DA Integra's Only
Old Apr 14, 2011 | 08:03 AM
  #46901
be18see1's Avatar
Default Re: DA Integra's Only
Originally Posted by Mattb16teg
Are you not planning on getting it on the dyno. IMO I would not waste any money on a street tune for a turbo car! When I got my car running I threw together a base map to get it drivable and drove it right to the dyno.
I know how you feel with the dump tube, it's a pain. Whats the positioning of your WG look like and where does it sit?
I have a ram horn so mine sits straight out under the support, next to the radiator.
So basically I have to make a very tight turn off the WG, go over the DP and down, this was my old dump tube:
However I used crappy material and it broke off. I just ordered a vibrant 90 degree bend and stainless flange to have another one made.
It will get dyno-tuned later this summer but initially it will be street tune only. Tuner is $75/hour including cost of dyno so I'm willing to wait a bit to get it. Go back a page or two and you can see my bay. Wastegate sticks out to the pass. side and aims directly at the rad support. Such a pain in the dick. I might go up and over turbo to driver side and run it down over there but I'm not sure how this will affect the exhaust flow into and out of the wastegate. UGH. I can't see hosted pics from my work pc but I will definitely check yours out tonight.
Originally Posted by OldSkoolDa91
my daughter is 3 years old today. i dont where the time went, but it went by waaay too fast!!
Congrats Andy!
Old Apr 14, 2011 | 10:50 AM
  #46902
Mattb16teg's Avatar
Community Builder
Community Influencer
Congrats man!
Any big plans?
So then you are going to drive around and beat it up?
I would advise against it, you've been putting in work on this motor and street tunes aren't exactly the greatest.
Think about it, tuner makes a base map, goes out and beats up the car while doing datalogs, he's gotta pull over somewhere make adjustments and repeat the process. This isn't safe for him or your car and it would take forever for an accurate tune. That's why most street tunes are thrown together.
Good luck though!
and for your WG, they make adapter plates that you can clock the WG, I've seen them before and look like a big cross or just cut the flange and reweld it so you can fit a dump tube in there.
They also make elbows but I figured that won't work as you can't get a dump tube in there.
Why not just rotate it so it faces the other way, should be room there, right?
Old Apr 14, 2011 | 11:08 AM
  #46903
Mattb16teg's Avatar
Community Builder
and man I never thought of how much of a pain the flange on the 38 could be, I'm sooo glad the 44mm is Vband!!!!! WOOO HOOOO!!
If you look right to the left of my drivers side headlight you will see my black 44 WG. There really weren't many options for me either as it sits right near the radiator and on the other side is my IC piping.
I wouldn't even think or rotating it up as that would most likely lead to creeping.
Old Apr 14, 2011 | 12:22 PM
  #46904
DA93teg87's Avatar
Just started working on the new project. Going to take alot of effort and time, but I refuse to let my DA go the the junkyard!!! Just picked up some quarters from a donor car. And working on an all motor GSR swap. Got alot of work ahead of me. Will be worth it in the end. The engine bay is pretty much stripped down almost ready for paint.
Old Apr 14, 2011 | 12:42 PM
  #46905
be18see1's Avatar
doesn't look quite ready for paint to me but neverless props on restoring it.
Old Apr 14, 2011 | 12:59 PM
  #46906
be18see1's Avatar
Congrats man!
Any big plans?
Good luck though!
As for the dump tube, I can fit something in there no problem, I just don't know where I want to dump it to.
As for the street tune, I'm driving while my tuner tweaks the base tune. He's just getting me rolling on this tune so I can drive it down to Cinci where the dyno he's a part owner of is. I'm not going to be ripping on it and tearing my hard work up FOR SURE. I mean, at some point I'm going to want to give it a little WOT but for the most part, I'm going to treat her right. I have a Moates Demon + Neptune RPT so you can actually just make changes on the fly and it immediately updates the maps. I just want to be rolling before a big meet on May 14 that I sort of want to unveil the car to my friends at.
Old Apr 14, 2011 | 01:18 PM
  #46907
DA93teg87's Avatar
Yeah still have alot to do. Focusing mainly on the engine right now. 84mm all motor gsr. Just got a few gifts from the ups man Wiseco 14.2:1 Compression pistons, Manley H-Beam rods, Type R Oil Pump, Gates Timing Belt, and Golden Eagle Headgasket.
Old Apr 14, 2011 | 02:27 PM
  #46908
Mattb16teg's Avatar
Community Builder
Oh, just go straight down. When the car is moving it will just blow under the car.
Yea you can make changes on the fly with most tuning software however you need at least 2 capable people to do so. Otherwise you will have to pull over and review logs and make changes every pull. Which sucks.
Holy compression, guess you plan to make this a drag car and only run on Race gas, ie. 110 or so?
If not then there is no need for all that compression because you will have to detune it to make it practical and run properly on 93 octane.
Old Apr 14, 2011 | 03:29 PM
  #46909
DA93teg87's Avatar
Checked it with the compression calculator. Actual compression I'll get is 13.4:1. And I'll be running on e85. Should turn out pretty insane lol
Old Apr 14, 2011 | 03:45 PM
  #46910
91-lsvtecsi's Avatar
Old Apr 14, 2011 | 03:49 PM
  #46911
lmao @ my mom in the background!
Old Apr 14, 2011 | 03:54 PM
  #46912
NastyDB8's Avatar
Nice ride bro...at least she's matching your ride
Old Apr 14, 2011 | 03:59 PM
  #46913
Thanks dude!!! lol
Old Apr 14, 2011 | 06:25 PM
  #46914
Mattb16teg's Avatar
Community Builder
Thick Head gasket?!
I wouldn't trust those things to be 100%, all depends which one you use I suppose.
Old Apr 14, 2011 | 06:43 PM
  #46915
DA93teg87's Avatar
Thick Head gasket?!
Using a Golden Eagle headgasket at .029". Wanted a Cometic .040" but I couldn't find one for 84.5mm bore. I used the c-speedracing calculator.
Old Apr 14, 2011 | 07:41 PM
  #46916
OldSkoolDa91's Avatar
Congrats Andy!
thanks sam
Congrats man!
Any big plans?
thanks man. i took her to the store n let her pick out an ice cream cake and then brought her home and gave her her gifts. didn't get too much time with her unfortunately cuz i had to work 4-10. her mother is having a big party for her on saturday so i took off work for that and then i plan on taking her along to honda day on sunday. shes def my kid cuz she loves cars and watching drag racing!!!
holy freakin dome!
so is it 84mm or 84.5mm? sleeved block?
Old Apr 14, 2011 | 08:16 PM
  #46917
DA93teg87's Avatar
thanks sam
holy freakin dome!
It's an 8.25cc Dome lol and its an 84mm Sleeved Block. My builder told me to go .5mm over not sure why. But with his 15 years experience I'm taking his word for it.
Old Apr 15, 2011 | 01:52 AM
  #46918
be18see1's Avatar
Cool. That makes my life a lot easier then. One 90 and a slashcut tube and I'm done. Hopefully it doesn't dirty up my bay too much because I spent a lot of time cleaning haha. I wasn't sure if I had to dump it under the pan or if in front was fine.
Old Apr 15, 2011 | 04:22 AM
  #46919
Mattb16teg's Avatar
Community Builder
haha nah, a slash cut should do it!
It shouldn't blow back up because the air running under the car will push it on its way.
I wouldn't extend it up and under because what it you hit something, that will be a lot of stress on the pipe and manifold.
Car goes back on the dyno tomorrow!!!!!!!!!!!
Lost of small changes since the last time:
Old Apr 15, 2011 | 07:25 AM
  #46920
be18see1's Avatar
excited to see what numbers you put down! How many psi were you running when you got your last tune that made 410 whp?
Old Apr 15, 2011 | 02:52 PM
  #46921
tougetuned_ef's Avatar
does anybody have an obd1 b16 ecu they want to sell? i want to put my b16 in the car soon and thats the remaining piece to the puzzle. i just picked up an obd1 intake mani for $40 from my buddy today. and also, the motor is out of a 00'si and i have the original harness already connected to it. do you think it would be easier to run with that harness and get an obd2 to obd1 conversion harness or just use the da harness and wire in the vtec and knock sensor wiring? i like everythink to look bone stock and i dont really want to touch this obd2 harness to steal plugs from it.
Old Apr 15, 2011 | 03:17 PM
  #46922
be18see1's Avatar
wire it in yourself. it takes $10 and 30 minutes. use shielded wire for the knock if you can.
Old Apr 15, 2011 | 04:25 PM
  #46923
kilerintegra's Avatar
Whats up DA squad. Its been awhile since i been in the da world but i just picked up a 92 gs teg. Ready to start wire tuck, 5 lug conversion, and k swap, im excited.... imma do a write up thread soon as i start the project. Oh the dude with the blue DA on the dyno that thing looks sweet.
Just wanted to show the DA owners love
Old Apr 15, 2011 | 04:52 PM
  #46924
Mattyg2's Avatar
Looks like you're going to build an internet car. I hope you're going to atleast put some legend/typeR calipers on with the 5 lug.
Old Apr 15, 2011 | 05:15 PM
  #46925
Im using the type r 5 lug set up there is a whole write up on it. The rear bolts right up and the front just needs the hubs machined to fit the da wheel bearings
