Bad speed sensor equals no VTEC?????
Hey i know for a fact my speed sensor is messed up and cracked. And there is an CEL code for the speed sensor. But nothing else. VTEC is not working and i have plenty of oil. The speed sensor is for sure messed up. I have one on the way. should this fix my probs???
Re: Bad speed sensor equals no VTEC?????
Having vtec problems myself. Was thinking it was my speed sensor but gauges all work fine, I can restart car and vtec will work but it seems like it's missing then goes into limp mode. Put a brand new vtec on it and no changes
CEL on for any reason means limp mode with no VTEC. When you turn key off and back on, the ECU goes back to normal mode until the problem is detected again.
What do you mean by "goes in and out like its trying to work"? It either works or it doesn't work.
Your solenoid could be dirty or broken.
just went through this too.
bad speed sensor = no vtec or odometer or cruise control.
tried the cheaper manual trans sensors but they are crap.
the $140 standard motor unit from rockauto finally settled down
and stopped glitching and has 3 year warranty.
the denso unit is $200 or so but can be had from japan for $113
https://jp-customparts.com/
