DA Integra's Only
Old Mar 12, 2012 | 11:14 AM
  #51326
OldSkoolDa91's Avatar
Default Re: DA Integra's Only
its cool. i am trying to have it done in time to hopefully bring it down for the ifo event though. but with the way things are going, i'll be lucky if that happens
Old Mar 12, 2012 | 11:25 AM
  #51327
Mattb16teg's Avatar
Community Builder
Community Influencer
Cool, would like to see this thing. I'll holla at him tonight.
Between, school, work, house, wedding, it's tough to find time for anything else.
Old Mar 12, 2012 | 11:52 AM
  #51328
yeah i bet. and hopefully you can see it at ifo... its nothin to look at right now though. needs a lot of work
Old Mar 12, 2012 | 11:59 AM
  #51329
EFcivicJDM's Avatar
random
Old Mar 12, 2012 | 12:51 PM
  #51330
HeLLa iLL2ndGen's Avatar
Lol Cali plates
Old Mar 12, 2012 | 12:59 PM
  #51331
ReV-TeKs_92_GsR's Avatar
Don't know how 2 upload pix of my DA :/
Old Mar 12, 2012 | 01:00 PM
  #51332
trashyhatch's Avatar
FAQ
Old Mar 12, 2012 | 01:08 PM
  #51333
wats FAQ?? lol
Old Mar 12, 2012 | 01:10 PM
  #51334
seriously? https://honda-tech.com/faq.php?faq=v...b3_attachments
Old Mar 12, 2012 | 01:20 PM
  #51335
EFcivicJDM's Avatar
frequently asked questions!
  #51336
oh Thx. Sorry bout dat its kuz I'm knew to diz
  #51337
EFcivicJDM's Avatar
Originally Posted by HeLLa iLL2ndGen
Lol Cali plates
ye there really funny ???
Old Mar 12, 2012 | 01:21 PM
  #51338
at the top -- where User CP, Home, etc is.. READ THE FAQ!
Old Mar 12, 2012 | 01:25 PM
  #51339
Yooo... How do u insert the heart in ur signature? Kan't find it
Old Mar 12, 2012 | 01:28 PM
  #51340
highlight > copy > user control panel > edit signature > paste
any more questions?
Old Mar 12, 2012 | 01:36 PM
  #51341
Thx. well i dont know if diz is new but I have a problem wit my rear tires. It has bad camber wear. I did DA alignment an bought an aftermarket rear camber kit. Is DA camber wear still there because I need a better rear camber kit? If dats the problem, which do u reccomend? Juz want DA camber wear gone and want my tires to be like brand new like in DA front.
Old Mar 12, 2012 | 01:38 PM
  #51342
if your camber kit is an ebay, yes. a new, name-brand will probably help. also, are YOU adjusting the camber or are you taking to a tire/wheel shop? also, it's not just camber that eats up tires.. toe also does.
Old Mar 12, 2012 | 01:44 PM
  #51343
Well I just ordered a skunk2 rear camber kit. Do you think that will help stop it? The homie installed the camber kit and then i took it to the shop to get it aligned. Wat do you mean by toe?
Old Mar 12, 2012 | 01:45 PM
  #51344
i'm having trouble following what you're saying because you aren't using english.
Old Mar 12, 2012 | 01:48 PM
  #51345
sorry about that. it is english. and I juz edited the post.
Old Mar 12, 2012 | 01:51 PM
  #51346
ebonics and english are two different languages.
**edit** you said back tires were the ones wearing, so toe isn't the issue. a good shop should be able to adjust your camber back to OE specs, especially when you are running a camber kit.
Old Mar 12, 2012 | 01:55 PM
  #51347
Yes. The back tires are the ones that are wearing out. The front ones are like brand new. Do you think skunk2 rear camber kit can fix my problem with my back tires?
Old Mar 12, 2012 | 05:28 PM
  #51348
top_speed's Avatar
My B18c powered DA
Old Mar 12, 2012 | 06:15 PM
  #51349
Colin's Avatar
Incorrect toe settings can wear out your tires regardless of whether they are front or rear.
Old Mar 12, 2012 | 06:33 PM
  #51350
blackguy503's Avatar
Originally Posted by 91b18a1ls
Pull one of the plugs out and watch the end of it for a spark. If dont see a spark then something is wrong with the distributor.
I've been having some issues with the electronics on my (b16) 92 da.
The issues i'm having: When I apply my brakes all my lights dim. I'll apply the brakes and my radio will shut off and my headlights will go off for a second and them come back on, but will be very dim until I release the brakes. The other night it got so bad that when I hit the brakes my whole car shut off for a second and then when I released the brakes it started up again. When I'm sitting at stop lights I can't have the brakes on or else all my lights come close to shutting off and my idle drops to about 200 rpm. The weird thing is this doesn't happen every night. It's a random thing that will go away for a few days and then just start acting up again.
The other issue i'm having is : After i've been driving for a while, my idle will start acting weird and move up to about 1200 and then drop down to about 700. It doesn't seem like a vacuum leak cause i've had that issue before and the idle would bounce up and down quite quickly and repeatedly. This is acting different. It will go up to 1200 and then hold there for a few seconds and then slowly return back down. It does this every 15 seconds or so. The weird thing with this is when I release the brake peddle the idle stops acting like that and stays right at 900 where I have it set. I'm not sure if the two issues are connected in any way, but it sort of seems like it to me.
The things I've checked : I hooked a volt meter to my battery when the car was on, all my lights, and my radio were on. The meter read 14.40V and when I applied the brakes it only dropped down to about 13V. I also hooked the volt meter to my alternator when the car was running with all the lights on and it read 14V. With the brakes applied it dropped to about 12.3V. I don't think it's my alt but I could be wrong. Now my battery is relocated to the trunk, but it's been that way for awhile now and I haven't had these issues until a few weeks ago. I checked all my grounds and they're all tight and corrosion free.
I'm not sure what else to do or check. I know that was really long, and thank you to anyone who took the time to read it. Any ideas guys? Thanks
(Next time the issue with the lights starts acting up I'll try and get a video of what it's doing)
thanks and yeah i pulled it out and it didnt get any sparks. i replaced the plugs and wires and still nothing. i was getting towed i had my lights on my lights would flicker and then my radio would go on and off. now my battery is like almost dead. im thinking its the distributor.
