DA Integra's Only
Old Dec 12, 2010 | 06:14 PM
  #44726
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: DA Integra's Only
Mine is. Probably possible if you dremel the heck out of it and make it paper thin.
It just looks soo much better without the grill and all front mount!
Here's my mock up:
Turboda-1-1.jpg?t=1292210254
I had a brain fart while making the brackets for the top. I forgot the headlights would hit those 2 bars there.
Basically ended up running a bar across the top that mounts to the support.
Old Dec 12, 2010 | 07:06 PM
  #44727
DA is best's Avatar
HELP HELP HELP where can i get bolts to hold my engine on an engine stand, i tried fastenal, napa, autozone but no one has them, there the ones that connect the trans to the block but i need them about 2-3'' longer...and will three arms hold the motor? the 4th was gone when i bought it
Old Dec 12, 2010 | 07:12 PM
  #44728
OldSkoolDa91's Avatar
try lowes or home depot mabye? i find it hard to believe that fastenal couldn't dome up with something. and yes, 3 will be fine
Old Dec 12, 2010 | 08:07 PM
  #44729
Tony8174's Avatar
Heres mine still waiting for my wheels.
Old Dec 12, 2010 | 08:15 PM
  #44730
Tony8174's Avatar
<a href="http://s1183.photobucket.com/albums/x478/tony8174/Cars/?action=view&amp;current=inprogress-1.jpg" target="_blank"><img src="http://i1183.photobucket.com/albums/x478/tony8174/Cars/inprogress-1.jpg" border="0" alt="Photobucket"></a>
Old Dec 12, 2010 | 08:20 PM
  #44731
Tony8174's Avatar
Old Dec 13, 2010 | 12:08 AM
  #44732
Mattyg2's Avatar
Fresh
Old Dec 13, 2010 | 02:45 AM
  #44733
be18see1's Avatar
Matt-did you just use an eBay piping kit to run that charge piping? Was there enough in one kit to get it all done? I'm debating drilling a 3" hole in the driver's side frame rail to shorten that hot side and hopefully give me a little less lag/more throttle response.
Old Dec 13, 2010 | 04:19 AM
  #44734
Mattb16teg's Avatar
Community Builder
I used mostly the piping that came with the intercooler. I did use some random piping a buddy had because they way I wanted to run my piping. I didn't want to drill a hole there, running up and over isn't going to make a ton of difference with lag/response. NCSI is redoing his too and is just going to do it the same way as I did also.
Old Dec 13, 2010 | 07:50 AM
  #44735
donkeykongvtec's Avatar
My Old DA last burnout b4 i pulled motor, car was totaled in the picture passenger front smashed!
Old Dec 13, 2010 | 07:59 AM
  #44736
Mattb16teg's Avatar
Community Builder
^ I don't see no burnout
Old Dec 13, 2010 | 08:02 AM
  #44737
be18see1's Avatar
My tuner says best is backdoor style, next is drilling a hole, and last is up and over. I'm hesitant to drill a hole but if I make it look nice then it should be ok.
Old Dec 13, 2010 | 08:13 AM
  #44738
My buddy caught me to late, and road surface sucked too.
Old Dec 13, 2010 | 08:31 AM
  #44739
yeah sam right now i'm debating between drilling a hole or just taking my intercooler to a good welder i know of locally and having it switch it to a back door setup for me. right now i'm really leaning towards the back door set up. a lot let piping/headache to worry about. keeps things simple and clean and effective
Old Dec 13, 2010 | 08:53 AM
  #44740
Mattb16teg's Avatar
Community Builder
Eh, I mean the guy is right however it really won't make that much difference. But the headache part is right and I wish I just ran a backdoor setup.
I just didn't want to drill a hole and mess with the frame like that.
It might also be tough finding someone to weld up the IC and do a really good job on it.
I couldn't imagine going backdoor because my spool time now is super low and I couldn't imagine having all that power sooner, tires would never stop spinning!
Old Dec 13, 2010 | 09:18 AM
  #44741
im not worried about finding a welder to do it at all. i'm lucky when it comes to ANYthing i need welded. found a local guy who does amazing work with anything you take him. hell i thought about even just getting a core and having him make custom end tanks from the start. still debating
Old Dec 13, 2010 | 09:24 AM
  #44742
EFcivicJDM's Avatar
cleared my tails...and also waiting on my JDP lip
Old Dec 13, 2010 | 10:42 AM
  #44743
Mattb16teg's Avatar
Community Builder
^ Still need to do this!
Sucks because I have no garage and would want to make sure the tails are fully dried out before I put them back on.
Old Dec 13, 2010 | 10:56 AM
  #44744
88civichbz6's Avatar
I ran my setup backdoor just offset the inner cooler to the pass. side a little. I ended up with a total of 4 bend in my whole piping setup two 90's and two 45's running and with only three couplers the rest of the joints where welded. I am running a t3/t4 50trim garret turbo on a 99 gsr with xsi trans. The car is a blast to drive instant power.
Old Dec 13, 2010 | 11:31 AM
  #44745
Mattb16teg's Avatar
Community Builder
Like I said, on my LsVtec with my 60-1 I hit boost around 4 - 4500 rpm's.
That's awesome!
Old Dec 13, 2010 | 12:27 PM
  #44746
EFcivicJDM's Avatar
anyone know any metallic brown/gold colour codes...like the rootbeer colour but not house of kolor??
or even what cars i came on
Old Dec 13, 2010 | 12:36 PM
  #44747
Mattb16teg's Avatar
Community Builder
New Elements, maybe YR-569M
Old Dec 13, 2010 | 12:51 PM
  #44748
uses0ap's Avatar
Old Dec 13, 2010 | 01:03 PM
  #44749
Bond's Avatar
efcivic: tails look much better. When I did mine I spent awhile with the gf hair dryer to get them bone dry. I think it helped a little.
I'm going to do my driver side piping through the rail. My buddy is an amazing welder and he offered to step in and do it. So we are going to give it a try. I think the main thing is going to be making sure it's fully welded on both sides of the frame as to not weaken it. I hope it works out ok.
Old Dec 13, 2010 | 02:07 PM
  #44750
be18see1's Avatar
I'm not welding anything to my rail? That part of the car doesn't really play into rigidity enough for it to matter to me.
