K24A2 oil pump timing procedure???
Looking to time the oil pump on a K24/K20 build with me using the tsx style balance shaft oil pump. Anybody know how to line up the one black link in the chain and the double black link???
Any help is greatly appreciated
Re: K24A2 oil pump timing procedure???
The oil pump gear has a line that you match on the housing. The chain itself has no markings for timing. IIRC
The main chain for the cam gears has a black link on each side of the dot on the cam gears when at TDC. The crank pulley gear for the chain has a dot that lines up with the single black tooth on the gear.
