Old Jul 24, 2019 | 11:45 AM
  #347
AZ_CIVIC's Avatar
So when I had a GE Sleeved 84mm block they recommended an 84mm gasket and it worked great. With Darton Sleeves they recommend JE but JE 84mm is too small so JE recommends using an 85mm gasket on an 84mm bore. In my mind that seems a bit weird but that is what they recommend and yes there gasket is machined like crap and doesn't fit the dowel pins that well. So with modified dowels I am hoping to not have any issues and from my understanding this is common practice on domestic stuff from my understanding.
Old Jul 24, 2019 | 04:42 PM
  #348
ohisofly's Avatar
Yea that's always a plus, I can hardly mig but appreciate the work that went into it.
Is this only for the block breathers?
Old Jul 25, 2019 | 05:57 PM
  #349
lvdb-2's Avatar
car is dope man!! I should be down in the AZ in the next few weeks to have Grampa Joe tune may car as well. But my car is no where as clean as yours
Old Jul 26, 2019 | 06:07 AM
  #350
AZ_CIVIC's Avatar
Nice!! Yeah Uncle Joe said he had a few tuning appointments to get done I guess racing season is getting close for us west coast guys.
