Function and Form coilover thread
at the same time i wana have the ability to slam...and they cant do that so i didnt get them
you're out of your mind tarik. you've got a huge fake mugen lip on your black integra and its sits at about the same height.
Either way doesnt really matter because it doesnt apply to this thread. Can't wait to order some.
and its not huge.
keep in mind my integra is just on stock shocks and gc coilovers....and its a little lower than that red coupe....
my goal is to go another 2 inches lower once i install my koni's and top hats
Yeah I pretty much just learned this on my own. Ive been spraying PB blaster for a week like 5 times a day and I tried to loosen it up tonight and I couldn't do it. I didn't have much space to work with the car on the ground but like it would be hard without leverage. That bolt is in there pretty good. My car has a very large amount of seized bolts
Not yet. I was going to do them this past Sunday with my friend but we both had a hangover from the night before haha. So we delayed it. I'm doing them tomorrow. Its going to rain but I should still be able to make it happen.
I'm in the ***** if the bolts break
I really wasn't able to put much force on it so it might still break when I use a breaker bar tomorrow. Ill whip out the torch if I have to. Im definately applying anti-seize though.
^^^looks good! height looks good too considering those body styles are supposedly hard to get low.
I think i'll be placing my order with weksos tomorrow
I went and installed my Type 1s today. I only did the fronts because it got cold and dark and my friend had to go. I'll be doing the rears tomorrow!
I didn't want to strip the rear bolts so I did the fronts first because they're a lot easier.
Me and my friend Miguel did them. Here we go!
Remove strut bar and those bolts
Then the 2 brake line brackets
Then the LCA bolt.
Then the fork bolt
Wirewheeled the fork to remove some rust and the used sandpaper.
I guess I had real TEIN sprins, I wasn't sure about whether they were or not
Ta-daa!!!
Comparison shot
Anti seize on all these bolts!
This is the height at the moment, I will set it lower once I get a camber kit.
How it was before
So yeah about an inch drop.
They drive really nice, I'm very happy with my coilover selection. The car feels nice and firm but not too stiff and it clears bumps pretty nicely. I can definitely feel the weight of the car now. Its night and day. It feels great!
Then the LCA bolt.
Then the fork bolt
Ta-daa!!!
Comparison shot
How it was before
wrong and wrong
. look up mines the black ej6, front all the way down.
and they do not go SLAMMED. i can go lower but from the pre-load perch but i wont touch it as it will void my warranty.
also i dont see the point of going any lower. as my UCA are like 2 cm. away from the shock towers.
I have a lot of experience with these coils, ive owned a few sets. You can make them go lower than you can imagine, frames can touch the ground if thats what you want...
lol i want to take pics soooo bad but im still putting the rears on cuz the lca bolts snapped =[ but once i get them on ill pist em up. its not on the stock 15s its on 16x8s with a +20 offset but the fronts are having trouble clearing all the way down so ima put on the camber kit and see what i can do.
we'll see should be done this week
we'll see should be done this weeki still can drop about an inch more....which i might but i have to do some more fender clearing. should have an update tomorow
^It's not even that.
People just don't know what the **** they're doing. And it's getting a bit annoying hearing all these retards talk about how their set won't go 'low enough'.
Then the LCA bolt.
Then the fork bolt
Ta-daa!!!
Comparison shot
How it was before
Then the LCA bolt.
Then the fork bolt
Ta-daa!!!
Comparison shot
How it was before
DUDE what a nice work !!!! how low can you go with type Ones???? :D it RULZ
ok i have some skunk2 coilover w/ stock shock and been driving them for a while now on a slight level drop. front is drop so that the fender cover the tire top at lease haft an inch or less. back side is drop even with quarter panel or so that you can slip your index finger between the tire and the quarter panel. i'm ok with the ride feeling although it sure bonce but now i'm thinking about to give it a drag look. More drop in the front and more rise at the back. i want to know how the performance will be. i try this setup once before but not for long. i notice that the car is less bouncier. so let me know what is the downfall and how will it perform.
although i could just rise the back but i wont be able to get out of my driveway w/out mid/heavy scratch at the bumper and/or under the car. i do angle out/in and on lot of of speed bump to. will any advice, knowledge will be thank..
