DA Integra's Only
Old Mar 11, 2012 | 11:43 AM
  #51301
hb420's Avatar
Default Re: DA Integra's Only
Yes
Old Mar 11, 2012 | 12:16 PM
  #51302
HardLuckfoto's Avatar
Awesome thanks, Found some white ones off a 91 DA at a local junkyard, I'd like to pick em up and swap out my black ones...
Old Mar 11, 2012 | 02:03 PM
  #51303
gsilnc's Avatar
engine bay clean up
before
after
also changed the trans oil, im hoping it solves the whole popping out of fifth thing
Old Mar 11, 2012 | 05:20 PM
  #51304
EFcivicJDM's Avatar
thinking of dropping in a k swap into my rhd da6 xsi...car is a obdo b16a JDM...what do i need?
even a link if there is one be handy..
i know i need k20 engine box loom
conversion mounts
new driveshafts etc is that it?
how much would it cost to swap it in
thanks
Old Mar 11, 2012 | 05:22 PM
  #51305
Brice.Hayden's Avatar
10,000 Euros
Old Mar 11, 2012 | 05:40 PM
  #51306
EFcivicJDM's Avatar
how did you come up with that?id pay bout 1500-1800 for engine box loom ecu etc..how much are the mounts drives etc
Old Mar 11, 2012 | 06:11 PM
  #51307
hb420's Avatar
Darren check this thread out, it might answer your questions
http://forums.g2ic.com/showthread.ph...body-built-one
Old Mar 11, 2012 | 07:25 PM
  #51308
ManManning's Avatar
My Da
Old Mar 11, 2012 | 07:47 PM
  #51309
gsilnc's Avatar
nice tuck
Old Mar 11, 2012 | 07:48 PM
  #51310
Boosted_hx00's Avatar
Damn! Sick a** Teg! What offset are those wheels^^^^^?
Old Mar 11, 2012 | 07:51 PM
  #51311
ManManning's Avatar
thanks man!
wheels are 16x8 +25 or 26 offset.
Old Mar 11, 2012 | 07:58 PM
  #51312
Nice! Looks dope bro!
Old Mar 11, 2012 | 08:14 PM
  #51313
blackguy503's Avatar
so my car isn't getting a spark. i think its the distributor i got new plugs and wires but still nothing. had to tow home tonight. :/
Old Mar 12, 2012 | 12:01 AM
  #51314
91b18a1ls's Avatar
Pull one of the plugs out and watch the end of it for a spark. If dont see a spark then something is wrong with the distributor.
I've been having some issues with the electronics on my (b16) 92 da.
The issues i'm having: When I apply my brakes all my lights dim. I'll apply the brakes and my radio will shut off and my headlights will go off for a second and them come back on, but will be very dim until I release the brakes. The other night it got so bad that when I hit the brakes my whole car shut off for a second and then when I released the brakes it started up again. When I'm sitting at stop lights I can't have the brakes on or else all my lights come close to shutting off and my idle drops to about 200 rpm. The weird thing is this doesn't happen every night. It's a random thing that will go away for a few days and then just start acting up again.
The other issue i'm having is : After i've been driving for a while, my idle will start acting weird and move up to about 1200 and then drop down to about 700. It doesn't seem like a vacuum leak cause i've had that issue before and the idle would bounce up and down quite quickly and repeatedly. This is acting different. It will go up to 1200 and then hold there for a few seconds and then slowly return back down. It does this every 15 seconds or so. The weird thing with this is when I release the brake peddle the idle stops acting like that and stays right at 900 where I have it set. I'm not sure if the two issues are connected in any way, but it sort of seems like it to me.
The things I've checked : I hooked a volt meter to my battery when the car was on, all my lights, and my radio were on. The meter read 14.40V and when I applied the brakes it only dropped down to about 13V. I also hooked the volt meter to my alternator when the car was running with all the lights on and it read 14V. With the brakes applied it dropped to about 12.3V. I don't think it's my alt but I could be wrong. Now my battery is relocated to the trunk, but it's been that way for awhile now and I haven't had these issues until a few weeks ago. I checked all my grounds and they're all tight and corrosion free.
I'm not sure what else to do or check. I know that was really long, and thank you to anyone who took the time to read it. Any ideas guys? Thanks
(Next time the issue with the lights starts acting up I'll try and get a video of what it's doing)
Old Mar 12, 2012 | 12:18 AM
  #51315
Ax3l's Avatar
Is there a way to make the oem usdm corner lights all clear without the amber piece in them? Like on the black drag car posted on the other page? Or are they aftermarket corner lights? -thanks.
Old Mar 12, 2012 | 02:33 AM
  #51316
89efhatchy's Avatar
They're aftermarket. They were like that when I bought the shell.
Old Mar 12, 2012 | 04:29 AM
  #51317
EFcivicJDM's Avatar
thanks herb
Old Mar 12, 2012 | 06:44 AM
  #51318
Mattb16teg's Avatar
Community Builder
Community Influencer
Haaaaaaaaaaayyyyyyyyyyyyyy!
Drag car looks great!
Old Mar 12, 2012 | 07:22 AM
  #51319
OldSkoolDa91's Avatar
hey matt, any word on that j pipe?
Old Mar 12, 2012 | 07:29 AM
  #51320
Stevo-DA's Avatar
WAkka WAkka biotchs. almost done in the stan. cant wait to get back and get back into the car scene
Old Mar 12, 2012 | 08:54 AM
  #51321
gsilnc's Avatar
get home safe bro
Old Mar 12, 2012 | 09:09 AM
  #51322
jasperDA's Avatar
My teg waiting in the garage for its new heart
Old Mar 12, 2012 | 09:54 AM
  #51323
gsilnc's Avatar
random shot
Old Mar 12, 2012 | 09:57 AM
  #51324
johnnyvtec22's Avatar
Old da, just wanted to share.
Old Mar 12, 2012 | 10:29 AM
  #51325
Mattb16teg's Avatar
Community Builder
Ahh freak me! Sorry, I've been so busy man! Too much stuff going down.
I'll hit Matt up and see if he can drop it off to me, I'm sorry!
