B series taxtime swap ?'s
Well soo many people are telling me to sell my D and swap to B series. I came to the conclusion that I am. Its getting swapped to Ls/vtec. I wanna see my results with just building first and then possibly turbo. I wanna know how would I go about swapping Mounts,axles,engine harness,dash harness,ecu,shift linkage and all depending on what year engine what would be the best OBD1 or OBD2. This would be my first true build beside bolt ons.
Where to buy? Best bang for my buck
Best compression build for turbo?
b18b1 block/ Gsr head. I was going to buy a non running b18b1 and start with that.
I have a total of 4000$ by Feb 10
Let me know your guys opinions. I need alot of help. Thx
Dammit kid. There's the FAQs!
Section 6C.
Section 6C.
- c. Swaps
- Removing/Installing Your Engine Without a Hoist
- Basic General Swap Information For Civics
- Detailed General "How-To-Swap" information
- The Ultimate Honda Swap Guide
- Engine swap into Civic information
- OBD2 LS Into 92-95 Civics (OBD1 chassis)
- K20 Into 92-00 Civics/94-01 Integras
- GSR Into 92-00 Civics
- Detailed H22 Into 92-00 Civics Information
- H22A Into Civic - Axle Information
- B20 Into 96-00 Civics
- B20 Into 96-00 Civic Part List
- OBD1 Engine into OBD2B or OBD2B Civic or Integra
- K20 Into 92-95 Civics, 93-97 Del Sols, and 94-01 Integras
- Common Info For JDM D15B
- Making JDM ITR Motor BAR Legal
- Retaining Power Steering in 96-00 Civics With B-Series Swap
- B- vs H- vs D-Series Weight Arguments Settled By Scale
- Where Different People Get Engine Swaps - Unofficial Discussion
- H22 Pros/Cons (OPINIONS) - Unofficial Discussion
- Opinions of ITR vs H22 - Unofficial Discussion
- B16 vs B18 Debates #1
- B16 vs B18 Arguments #2
- B16 vs B18 Arguments #3
- B16 vs GSR vs LS/VTEC Debates
- Lots of Wiring Information on OBD2 B-Series Engines Into 96-00 Civics
- Wiring Information For OBD1 GSR motors in 92-95 Civics
- Misc info for B-swaps in '96 - '00 Civics
i will spoon feed you the idea. you're on your own after that.
hmotorsonline for the engine.
use a b16/18 head not a GSR
you could try 15:1. j/k. 10:1 and down. 10 being much harder to do because it has to be precise in all areas. but you'll get more power at less PSI and still have power before the turbo spools.
it'll be an awesome setup. provided this isn't the same old pipe dream im assuming it is.
H2B next time.
H2B next time.
Go to hmotorsonline buy a full swap. Get your *** researching on wiring and tuning!!! Ask around in your town. Don't buy crap till ALL your plans are set in stone and everything is picked out.
Ls/vtec's are notorious for snapping rods and messed up internals due to a bad r/s combined with high revs. Go with a straight gsr or a b16a2. It will last you longer and run smoother.
This is so wrong I don't even know where to begin. Oh wait: https://honda-tech.com/forums/showthread.php?t=1676914
God I hate when idiots come on here talking about something you have no idea or experience about. Just shut up
the owners of said broken LS/Vtecs are infamous for cheaping out on parts not using ARP bolts and if its not ebay its not worth it.
- the real cause of busted B20/vtecs.
4k on a motor? unless youre gonna get a b18c5(overpriced) or k20 thats waaaaay more then you need.
idk why he wouldn't go with an H22A with a B series tranny for 4k
I'm doing everything the expensive way, and my H2B swap using an ITR transmission, Exedy Stage 1 Clutch, Fidanza Flywheel, LogicMotorsports header, custom exhaust, Axles, 70mm TB, and the cost of Labor at Mainstream Performance is all around ~$5,000.
Again, that's for good parts, no half-assed anything, PLUS labor to pay a shop to put it in.
~210-230whp depending on the health of the engine and tune on a totally stock block/head.
Hey HT!! Im a total noob..I've spent too much money in the wrong places in the past, not looking to make the same mistake 2x..I def want to be boosted by summer 2012...I got a couple of $$ and an integra ls..I don't have $$ to sleeve, should I buy a separate motor to install Rods and pistons?? (167k)..lookin 4 350whp
HEy honda-tech whats the best way to facepalm myself for seeing threads like this everyday!!??
Here read through this before you post anything else up. Which you should've done first
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Edit you could've just seen what grumblemarc posted in the 1st post
Section 6C.
Section 6C.
- c. Swaps
