Function and Form coilover thread
Old May 29, 2010 | 05:48 AM
  #776
SHG_Claudio's Avatar
Default Re: Function and Form coilover thread
Originally Posted by kimosabe
Types I ans Types II lower the same ???
Yes
Old May 29, 2010 | 06:07 PM
  #777
emii's Avatar
i want the type 2.5 super bad
Old May 30, 2010 | 04:28 AM
  #778
kimosabe's Avatar
Yes
thanks dude
Old Jun 5, 2010 | 03:04 AM
  #779
DOMAN!EJ8's Avatar
just confirming, but how do you adjust the height? there's 3 collars total, 2 right under the spring, and one by itself. thnx.
Old Jun 5, 2010 | 04:16 AM
  #780
Correct. The first 2 collars/perches are together and they lock against each other to hold the spring in place. That is the preload. Don't mess with it as it's already set correctly. When you install them. Use the wrenches that come with it and tighten those 2 together a little better. I used a flathead an hammered it to tighten as I heard the wrenches don't fit good.
The height itself is adjusted from the bottom perch. That one you twist and them twist the lower body so that it sits right under the perch thus locking them.
Old Jun 5, 2010 | 04:41 AM
  #781
|eG|BB4's Avatar
This is my friends lowered with Type IIs.
Front is less higher than the rear until new tires are in.
Old Jun 5, 2010 | 06:31 AM
  #782
RareSpirits's Avatar
I have Type I. I love them. No Major complaints except I wish I had adjustability. So one day I will go and buy the 2.5's 12k 10k
Old Jun 5, 2010 | 10:55 AM
  #783
DOMAN!EJ8's Avatar
if i understand this correctly, so you twist the whole shock body? then lock it with the bottom perch, is it the same process for the rear? since the whole shock body attaches to the lca
Old Jun 5, 2010 | 11:19 AM
  #784
TYL3R's Avatar
just ordered some type 1's for my new car... cant wait to get them!
Old Jun 5, 2010 | 11:45 AM
  #785
chads's Avatar
I have the type 1s
Old Jun 5, 2010 | 12:14 PM
  #786
Yeah but idk about the back. I have not adjusted my height yet but I think you have to take the lca bolt out and the pull the F2 out and then twist it
Old Jun 5, 2010 | 12:49 PM
  #787
A.C. Slater's Avatar
Thats how I did it...kinda sucks but oh well
Old Jun 5, 2010 | 01:42 PM
  #788
EjSex's Avatar
all the way
Old Jun 5, 2010 | 02:18 PM
  #789
Thats pretty low! Lower the tire pressure and you sir are slammed!
Old Jun 5, 2010 | 02:30 PM
  #790
EjSex's Avatar
haha i should have
i got rear ended in that car last year on my birthday <\3
Old Jun 5, 2010 | 02:42 PM
  #791
Oh sucks to hear... Did you adjust the preload?
Old Jun 15, 2010 | 07:49 AM
  #792
NissanSkyline901's Avatar
Got mine for my wagon yesterday. These are all the way down. They haven't settled yet at all either.
Old Jun 15, 2010 | 11:02 PM
  #793
wannaBjdmca6's Avatar
WTF :h ammer:
u guys make the F&F gods mad lol u dont have to take them out just do the same as the front.
1 losen the last collar
2 twist the 2 upper collars TOGETHER up or down depending on what u want
3 tighten back up
4 get an alignment
5 enjoy!
Old Jun 16, 2010 | 04:19 AM
  #794
Originally Posted by wannaBjdmca6
WTF :h ammer:
3 tighten back up
4 get an alignment
5 enjoy!
Uh no? on you.
By adjusting the 2 top collars you are changing the preload. You are supposed to adjust height by the bottom collar. When you adjust the preload, the way your suspension handles is no longer the same. You will loose suspension travel.
I'm going to try to do the rear by just taking off the bolts from the top and pushing down on the rotor until the suspension pops out from the chassis and adjust it from there.
Old Jun 16, 2010 | 06:18 AM
  #795
Blazin Si's Avatar
Loved
Community Favorite
Just installed Type 2's on my DD. They ride much better than I has expected. The dampening is set to full stiff and it still rides really nice. The Omni's on my Civic are extremely harsh in comparison.
Old Jun 16, 2010 | 06:47 AM
  #796
732xghost's Avatar
dude i love your CL. keep up the awesome work.
Old Jun 16, 2010 | 07:03 AM
  #797
BG451MO's Avatar
wow so low, you feel comfortable driving it? :D
Old Jun 16, 2010 | 09:06 AM
  #798
red92si's Avatar
For the people that want the 2.5's.... why not just buy some Eibach ERS springs on your own? Same with the Type-1; you could upgrade to Eibach ERS springs with no problem at all.
Old Jun 16, 2010 | 12:59 PM
  #799
Uh no? on you.
ure a complete moronnnnn haha
by twisting both upper collars together at the same time they will move the whole shock around and no preload will be lost. the collars will never move from were they originally were in the threaded body. if they do move then put them back were they were and tighten them to eachother more until the whole shock moves with the rings simultaniously.
jump off a bridge my friend. READ THE ****ING INSTRUCTIONS FORE WHEN THE COILOVER IS IN THE CAR!
they come in the box IM DISSAPOINTED SON
Old Jun 16, 2010 | 01:09 PM
  #800
-NA-aLL-thE-wAy-'s Avatar
EFSS153
No, not when they are tightened together. When they are together and the lower gold collar is loose, you can rotate the entire unit to raise and lower it by turning the two locked collars as one with the included wrench. Read the instructions again. If the two top collars are NOT locked together and you screw them down on the threads THEN you are adjusting the preload.
