Question about T3 60-1 on stock GSR?
Old Aug 18, 2004 | 09:49 AM
speedy108's Avatar
Default Question about T3 60-1 on stock GSR?
I found a really good price on this turbo from a friend. This would be going on a stock '99 GSR with basically a DRAG kit and Greddy Type 24, still using the DRAG manifold also. Here are the questions I'm more concerned about:
1. With using this turbo on the DRAG manifold andTial 35mm wastegate, will I have a problem with boost creep? (main concern)
2. At about what RPM will this turbo hit full bost on my car? (9-10 psi)
And if I said that I can pick this up for $375 practically new, what would you say?
Thanks for all your help.
Old Aug 18, 2004 | 12:27 PM
speedy108's Avatar
Default Re: Question about T3 60-1 on stock GSR? (speedy108)
bump
Old Aug 18, 2004 | 02:30 PM
Sonny's Avatar
What is the a/r of the turbine housing. That will have the most noticeable effect on spool time. Terry (boostfed) had a built B16 that was about 1750cc with a T3/60-1 and a .82 a/r turbine housing. It made 500 whp but power didn't come on until well past 5k.
Sonny
Old Aug 18, 2004 | 03:07 PM
EM1 MIKE's Avatar
I'm using a t3/60-1 with a .82 turbine housing. I'd probably say I don't see any real power until VTEC engages
$375 brand new is pretty good but what is your horsepower goal?
Old Aug 18, 2004 | 03:19 PM
twkdCD595's Avatar
Default Re: (EM1 MIKE)
I think its a good deal for 375...
what a/r is it, and is it new or used?
Old Aug 18, 2004 | 03:23 PM
EM1 MIKE's Avatar
Default Re: (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">I think its a good deal for 375...
what a/r is it, and is it new or used?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">And if I said that I can pick this up for $375 practically new, what would you say?
I assuming "practically new" means it's used.
Old Aug 19, 2004 | 03:06 AM
speedy108's Avatar
Yes practically new means it's used, but still in great condition.
I'll try to find out what the A/R is on it for you guys today.
Old Aug 19, 2004 | 04:46 AM
Adi Radoncic's Avatar
On Fire!
Default Re: (speedy108)
I used to run a t3 60-1 .63 a/r housing on a stock gsr motor with a headgasket, I had full boost at 5500, using a max rev manifold, 3" turbo back exhaust.
With the 35mm tial gate I only experianced 1psi of creep at 15psi.
I personally wouldn't trust that drag manifold as far as I could throw it with that turbo, but thats just my oppinion.
Old Aug 19, 2004 | 05:11 AM
speedy108's Avatar
Default Re: (newgsr)
Thanks for the response guys. I appreciate everyones opinion and it makes it easier for me to make a choice. I think I will just bite the bullet and go with the SC34.
Old Aug 19, 2004 | 11:14 AM
b16hybridsol's Avatar
i run a 60-1 on my h22, full boost at about 4200ish using a rev hard mani and a deltagate and havr never seen even 1 psi over 7
Old Aug 19, 2004 | 11:31 AM
Drag_On's Avatar
Default Re: (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">i run a 60-1 on my h22, full boost at about 4200ish using a rev hard mani and a deltagate and havr never seen even 1 psi over 7</TD></TR></TABLE>
Why such a big snail for only 7 psi? Good price?
Speedy - I would look into the AR of that 60-1 before you shell out the big ching on a SC34. Cause if you can find a bit lowe AR on it - you could see boost early and possibly even :similar: to the 34.
Old Aug 19, 2004 | 11:39 AM
Default Re: (Drag_On)
yea, i gotta ful kit for 1900 including the 60-1, but the boost is going up, i'm waiting for my aem, so it was just 7psi on the hack
airmaxbri
Nov 13, 2007 05:34 AM
turbo boost
Oct 3, 2006 04:44 PM
shady 5th
Mar 14, 2004 04:43 PM
tygsr
Jan 21, 2003 12:12 PM
boosted3g
Oct 24, 2001 12:10 PM
