Spark Plugs
I tried searching and found nothing. Should I stick with the stock platinum plugs or go with something else? What are you guys using for your stock R's? Mines a 98. Thanks
Come on, do another search under the Type-R Forum > Spark Plugs, and you'll find just about 100 threads... or check out the stickied FAQ at the top of this page.
Engine - Ignition - Spark plug - General
http://www.dansmc.com/sparkplugs1.htm - General Information
http://www.dansmc.com/Spark_Pl....html - 29 Images Of Spark Plugs - Different Running Conditions
https://honda-tech.com/zerothread?id=278886
https://honda-tech.com/zerothread?id=261560
https://honda-tech.com/zerothread?id=186385
https://honda-tech.com/zerothread?id=235885
https://honda-tech.com/zerothread?id=188875
https://honda-tech.com/zerothread?id=130790
Engine - Ignition - Spark plug - Technical
https://honda-tech.com/zerothread?id=742226
https://honda-tech.com/zerothread?id=727538
https://honda-tech.com/zerothread?id=381313
https://honda-tech.com/zerothread?id=241213
Engine - Ignition - Spark plug - Bench Racing
https://honda-tech.com/zerothread?id=702167
https://honda-tech.com/zerothread?id=640447
https://honda-tech.com/zerothread?id=136130
Engine - Ignition - Spark plugs - How Often To Replace?
https://honda-tech.com/zerothread?id=328695
https://honda-tech.com/zerothread?id=209155
Engine - Ignition - Spark plugs - For Cars With More HP
https://honda-tech.com/zerothread?id=287670
https://honda-tech.com/zerothread?id=264475
https://honda-tech.com/zerothread?id=278184
Engine - Ignition - General
https://honda-tech.com/zerothread?id=128626
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard »</TD></TR><TR><TD CLASS="quote">Engine - Ignition - Spark plug - General
https://honda-tech.com/zerothread?id=128626</TD></TR></TABLE>
inane
Jan 30, 2005 11:38 PM
Rhetoric
Sep 26, 2003 10:38 PM
