what head studs for ls/vtec? timing belt?
Old Jan 9, 2003 | 10:40 AM
avividmemory's Avatar
Default what head studs for ls/vtec? timing belt?
b18 block, b16 head...im not sure if i would need the b16 or b18 head studs...im thinking b16, but then again ive been wrong before
and also would i use a b18 timing belt w/ it since it is dependant on the block?
TIA
Old Jan 9, 2003 | 11:01 AM
misledyouth's Avatar
New User
Default Re: what head studs for ls/vtec? timing belt? (SpoolinLS)
gsr head studs
and the timing belt has to mach the water pump and oil pump
aka b16 water and oil = b16 timing belt
ls water and oil = b18 timing belt
Old Jan 9, 2003 | 12:22 PM
BROOD's Avatar
Default Re: what head studs for ls/vtec? timing belt? (misledyouth)
gsr head studs
Any of the B18 engine headstuds will work. You need the studs for a B18 deck height. GSR or ITR head studs will work fine.
the timing belt goes with the water pump, but not how it was before mentioned
Vtec water pump = B18 Vtec timing belt (either ITR or GSR belts)
non-Vtec water pump = B18 non-Vtec belt (either LS or CRV belts)
you have to kep in mind the difference in deck heights between the B16 and B18 blocks as well as the pulley diameter difference between the non-Vtec water pumps and the Vtec water pumps
[Modified by SLPR, 1:29 PM 1/9/2003]
[Modified by SLPR, 8:57 PM 1/10/2003]
Old Jan 9, 2003 | 02:49 PM
CHEETAH's Avatar
Default Re: what head studs for ls/vtec? timing belt? (SLPR)
also just tell him 22 teeth use gsr/ITR P72 belt and for 19 teeth use LS/B20b belt PR4/P3F
greg
Old Jan 9, 2003 | 03:03 PM
Default Re: what head studs for ls/vtec? timing belt? (CHEETAH)
thanks for the info guys...it was a big help
rick_rabies
Apr 1, 2009 12:59 PM
B6tizzleHatch
14
Aug 14, 2006 08:49 PM
mycrx7
14
Jun 14, 2005 02:14 AM
1SlowSi
Mar 21, 2005 05:59 PM
hybridb18
Feb 18, 2004 07:40 PM
