Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake Pads
Old 02-15-2007, 08:20 AM
Indiana Jones's Avatar
Default Brake Pads
Time for new brakes. What does everyone prefer I am thinking of going either Hawk or Axis. This will be on my daily driver 99 Integra LS with about 300whp. It will not be seeing the track all that often and I want a pad that won't dust horribly. I see people going with either the Axis Ultimate or the Hawk HP or HPS . . . people seem to run the .480 thickness. Any insight would be helpful. Thanks
Old 02-15-2007, 08:36 AM
BrianZ's Avatar
Default Re: Brake Pads (Indiana Jones)
I like the Colbalt friction Spec B's but that is a track only pad... for street i stick to OEM pads..
Old 02-15-2007, 08:55 AM
Andrie Hartanto's Avatar
carbotech AX6. You will love it. Check out http://www.ctbrakes.com
Old 02-15-2007, 09:19 AM
Default Re: (Andrie Hartanto)
thanks
Old 02-15-2007, 09:43 AM
Just_LS's Avatar
I use Hawk HPS as DD/Track. DD no complain, better than Axxis MM but it faded in my lapping day. Both Hawk and Axxis do dust more thatn stock though.
Old 02-15-2007, 10:13 AM
6spdKEG's Avatar
Default Re: Brake Pads (Just_LS)
I have some slightly used Carbotech AX6 pads and Rotors for sale if you want them.. . or higher temp/bite XP8s slightly used as well.
$120 shipped - Nice slotted BRembo Blanks from Tire Rack - used with AX6s with the rotors (5,000 miles, 8- 20min track sessions). Will sell for $120 shipped - Rotors alone are $120 from TireRack. Pads cost $130 from CTbrakes.com
$120 shipped - Very little used XP8 pads with used blank rotors (1,000 miles 10- 20 minute track sessions) - $120 shipped - pads are $140 new from CTbrakes
I can sell brand new Rotors with these pads as well.. .
8- 20 minutes race sessions = means I participated in a HPDE and was out on the course for around 20 minutes, 8 times through the weekend.. .
Reason I'm selling - I'm upgrading to 11" rotors with ITR calipers
Modified by 6spdKEG at 1:57 PM 2/15/2007
Old 02-15-2007, 10:35 AM
you better correct that post. 1000 miles 10 qty?? You got 10 of those pads for $120?
Old 02-15-2007, 10:58 AM
FlyZlow's Avatar
Why not use stock pads for the street and track pads for the track? Any combination will be a compromise on both ends and it only takes 10 mins to swap out the fronts.
Old 02-15-2007, 11:48 AM
6spdKEG's Avatar
Default Re: (FlyZlow)
I find that the XP8s and AX6 pads are streetable which means you will have plenty of power behind your brakes when you are using that 300whp car on the street. They will dust a little bit more than your average pad but the dust is noncorrosive and comes off easily.
Old 02-15-2007, 07:02 PM
osprey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie Hartanto &raquo;</TD></TR><TR><TD CLASS="quote">carbotech AX6. You will love it. Check out http://www.ctbrakes.com</TD></TR></TABLE>
yum carbotech...
the panther xp10s are an awesome pad
Old 02-15-2007, 11:02 PM
Kamin's Avatar
Default Re: (tehBenz0r)
ive been using Hawk HPS's for a long time now, they are decent. i have a little bit of fade issues on hot days or HARD sessions in DE but cant beat them for the money. im anxiously waiting for these to die so i can step up to some blues.
Old 02-16-2007, 12:49 PM
bender's Avatar
I used the Axxis Ultimates on my dd/autox car, and really liked the performance. But it was a lot more dust than I wanted to deal with on a street car. I switched to the Carbotech Bobcats when the Ultimates wore out, and I've been happier overall.
Old 02-16-2007, 08:04 PM
Supahr_Ed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianZ &raquo;</TD></TR><TR><TD CLASS="quote">I like the Colbalt friction Spec B's but that is a track only pad... for street i stick to OEM pads.. </TD></TR></TABLE>
sorry i have to put a cheap ad link...look if your interested
https://honda-tech.com/zero...05127
Old 02-16-2007, 08:16 PM
Banned
turboteener's Avatar
I am running Hawk HPs pads in my DD/track car. I love them for a street pad. They don't have the problems that performance friction pads had on cold startup and they bite extremely hard when hot.
I ran two 45minute sessions without a hint of fad. Now that was with a good 140hp. Now double that and I will probably have a problem.
For this year I am going to go to an 11in rotor and add some brake ducts to my race airdam. And will probably go with HP+ or Blacks.
Old 02-17-2007, 12:06 PM
Reflex Speed's Avatar
any more info on hawk pads?
Old 02-18-2007, 12:54 AM
osprey's Avatar
Default Re: (Reflex Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reflex Speed &raquo;</TD></TR><TR><TD CLASS="quote">any more info on hawk pads?</TD></TR></TABLE>
lots:
https://honda-tech.com/zerothread?id=1824307
https://honda-tech.com/zerothread?id=1780840
https://honda-tech.com/zerothread?id=1763227
https://honda-tech.com/zerothread?id=1586515
https://honda-tech.com/zerothread?id=1270519
https://honda-tech.com/zerothread?id=1236780
and too many to list... happy reading
Old 03-01-2007, 12:45 PM
Milan0Gsr's Avatar
how about ebc brake pads?
Old 03-01-2007, 02:09 PM
Lo-Buck EF's Avatar
Default Re: (Milan0Gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milan0Gsr &raquo;</TD></TR><TR><TD CLASS="quote">how about ebc brake pads?</TD></TR></TABLE>
Junk.
Old 03-01-2007, 05:32 PM
ZUL8R's Avatar
Default Re: (Lo-Buck EF)
Has anyone used the EBC Yellow? I have a buddy thats using them on his HC car. They lasted him all last season and hes gonna use them his first event this year.
I dont get it
Old 03-01-2007, 07:09 PM
Lo-Buck EF's Avatar
unless they have changed their compound, they still suck. remember, people use axis ultimates on their race cars and say they do the job. maybe they aren't hard on brakes or whathaveyou. if your friend is running an H5 car at tracks that arent hard on brakes, ebc may actually work. i'm not saying hes lying or he's wrong. just saying i havent had any good experiences with ebc brake pads in the past.
BTW- my vote for street pads are the axis ultimates.
Old 03-01-2007, 07:49 PM
smokin rubber's Avatar
Default Re: (ZUL8R)
I would get axis ultimates for the street/autocross and something much stronger for the track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone used the EBC Yellow? I have a buddy thats using them on his HC car. They lasted him all last season and hes gonna use them his first event this year.
I dont get it </TD></TR></TABLE>
I think he did six events with those pads and is trying to get one more. I am suprised they lasted this long.
Old 03-01-2007, 11:24 PM
blackdc5's Avatar
Default Re: (smokin rubber)
Shouldn't one consider the tires one's using when choosing the pads?
For example Im using HPS w/ RT615s...I can still activate ABS if I tried, so I figure I would need more tire, not more pad.
But would a gripper pad mean less pedal force is needed to stop the car, thus less pressure exerted on brake fluid, thus less chances of bluid boiling?
Reason I ask is because on the way home from the track day, my pedal was mushier than when I came...it was fine all day on the course though.
Old 03-02-2007, 06:06 AM
mc-integra111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokin rubber &raquo;</TD></TR><TR><TD CLASS="quote">I think he did six events with those pads and is trying to get one more. I am suprised they lasted this long.</TD></TR></TABLE>
I have only used Hawk Blue's. When I first started (not good, still learning) 1 front set lasted me 8 weekends. Now, with the car at pace with ITA leaders, I get 5 weekends. The conclusion I am drawing is that you're skill (how hard you brake) is a strong determiner of how long the pads last. An H5 car is significantly lighter than my Integra, so could believe 6 or more events.
Rekorb9
Honda Civic Type-R (2017 - Current)
12
10-09-2019 07:02 AM
MilanoRedDC2
05-14-2009 12:04 PM
blackapino85
22
08-05-2004 02:13 PM
RATEDR
03-01-2002 10:37 AM
MaddMatt
03-01-2002 02:48 AM
Quick Reply: Brake Pads
