DA Integra's Only
Old Nov 14, 2011 | 06:20 AM
  #49901
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: DA Integra's Only
^ post up graph clown! Now drive it when you come up!
Old Nov 14, 2011 | 06:27 AM
  #49902
OldSkoolDa91's Avatar
you get your switch yesterday matt?
Old Nov 14, 2011 | 06:31 AM
  #49903
so i worked on a friends da yesterday. he just got it about 2 weeks ago and like 3-4 days after he go it, the clutch let go while driving it. figured it was the pressure plate but when we pulled the tranny yesterday, found this...
no idea what kind of clutch it was, but it was DESTROYED!! no wonder it wouldn't shift into gear when the car was running
Old Nov 14, 2011 | 06:46 AM
  #49904
Mattb16teg's Avatar
Community Builder
Yea, luckily there are about 3 Integras there, one is a few days old and I even found a red light ticket in the car from a few months back. Looks like it just got impounded or donated. Car is in great condition. I pulled a bunch of stuff off there.
Although I didn't get to test it because I was in a rush and like an idiot hooked it all up and decided to put the switch in last. I tapped the back against some metal and arched it and blew the Ign fuse. I didn't have any 50 amp fuses laying around so I have to grab one today to test it.
But I think I will take some time to redo some wiring under my dash. It is a mess because the aftermarket alarm I had put in years ago and such.
Grrrrrr!
Old Nov 14, 2011 | 07:05 AM
  #49905
lol gotta love wiring!!
there's a really mint da at the junk yard i normally go to right now too. wish i had the extra money to just rob that thing. i'd love to grab both bumpers, head lights, tail lights, n driver side door to start. possibly more
Old Nov 14, 2011 | 07:14 AM
  #49906
Mattb16teg's Avatar
Community Builder
it sucks because I spent all weekend working on the car, small change here, small change there, etc.
Sunday I finally get on the verge of getting everything straight and we had plans so I was SOL lol.
There are some mint seats in this one that I want. Grey with the red insert. Not sure how they will go with my palmy blue interior but oh well.
Old Nov 14, 2011 | 10:56 AM
  #49907
kiDchaos's Avatar
Originally Posted by tougetuned_ef
so my baby is sitting in the place it will sit for the next 6months-1year. its sitting in a parking lot of grand nationals, rare turbo firebirds, vettes, a typhoon, some nice classic mopars and a turbo vw bug! hes got a hemi cuda he's been slowly restoring for the past 10 years. with no.s matching motor and trans. oh and a nut and bolt restored GNX in the shop. leaving for Utah on thursday for and unknown amount of time. maybe my buddy will man up and buy a house with a garage and i would fly back to get the car.
got that for ya on a real note, good luck out there. I'm jealous over here!
Originally Posted by Ncal ef2
Who wants too buy a real deal da8 integra xsi rhd b16/lsd trans 4500
Just motor and tranny or complete car?
Originally Posted by Mattb16teg
I have the short geared B16 YS1. Gearing is too short now.
I guess you learn somethign new every day. I had no idea there was a YS-1 b16 cable tranny out there. what did this come out of? (or are you guys just josh'n someone?)
Since everyone was talking about it earlier. Feel pretty proud i finally found a really nice, smooth shifting gsr ys-1 for $350 thanks to dave. I Thought that was a great deal.
Old Nov 14, 2011 | 11:58 AM
  #49908
Mattb16teg's Avatar
Community Builder
^ no, no joshin, see list:
S1/YS1/A1USDM B18A
YS1USDM B17A1; JDM B16A X-Si w/LSD
http://hondaswap.com/reference-mater...n-specs-29132/
Old Nov 14, 2011 | 12:28 PM
  #49909
TurdBlown Teg's Avatar
i wish the b17 ys1 wasnt labled that
Old Nov 14, 2011 | 12:55 PM
  #49910
kiDchaos's Avatar
S1/YS1/A1USDM B18A
lol. so its the same one they used in the b17 gsr. i wonder why they call it two different things then.
so i kept getting all my info here: http://www.ff-squad.com/tech/temp/Bgears.htm
but figured it was a mis print since they labeled the JDM integra body running in '93 as well. I thought they stopped building the DA chassis in '92 over there.
Old Nov 14, 2011 | 01:43 PM
  #49911
DumaDA's Avatar
The codes they used for honda transmissions are pretty retarded. If I remember correctly there's 4+ different codes on b16 cable transmissions
Old Nov 14, 2011 | 02:16 PM
  #49912
Mattb16teg's Avatar
Community Builder
LoL Yup!
So I'm having a weird issue with the car now all of a sudden:
Ignition gets KO power. But fuel pump won't prime and ECU doesn't get power. Replaced main relay and ignition switch to no luck. No blown fuses either.
Started the car and it was idling then stalled and now the above issue....
Car will still crank however since the pump doesn't prime there is no fuel pressure and no fire...
Anyone encounter this?
Old Nov 15, 2011 | 02:23 PM
  #49913
sd93teggy's Avatar
got a question guys im ordering function and form type 1's sometime this week and was told they dont go too low for the DA but if i were to get EG coilovers and get EG front forks it would be lower? i wanna know if that is true and wouldnt the shocks blow faster because not only am i gonna be slammed but the DA chassis weighs more than the EG.
so lmk whats up guys thanks in advance.
Old Nov 15, 2011 | 04:45 PM
  #49914
tougetuned_ef's Avatar
be carefull on that because im running ek koni yellows and they are too tall. the front i cant slam without having no bump stops and i would bottom out if i didnt have them. also the rear will dump but i would have only 2 inches of travel. i also had to trim my brand new bushings in the rear to have them work. but when i have it at a good drivable height then they are perfect.
also with konis it doesnt matter how low they are it does not effect the shocks when they are dumped. you can dump with koni yellows and gc setup. just get race valves in the shocks for a stiffer spring rate. with street valves i think you can only go to 600lbs springs. im running street valves with 500 front and 400 rear and its a good dd setup. but if you want to track your car and its not a dd then i woulld go 900fr and 800rear or if its goin g to be a track car i would say 1100 fr and 1000rear.
Old Nov 15, 2011 | 04:57 PM
  #49915
DumaDA's Avatar
if you want to slam your car dont bother with function form type I, just get a gc/koni set up and if you cant afford it then keep saving. Where were you last week when i was selling KW coilovers?! Ended up getting rid of them for $350
Old Nov 15, 2011 | 05:33 PM
  #49916
sd93teggy's Avatar
my cars far too slow to even park at the track lol. its a dd that i use for work/school. im not the lowest da out there but i like to be slammed. im really worried i wont be happy with my type 1's i hope thats not the case i just wish i could find a picture of a da on type 1's thats maxxed out from just the lower mount without touching the preload. damnnnnit
Old Nov 15, 2011 | 05:35 PM
  #49917
sd93teggy's Avatar
man i wish i woulda known about that. it seems to be when the good deals are around thats when im broke. im really on the fence about this i heard type 1's are really good for the money but with the holidays coming i wont have this money for long so im just gonna have the go with the type 1's.
Old Nov 15, 2011 | 06:49 PM
  #49918
Mattb16teg's Avatar
Community Builder
Why do you want to be "slammed"?
Old Nov 15, 2011 | 07:49 PM
  #49919
sd93teggy's Avatar
i dont wanna be stupidly low. but i think if your not tucking tire with a DA it doesnt look that great also i have a stock ls and dont do any autox or anything so it really doesnt matter. for people who actually drive there car hard of coarse there not gonna be slammed but i dont and i like being low so thats why.
Old Nov 15, 2011 | 09:38 PM
  #49920
Bond's Avatar
Wow guys I haven't stopped by here in FOREVER!!!
I know I bet some probably thought I died or probably dont even remember me. Life has been busy since I lost my great friend chris vang (90_DA) this summer in a drowning/fishing accident. Some of you may recall hearing about it as he was a great DA enthusiast. Since then I have promised me (and him) that I would get my DA done. I've been busy working hard on it when ever I can. I'll update with pics and stuff in the next couple days as I need to take some lol.
Great to see this thread still moving along nicely
Old Nov 15, 2011 | 09:52 PM
  #49921
well ill say that i love my koni/gc set-up for cruising. and handled great when doing autox. just save up for them i swear you will not be disappointed. and you can dump them if you want.
Old Nov 16, 2011 | 04:38 AM
  #49922
Mattb16teg's Avatar
Community Builder
Well it seems it would make more sense for people who actually drive their car everyday to be at a more reasonable ride height? Wouldn't it?
My DA next to my CL:
Front lip height:
Side view or ride height with slightly larger tire:
How's the setup coming along???
Old Nov 16, 2011 | 07:31 AM
  #49923
LoL Yup!
check for broken wires would be best bet or run power source to the ecu and fuel pump and see if you can idle your car that way.
but if that works i would in no means start driving it like that
Old Nov 16, 2011 | 07:41 AM
  #49924
Mattb16teg's Avatar
Community Builder
^ looks like it is the ECU at this point. Waiting to get another known working unit to test.
Fuel pump is fine, if I jump the relay the pump primes.
Thanks for the reply.
Old Nov 16, 2011 | 08:16 AM
  #49925
DumaDA's Avatar
i used to daily drive my car and take it every where while being pretty low, just be prepared when you need to swap out an oil pan and get a new cat put on the car from scraping too much
