DA Integra's Only
Old Apr 25, 2011 | 01:53 PM
  #47126
g2_teg_'s Avatar
Default Re: DA Integra's Only
Originally Posted by Mattb16teg
It is possible and it happens yet if you knew more about the specific subject you would know things like these types of tubular manifold crack all the time, no matter what the application or power level. Hell poor Dave has had tons of issues with his manifold cracking and it's a PeakBoost unit. Just another pay to play item, sure you could get a cast manifold which will take longer to crack and not flow as much air as the tubular unit.
Rings are also a finite part and wear out, nothing "blew out", it's only common sense to replace them now while everything is apart.
And cracked blocks happen to everyone pushing their setup, that's why people started the sleeving process.....
You're getting me confused with the guys who said the car wasn't built right. i never denied that. I know those manifolds crack, i knew about Dave's cracking forever ago.
Its my belief that even a turbo honda built right will have failures. You either proved this or you didn't build it right. I believe it was built correctly. But you are not the only one that has proved my theory. I understand that these issues are common among FI cars.
Old Apr 25, 2011 | 02:01 PM
  #47127
g2_teg_'s Avatar
It has because the dyno is a tuning device which simulates driving it on the road. LoL, again with some type of pot shot, please tell me how driving a car on the dyno and pushing it isn't the same as pushing it on the road.
I built my current car to drive it. It's a lot more fun on the road then on the dyno.
And from the items you've brought up I figured you would realize that tuning a simple "all motor" setup isn't as involved as tuning a turbo car. There are tons of settings and adjustments to make and since I've had access to the dyno I'm taking advantage of it while I can.
this is all true.
Old Apr 25, 2011 | 02:05 PM
  #47128
g2_teg_'s Avatar
Also you being on the highway and hitting mad Vtak isn't really 100% comparable to making passes at a track. But again, we get it, much like others you don't drag race and your car is puuuuuuuuuuuuurfect.
hold on now. I never hit vtec on the highway unless im speeding and hit it in 5th. When i hit 8-9000 rpm its exiting a 35 mph turn. This happens 80 times a day once a week. That is comparable beating that a car takes at a track. In fact I would say that driving hard for 12 seconds, and then letting the car sit for a half hour is much less beating.
Old Apr 25, 2011 | 03:27 PM
  #47129
tougetuned_ef's Avatar
i need a little help guys. i went down to my garage just a min ago and i got hit with the smell of gas! i looked in my bay and the fuel line coming thru the firewall that was taped with blue masking tape was soaked with fuel and the floor was soaked also. so i opened the doors to the garage and then opened the gas cap and there was a ton of back pressure. should i just leave the cap off to keep this from happening? it has been very humid for the past day.
Old Apr 25, 2011 | 04:43 PM
  #47130
hondahead_dave's Avatar
Hey Matt, I was just watching this show, and you know who you look like? prince William, lol.
Old Apr 25, 2011 | 05:18 PM
  #47131
be18see1's Avatar
Old Apr 25, 2011 | 05:22 PM
  #47132
Damn hommie, coming along real good.
Old Apr 25, 2011 | 06:12 PM
  #47133
Mattb16teg's Avatar
Community Builder
Community Influencer
like the 20th time I've heard it this month.
Guess it's a good thing.
Originally Posted by be18see1
Looking good, sorry I insulted your manifold
Old Apr 25, 2011 | 06:13 PM
  #47134
Mattb16teg's Avatar
Community Builder
Picked up my new block tonight.
Old Apr 25, 2011 | 06:15 PM
  #47135
evrythng_fast's Avatar
i have a b18 1.8l dohc that im turboing and im trying to figure out if i need to sleeve it and get bigger pistons im only going to be driving it maybe 2 times a week and need to know if i can run 14psi on the stock block and it all be okay? ive changed too single 2core radiator, cam gears timming belt, fuel rail, chip ecu and fuel pump what do you think if you could help me out anyone???
Old Apr 25, 2011 | 07:49 PM
  #47136
tegman23's Avatar
that bay looks good, but ebay ftl. not hating cause i had one but its going to break so just watch you dont mess somthing else up
Old Apr 25, 2011 | 08:00 PM
  #47137
Bond's Avatar
Guys, has anyone used an Ls crank and rods in a GSR block?
I'm just looking for people that have had experience with it.
There a few minor things in the process that I'm curious about.
Bond, how are you going to route your dump tube?
Well if you creep my build thread from looking at the pictures I posted basically straight out towards the rad then a 90 across (horizontal) to kick it towards the motor then a 45 type of bend and then straight down. Keep it even with the bottom of the traction bar and right behind it. Sort of snake it between the rad and then between the manifold and rad support/ traction bar. Going to be a real squiggly one haha. But at 60mm it shouldn't hurt flow hehe. I think that makes sense??? lol
Take some pics of your motor going together. I need something interesting to look at
Old Apr 25, 2011 | 08:49 PM
  #47138
OldSkoolDa91's Avatar
I drove one and it's a turd. Handling isn't so great either. I was left unimpressed. Not to be a Debbie Downer but I just don't have the affection for the H badge like I used to or like a lot of you guys obviously do. My next vehicle will be a Nissan, Datsun, or RX7 with an LS swap.
noooo ls in the 7. i cant stand when guys put ls swaps in rx7's or 240s
jj its not an ebay manifold. it looks like one, but its some oldskool mani, i forget the name. he said its actually pretty stout
Old Apr 25, 2011 | 09:05 PM
  #47139
hb420's Avatar
That's strange my fuel line at the firewall has been dissconected for over a year and that has never happened.
Old Apr 25, 2011 | 10:56 PM
  #47140
bonspeed's Avatar
hey guys, can anyone tell me what this plug behind the block is for?.. It's the green with two terminals above the oil sending unit.. sorry noob here..
Old Apr 26, 2011 | 12:06 AM
  #47141
be18see1's Avatar
Fan switch.
Old Apr 26, 2011 | 12:07 AM
  #47142
be18see1's Avatar
It's not eBay. It's from a shop that used to be in MI called Payne Technologies. It's from 2002 and has never required rewelding and the last car it was on made 400 whp.
Old Apr 26, 2011 | 04:11 AM
  #47143
Mattb16teg's Avatar
Community Builder
Go check out the Forced Induction forum, there is an FAQ which will list everything you need.
Sleeving all depends on your goals and wallet. If you can't afford to sleeve the motor (about $3k) then stock sleeves will hold for moderate power.
14psi is all relative to the turbo so it really depends.
Good luck!
Old Apr 26, 2011 | 04:42 AM
  #47144
EFcivicJDM's Avatar
just picked up 1st place in show and shine at showerks live here in ireland delighted
heres a link to pics of the day
http://www.ilovebass.co.uk/photo/showerks-live
Old Apr 26, 2011 | 06:02 AM
  #47145
be18see1's Avatar
Good luck!
3k? It can be done for 1.5 - 2 k. $600 for the sleeves and maybe $800 to $1k for the install.
edit-
check out this price!
http://www.rlengines.com/Web_Pages/D...tallation.html
Old Apr 26, 2011 | 06:06 AM
  #47146
Mattb16teg's Avatar
Community Builder
I meant for everything, sleeves, pistons, rods, etc.
Old Apr 26, 2011 | 08:18 AM
  #47147
be18see1's Avatar
Ah ok. Then yep!
Old Apr 26, 2011 | 09:22 AM
  #47148
Mattb16teg's Avatar
Community Builder
Ah ok. Then yep!
Just tried to justify spending that much on my motor but can't with buying a house in the next 8 months or so and a wedding coming up next year too.
Old Apr 26, 2011 | 09:30 AM
  #47149
be18see1's Avatar
What if you reuse the internals you have right now?
Old Apr 26, 2011 | 09:37 AM
  #47150
DumaDA's Avatar
congrats EFcivicJDM, your da deserves it
