Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   AZ_CIVIC'S Build, Testing Things, ETC. (https://honda-tech.com/forums/forced-induction-16/az_civics-build-testing-things-etc-3325048/)
AZ_CIVIC 08-03-2018 07:44 AM
Well I basically got my rolling chassis all back together. Had some fun figuring out things I never have done before like removing my front and rear windows, my roof and re-installing as well. I've posted roof removal and re-installation in paint and body so if anyone is thing of doing something similar I've got some nice instructions on a how to and try to create helpful things as I go along.
I'm creating a thread here because I am going to try some things out with my forced induction setup and thought this could be a helpful place to add some insight and answer some questions.
I am going to be trying some intake manifold tests, maybe some different turbo tests, intercooler setup and tests and because I am using Motec have the ability to run a bunch of sensors to see what difference certain things can result in for better or worse. One of the biggest issues I am having right now is my breather box which is new and have had issues with this thing just spitting oil right out the filters.
Quick run down on my new current setup which is almost done
Block:
Darton Sleeved 84mm, Aluminum Rod 10:1 compression GSR Block.
Head:
4 Piston Outlaw Head, Full Ferrea Valve Train, Web Cam Pro's Cams, GSR Head
Trans:
PPG Gear Set, Liberty Bell Housing, Comp Twin, DSS 5.9's, Gforce shifter with strain gauge.
Suspension:
Strange Engineering Coilovers, Kaizenspeed Rear Trailing Arm Kit, MAAK Brace, Full Kingpin Spherical Bearing setup.
Fuel:
Huge Weldon 2345-A pump, 8 ID200's Injectors, 1.9 gallon fuel cell
Forced Induction:
Custom 7290 Comp Turbo, Full Race Forward Face Manifold, Tial 60mm Gate/Blowoff Vavle, Custom piping, Custom Intercooler.
Autoworks 08-03-2018 08:24 AM
Re: AZ_CIVIC'S Build, Testing Things, ETC.
Nice!
If you are going to use a Skunk2 Ultra IM, I'd be curious to know if it fit the head flush right out of the box
AZ_CIVIC 08-03-2018 09:00 AM
Originally Posted by Autoworks (Post 51698665)
Nice!
Iíll be using this modified BMC.
https://cimg6.ibsrv.net/gimg/honda-t...0a12457e2.jpeg
ls joker 08-04-2018 10:09 AM
Awesome. Any ideal on mainfolds and turbo that you wanted to test out.
Side note, i recently looked into the web street/strip cams.
Balor_Gr 08-04-2018 12:18 PM
Wow its gonna be killer.
Interesting that you chosen Comp turbo for such a serious build. Do you have some data on their turbos ?
Im not saying they are bad but i cant seem to find data for their turbine wheels spool etc. They only list 92mm exducer turbine wheel turbos
on their website hmmmmmmm :)
AZ_CIVIC 08-04-2018 12:57 PM
Well I had the Edelbrock Victor X manifold on my car and then borrowed this BMC manifold from my buddy. I had just swapped the manifold, the forward faced manifold, intercooler and turbo onto my car and made one pass before my block finally gave out.
So I was originally thinking of buying the Skunk2 Ultra with the 4piston machining on the runners but decided not to do it because the BMC has 8 injector mounting on the top where the Skunk2 has 4 up top and 4 down below so I didn't want to have to remake my fuel line to accommodate. Then I though of going all out and purchasing a Kinsler but again they run the injector top and bottom. So what I ended up doing was using the BMC but the runners were able to be removed and were held on with bolts and orings. I've heard of these things leaking so I decided to have the runners totally welded on so I wouldn't have to worry about leaks.
So the BMC has a pretty big Plenum and am going to see how this one works with my new setup and hopefully it is better than when I ran the Victor X.
AZ_CIVIC 08-04-2018 01:04 PM
So I ran the Comp 62mm turbo in the past and it did pretty decent. The Comp Turbo I am going to run came of Joe's grey car from Locash Racing, the one that ran an 8.31 with this turbo. Before this I ran the Precision 6870 which got me an 8.8 so I am going to see what the Comp will do. I know one of the guys who works for Comp and he hooked me up with rebuilding the Comp Turbo for free I mean basically a new turbo since it had been on Joes car for a few years so we will see how it goes.
If the turbo ends up sucking I am thinking of trying the Precision gen2 7285 and as far as spool goes I am not worried about that LOL. I never go below 9,000 RPMS so no biggie. I've also thought about the Precision 6785 as well but we will see.
Balor_Gr 08-04-2018 03:07 PM
Yeah i was thinking about 6785 would be very good for your build but it DAM expensive. What happened to the 6870?
About spool yeah im an idiot you never really let of the gas anyway...
Edit: Wait isnt it a ruleset on turbine wheel of like 85mm?
What category do you race?
AZ_CIVIC 08-08-2018 07:38 AM
So this will be the turbo I will be using on my car this go round to see what it will do. I figured just taking a picture of the turbo in the box you sometimes loose reference on how big a turbo or something can be by just looking at a picture. This is the turbo next to a gallon milk jug just to give a reference on how big this thing is LOL.
https://cimg1.ibsrv.net/gimg/honda-t...f68112b43.jpeg
https://cimg2.ibsrv.net/gimg/honda-t...165d3ee4d.jpeg
https://cimg3.ibsrv.net/gimg/honda-t...89c5b4928.jpeg
Txdragon 08-08-2018 08:37 AM
A turbo that size just seems more comical than practical. Lol
AZ_CIVIC 08-08-2018 08:44 AM
Oh for sure, a turbo this size on a DD car wouldn't make much sense but a race car absolutely LOL.
2x0 08-08-2018 09:06 AM
That's one large snail.
In for more awesomeness.
:beer:
Balor_Gr 08-08-2018 09:47 AM
Wow. This will pull the car to the side. Haha.
Do you have any dyno plot of the 6870?
It was itching me to get a Comp turbo some years ago.
Do they have their own design turbine wheels or garrett/garetish design?
AZ_CIVIC 08-08-2018 10:03 AM
We did a dyno run with the 6870 and put down like 1070whp or something like that but last time I asked Joe of Locash CNC (my tuner) he didn't save my run LOL.
This Comp turbo has put down over 1300whp.
Comp Turbo does design their own turbine wheels and doesn't use anything Garrett.
Txdragon 08-08-2018 10:39 AM
Especially if you're gonna race to the moon!!! Lol :drag:
Balor_Gr 08-09-2018 09:06 AM
Yeah i found it: Dynos ? VitTuned Blog
I saw this collections of dynos some years (?) ago
Comp turbo yield good results.
Pepe14 08-09-2018 11:09 AM
They dont just mix and match wheels like other companies????
AZ_CIVIC 08-09-2018 12:55 PM
Not that I am aware but who knows with companies now days LOL.
AZ_CIVIC 08-15-2018 05:09 PM
turboLScrx 08-15-2018 06:07 PM
Incredible build man, extremely impressive, I can tell you have put your heart and soul into this car
extremeracer 08-16-2018 12:11 AM
Beautiful car - but then I'm a black car fan. I've always thought Black suited the EG and EK's
AZ_CIVIC 08-16-2018 12:41 PM
So one of the things I have seen some people asking is the type of pan to use. A lot of people have had issues with Moroso pans leaking and so have I, one thing with my last Moroso pan we tried gaskets, we tried Honda Bond and we even shaved all the little dimples down and used a gasket sealer and that was the best but still not perfect.
This time I am trying the all aluminum Moroso pan and we will see how this one holds up. So far putting it on a flat surface it is almost perfect with very slight movement but nothing major. Once it is bolted down and sealed hopefully I don't have issues but we will see.
https://cimg3.ibsrv.net/gimg/honda-t...e49617f74.jpeg
https://cimg2.ibsrv.net/gimg/honda-t...b9ce56e16.jpeg
Balor_Gr 08-16-2018 02:09 PM
The paint job is incredible. What a car.
AZ_CIVIC 08-16-2018 02:33 PM
Thanks man I took my time when I painted it plus that 3000 grit wet sand and buff came out very clean.
LightningTeg 08-17-2018 03:00 AM
Yup car looks great.
