Which turbo upgrade??
Old Jan 19, 2003 | 07:40 PM
tygsr's Avatar
Default Which turbo upgrade??
Currently I run the standard drag gen 3 turbo. I want to support 400whp efficently. First question, can it be done with that turbo. Second, if I upgrade, which would be best. I am leaning towards a t3/60-1 w/.48a/r for faster spool, or the same turbo with .63a/r. Or, a small upgrade from mine, a t3/t04e 60 trim .63a/r?? Now if I go with the T3 I need a new manifold also. If I stay with the to4e range I can use the drag manifold and save some $$.
Old Jan 19, 2003 | 08:32 PM
jdmtegxsi's Avatar
Default Re: Which turbo upgrade?? (tygsr)
I have a turbonetics t3/to4e and it spools up pretty quick. That is the quickest turbo I have had experience with.
Old Jan 19, 2003 | 08:36 PM
LS-hatch's Avatar
why would you need a new manifold? a T3 and a T3/T04e both the T3 flange right?
Old Jan 19, 2003 | 08:51 PM
Flamenco-T's Avatar
Default Re: Which turbo upgrade?? (LS-hatch)
yes....
Old Jan 20, 2003 | 02:53 PM
tygsr's Avatar
Default Re: Which turbo upgrade?? (Flamenco-T)
can the drag turbo be efficent up to 400whp? I live in utah at high elevation I know that plays a part in a turbos effieceny..
Old Jan 20, 2003 | 03:53 PM
boosted hybrid's Avatar
If you want to upgrade to a better turbo, run the 60 trim if you are worried about spool up time. If you arent, and you like traction run the 60-1 t3 .63a/r. You will still get full boost around 5500rpm, and it will pull till 8,500rpm. Lag=traction. Beware that you must run minimum of 12lbs of boost to make the 60-1 efficient. It does flow 60lbs/min compared to the 60 trim which flows 53 lb/min, but in this case its not efficient at all below 12lbs and you are better off going with the 60 trim.
Old Jan 20, 2003 | 04:05 PM
turborex's Avatar
Default Re: Which turbo upgrade?? (boosted hybrid)
Will the 60-1 .63 be able to handle 20-25 psi or is this to much for that turbo? Will it pull to 9000 rpm?
Old Jan 21, 2003 | 12:12 PM
tygsr's Avatar
I have thought of the whole lag thing helping out with traction. The 60 trim/.82 ar has more lag than the 60-1 from what I have heard..I wonder if it would be best to stick with my turbo and get a more efficent intercooler??
hatchattak
Feb 7, 2004 03:26 PM
WAFFLES
Jan 2, 2003 11:42 AM
turborex
Dec 20, 2002 02:43 PM
boosted3g
Oct 24, 2001 12:10 PM
