DA Integra's Only
Old May 10, 2011 | 04:25 PM
  #47376
be18see1's Avatar
Default Re: DA Integra's Only
Originally Posted by 95-db6-719
i would check fuel pressure like i stated, and make sure to use a spark tester or make a spark tester when you test spark(it should be able to jump 150 thousandths((the gap on a spark tester)), if it does the spark is strong. You might seem to have a healthy spark, but thats the rule out everything test for spark.
Its either spark or fuel, with both, no matter what it will at least try and run, might not run well or might want to try and die on you but the ecu should try and correct for what ever reason it assumes is wrong ie. fail safe mode.
also important sensors to check, MAP, TP, IAT. make sure the signal is correct and to spec.
other than those man, i cant really think of why you would be having this problem with good compression.
I'm not too sure either. All of the major sensors are reading fine and I can monitor them through my datalogging software.
Old May 10, 2011 | 04:29 PM
  #47377
95-db6-719's Avatar
yeah man thats wierd, like i said it has to be something, with the spark or fuel.
Old May 10, 2011 | 06:13 PM
  #47378
tougetuned_ef's Avatar
so i bought that blue da on the last page that was for sale and im baffled as to why it wont start. i replaced with known working parts, dizzy, wires, plugs, ecu and main relay and im not getting spark or fuel. any suggestions. the car is about 60 miles away so if i cant figure it out im getting it towed when my aaa kicks in on the free 100 mile tow. next tuesday.
the car is basicly stock. has b18b, crap exhaust and thats about it. its an rs, motor has 60-70k on it and shell has 209k. i checked spark with a spare lug in the end of a plug wire. im about to rent a uhaul truck to get it home if i have to.
Old May 10, 2011 | 09:51 PM
  #47379
tegtuner01's Avatar
i hate how i cant get any help on this thread unless i'm having turbo issues..
Old May 10, 2011 | 10:49 PM
  #47380
Ef9vsDa9's Avatar
drive down to s.a i know a place that will pass you and they dont charge extra,
15 bux flate
Old May 10, 2011 | 11:03 PM
  #47381
tegtuner01's Avatar
15 bux flate
yeah but i need to be inspected in the county my title is registered in...
Old May 10, 2011 | 11:40 PM
  #47382
OldskoojdmDA9's Avatar
Originally Posted by MaltBeer
Thanks! But I just have the front and sides haven't come across the rear yet.
Sure thing man I know a clean teg when I see one. From the looks of it, you have all three pieces for the side skirts as well! Finding the sides, fender caps and door inserts are a royal pain.
As for a rear lip, there's one for sale on G2iC! It could use a little love, but hey it's something and it's cheap. Check it out.
http://forums.g2ic.com/showthread.ph...-Optional-Rear
Old May 11, 2011 | 12:23 AM
  #47383
oemda's Avatar
anyone know if DA front shocks and EF and CRX shocks are the same, i got a box of KYB AGX brand new fronts and was gonna use them. but guess they dont fit newer civics(silly me thought all that was the same, guess not).
if anyone might be interested in them i ll let them go for 175 plus shipping.
The front shocks should definately be the same because Im running one from a CRX.
Old May 11, 2011 | 03:17 AM
  #47384
be18see1's Avatar
Some of us can't help you because we don't have to do any of that emissions stuff. Actually, I would venture to say MOST of us can't. Lots of guys from PA and the east coast. I'm from OH so nothing here like that here either.
Old May 11, 2011 | 04:34 AM
  #47385
Mattb16teg's Avatar
Community Builder
Community Influencer
What is your issue exactly?
it's due to noise that I even have a muffler
Hmmmm, your issue is baffling!
What EMS do you have, log a startup and post it up somewhere. If it's hondata I can help you.
Old May 11, 2011 | 05:20 AM
  #47386
be18see1's Avatar
I have 4.5' of 3' straight pipe to a turn down. It's gonna be a little loud..
I'm running Neptune RTP. I'm not 100% on how to save a datalog but I can try to tinker with it tonight. I'm still a beginner on the tuning aspect.
Old May 11, 2011 | 05:34 AM
  #47387
Mattb16teg's Avatar
Community Builder
4.5??!? Down pipe?!
I'd say log a start up, save it and load it somewhere and share it on the tuning section. People may be able to help.
Old May 11, 2011 | 06:03 AM
  #47388
Ef9vsDa9's Avatar
huh? you are not making any sense
Old May 11, 2011 | 07:31 AM
  #47389
be18see1's Avatar
4.5??!? Down pipe?!
downpipe thhheeen 4.5' of straight pipe. it sounds sick when I'm trying to start my car...
Just found that I think I have Delphi injectors and not Bosch injectors. That means I actually have injectors rated at 2 ohms and not 2.2 ohms. After talking with..Chris?...of HR Tuning, he says that could definitely be contributing to the problem and that I will need to tweak fuel. Hopefully that's all there is to it!
Old May 11, 2011 | 07:48 AM
  #47390
OldSkoolDa91's Avatar
have you tried putting your stock ecu back in and trying to start it like that? i've seen it happen before where modded ecu's have random problems n wont start a car, but as soon a stock ecu is put back in, bam, starts right up
Old May 11, 2011 | 09:11 AM
  #47391
be18see1's Avatar
I don't have a stock ecu. Plus I have 1000cc injectors so I doubt it would have started anyways.
Old May 11, 2011 | 09:35 AM
  #47392
95-db6-719's Avatar
your breaking it in NA right..?
Old May 11, 2011 | 09:52 AM
  #47393
Mattb16teg's Avatar
Community Builder
Hmm, Ohm the injectors out.
Andy has a point, has this ECU been used on a running car before and worked without issue?
With 1000s it would have started, ran pig rich, smoked a lot then stalled out lol!
He doesn't need to break it in N/A. As long as he doesn't hit boost it's the same thing.
Besides, start it up, let it reach operating temperature/run for a bout 15 minutes. Change oil and voile, dyno time and rings are set!
Old May 11, 2011 | 09:57 AM
  #47394
be18see1's Avatar
I'm not breaking it in at all. It already ran in another car with a very similar setup to mine. The ECU has never been used in a car besides mine since I have owned it.
Old May 11, 2011 | 09:59 AM
  #47395
be18see1's Avatar
Already did ohm them out and got 2.1 ish ohms with a flaky multimeter from Harbor Freight.
Old May 11, 2011 | 10:29 AM
  #47396
Mattb16teg's Avatar
Community Builder
Wait so the motor is used and you didn't rebuild it?
So the ECU did work in your car before the build?
LOL, sucks when your looking for 2 or 2.2.
Old May 11, 2011 | 10:49 AM
  #47397
be18see1's Avatar
No it was in my friends car that he parted out to buy a house. It ran great before that. It was built by "the" shop for Hondas in central Ohio. I have no concerns with the motor whatsoever. The ECU is completely new to me. New to me P28 with a new RTP unit installed.
Old May 11, 2011 | 11:01 AM
  #47398
Mattb16teg's Avatar
Community Builder
Hmmm, find a car to throw that ecu in and vice versa.
Old May 11, 2011 | 11:33 AM
  #47399
be18see1's Avatar
ughhhhhhhhhhhhh
Old May 11, 2011 | 11:48 AM
  #47400
Mattb16teg's Avatar
Community Builder
it sucks but will be very helpful in your trouble shooting.
