DA Integra's Only
Old Jul 22, 2012 | 06:45 PM
  #52401
be18see1's Avatar
Default Re: DA Integra's Only
Originally Posted by 89efhatchy
It's really simple. You just need to have a big enough fuel system for ethanol. It takes roughly 20% more fuel. You can easily create two maps if you want to run gasoline at times. Obviously this will require something to tune with, but anyone interested in using ethanol should have that taken care of.
Actually, I have a question. Do you have to make any changes to prevent degradation/rusting in the lines, tank, pump etc?
Old Jul 22, 2012 | 07:18 PM
  #52402
hb420's Avatar
I was going to ask the same about the fuel lines
Old Jul 22, 2012 | 07:19 PM
  #52403
Bond's Avatar
I know that some aftermarket pumps, filters and injectors are not for e85. OEM I have no idea
Old Jul 22, 2012 | 08:21 PM
  #52404
Kevin's Avatar
I've been running e85 in both of my DA's for years now. There are no ill effects on any of the fuel system that i've come across HOWEVER i do run aftermarket fuel pump and stainless element filter. Me and my boy built another EK coupe that used a stock fuel filter on e85 with no issues.
Old Jul 22, 2012 | 08:34 PM
  #52405
91b18a1ls's Avatar
Ok, let me hop in on this lol. Like the guy stated above me, there aren't any issues with rusting fuel lines or fuel tank. I personally have only been on e85 for a few weeks now, but I have a friend who did it on his rhd del sol sir for over 2 years without issues. As for converting, it was extremely simple and easy. I'm using dsm 450cc injectors with 10w 10ohm inline resistors, and my 20 year old stock fuel pump. I tuned it myself on crome free and i'm running roughly 50% more fuel than what the stock p30 tune had. I advanced my timing 2 degrees on the low cam and 6 on the high cam, and my car is pulling much better than it used to on 93 gas. A lot of people say you HAVE to have a bigger fuel pump, but unless you're boosted or really built it's not needed. I'm on a b16a stock internals, just full bolt ons. If I were to want to run regular gas again I would have to retune for it. Moates.net sells what's called a 2 timer, which is a thing that stacks 2 chips in your ecu and you can switch between the tunes with a switch. I'm in the process of buying a 50 shot wet kit so i'm gonna need that 2 timer. Idk if my pump will be enough for the spray as well, but i'l find out. I don't have any fancy tuning stuff either. Like I said I used crome free, I've got the Burn2 that Moates sells, and my a/f gauge, that's it. Tuning wasn't too hard just kinda touchy, but I think that was cromes fault
Old Jul 22, 2012 | 10:22 PM
  #52406
tougetuned_ef's Avatar
glad to get some insight on this. this is the first time ive actually seen it done.
Old Jul 23, 2012 | 05:26 AM
  #52407
Mattb16teg's Avatar
Community Builder
Community Influencer
It sucks for those of us who live in areas with bad winters, E85 sucks in winter time!
Old Jul 23, 2012 | 10:37 AM
  #52408
91b18a1ls's Avatar
It's a simple thing to do (as long as you or someone tunes it correctly), but it's not something I'd recommend on a daily, unless you don't mind going to the gas station more often then normal.
Yea I heard it's tough to start the car when it's cold, but yea luckily here in Texas I only have about one week in January where that might be a problem lol
Old Jul 23, 2012 | 11:33 AM
  #52409
Mattb16teg's Avatar
Community Builder
Block heater is a must! For this area at least.
Old Jul 23, 2012 | 04:37 PM
  #52410
just got an email that my fuel pump should be here by wednesday! it needs to get here quick before i start hating my car enough to just sell it and move on. thinking about a jeep cj or toyota pickup! my car is raised up a good amount and i still cant get out of my girls driveway without hitting my front tow hooks or in my driveway, must get to 3 wheel or it hits the exhaust and floor of the car! utah blows for lowered cars!!!!!!
Old Jul 23, 2012 | 06:04 PM
  #52411
DASquareOne's Avatar
Has anyone had an issue with their turn signal lights on 1 piece headlights? When i signal left the right also flashes, but not at the same time.
Im thinking it could be the DRL relay. Can anyone else input on this.
Thanks in advance
Old Jul 23, 2012 | 07:55 PM
  #52412
thedb63's Avatar
things are starting to look up i painted the bay finally and got the engine in
probably going to paint the valve cover blue
and new gas tank installed!
Old Jul 23, 2012 | 08:43 PM
  #52413
Builda'Teg_92's Avatar
^looking super dope! Nice work so far.
Old Jul 24, 2012 | 04:44 AM
  #52414
92NoTeC's Avatar
Looks boss. I've never seen the fuel pressure regulator hooked up in that manner. Can you take some close up pics?
Old Jul 24, 2012 | 07:07 AM
  #52415
Colin's Avatar
Are you going to remove that engine, clean it and reinstall? Seems pointless to paint the bay and then leave the engine with 20yrs of dirt and oxidation on it.
Old Jul 24, 2012 | 07:12 AM
  #52416
thedb63's Avatar
thanks guys....im just showing progress of my build and it will get cleaned with a toothbrush i already pressure washed 3 times......last time i painted my trans and block with alumiblast....i liked it but then i didnt so thats why im not going to paint them this time......bolts and washers will be a last thing.....the skunk 2 hardware just for the valve cover alone are 80 bucks....so looking for other options....
Old Jul 24, 2012 | 07:42 AM
  #52417
Mattb16teg's Avatar
Community Builder
Lookin good! What ITBS are those?
Old Jul 24, 2012 | 08:01 AM
  #52418
Colin's Avatar
Yeah, I'm not a fan of the painted look either. It looks good in pics most of the time, but in person it looks like crap IMO. Simple green + wire brush + steel wool + elbow grease is the best combo I've found. And if you still have some blemishes they can be touched up by applying silver/chrome paint sparingly with a paper towel (works better than it sounds like it would).
Old Jul 24, 2012 | 07:14 PM
  #52419
Lord Helmet's Avatar
Thanks in advance
I use to have that issue too. I just wired the turn lights aka city lights into parkngs lights and just used my lower bumper lights as turn signals. that solved my issues.
You can wire the bumper lights to the turn signal in the one-piece via jumper wires. Nobody will see it since it's hidden inside the bumper and behind the headlights. Both will blink when you hit the turn signal stalk.
I'm quite sure there's plenty of other ways to do it.
Old Jul 24, 2012 | 11:07 PM
  #52420
OEM92GS-R's Avatar
Sup guys, i recently picked up some work emotions for a fair price in 16x7 +44. Im curious if anyone has ran 25mm spacers on a DA? thinking about running a 25mm spacer. what do you guys think? plans, front lip, adjust my camber: rear and front toe at 0,rear camber at 0, and camber up front no more than 1. input is appreciate. thanks
Old Jul 25, 2012 | 08:43 AM
  #52421
be18see1's Avatar
I did this and it worked very well. I like it nice and natural
Old Jul 25, 2012 | 09:29 AM
  #52422
so my fuel pump finally took a **** on me. the car will start but when you touch the throttle it stalls out. pump is making a really ****ed up noise when you prime it. i think because i went up a pretty steep hill that i had to shift down to third is what finally toasted it. pump should be here today and luckily my tank is pretty low so im going to do it on the side of the road. its in a spot that is not driven on too often so it shouldnt be too bad.
Old Jul 25, 2012 | 09:35 AM
  #52423
fuel pump just came in ten min after i post that last one. maybe do it tonight
Old Jul 25, 2012 | 09:52 PM
  #52424
Bond's Avatar
Get on it! Hope it solves all your problems.
Old Jul 26, 2012 | 06:02 AM
  #52425
1ac4u2nv's Avatar
I have not posted here in a while. My bucket after installing my side skirts and OEM optional rear lip. Also added a Corbeau Forza seat.
