K DYNO INFO
K24 Bored out to 87.5
Carrilo Rods
CP Pistons 87.5 12:1 compression
type s pump
ACL Bearings
Type S Head port and polished
Drag Cartel Stage 4 Cams
550 rc injectors
Super tech valvesprings and retainers
RBC manifold bored out
skunk 2 74mm tb
hytech headers
ARP headstuds
OEM Timing chain Tensioner
3 in k teller piping
kpro
OK so i dyno it and made 270whp and 200lb torque
Tuner tells me to bring it back after 1000 miles to put more power out . Is this true and why do i have to wait 1000 miles?
Carrilo Rods
type s pump
ACL Bearings
550 rc injectors
skunk 2 74mm tb
hytech headers
ARP headstuds
kpro
What type of dyno?
The engine should be fully broken in on the dyno. You should not have to wait 1000miles and go back and re-dyno.
For your set-up those #s seem a little low.
For comparison w/ the KMOD RSX we made 268whp-190wtq
Set-Up
K24a1(Head & Block)
FIC 525cc Fuel Injectors
KMOD 4-1 Race Header
KMOD 3.0in Exhaust
KMOD Stg1 Head Porting
Set-Up
K24a1(Head & Block)
Gato Performance Intake Manifold
Infiniti Q45 84mm Throttle BodyFIC 525cc Fuel Injectors
KMOD 3.0in Exhaust
Crower "KMOD" Camshafts
Honda Locked Rocker Arms
Skunk2 Exhaust Cam Gear
Supertech Beehive Valvesprings
Supertech Titanium Retainers
Supertech 13.5:1 Pistons
Eagle Connecting Rods
KMOD K20a2 Oil Pump
We are teing some Kelford 179-b cams next week on this same set-up
KMOD K20a2 Oil Pump
i think they just wanna make more money off you.... im sure that setup will make over 290whp btw it'll be a good investment to get an aftermarket chain tensioner fro those bad boys
tuner is kindda correct...assuming those CP pistons are street pistons therefore the rings are not racing rings, then you have to do a good 800-1000mile breakin after about 2-3 oil changes...typically it depends on the rings that you use, that determines the break in.
also during the 1000mile, the best breakin procedures typically for the street rings:
-dont keep at stead rpm on the hwy, vary it back and forth
-approaching stop light or stopping in general, keep downshifting to each gear and let of gas
-dont keep idling the motor
jeimport
Jul 8, 2004 05:42 AM
