DA Integra's Only
Old Jul 6, 2011 | 09:54 AM
  #48151
ncsi's Avatar
Default Re: DA Integra's Only
Yea thanks matt!
also did obd2 oil pump,ngk plugs, energy bushings, ef steering rack, boost by gear solenoid, mickey street ets, converted speed sensor to electronic, oil pan and dp gasket, rear camber kit and fresh fluids everywhere
Old Jul 6, 2011 | 09:56 AM
  #48152
DumaDA's Avatar
ncsi your car is dope, makes me miss my old da
Old Jul 6, 2011 | 10:03 AM
  #48153
ncsi's Avatar
Thanks man!
Old Jul 6, 2011 | 10:17 AM
  #48154
90HondaDA's Avatar
ncsi how to like the RD1 as your cluster? Debating doing cluster for my rd1
Old Jul 6, 2011 | 10:23 AM
  #48155
Mattyg2's Avatar
I'm jealous of all your cars running. Mine is still sitting down with a broke clutch.
Old Jul 6, 2011 | 10:27 AM
  #48156
DumaDA's Avatar
i thought you replaced it with another clutch already?
Old Jul 6, 2011 | 10:28 AM
  #48157
Mattb16teg's Avatar
Community Builder
Community Influencer
Matty, did you hold of fixing it because it would have been a waste of time with that clutch?
Old Jul 6, 2011 | 11:43 AM
  #48158
ncsi's Avatar
I haven't drove the car yet its still being reassembled
Old Jul 6, 2011 | 11:46 AM
  #48159
Mattb16teg's Avatar
Community Builder
Still waiting on a dump tube to be made and for it to go back on the dyno. It runs and drives nicely though!
Old Jul 6, 2011 | 01:05 PM
  #48160
hb420's Avatar
I might start pulling the motor out to get it rebuilt and to get it ready for when i get the brakeline tuck done. I really want to boost the teg since it rarely will be driven. So i figure if i save some extra cash and visit pa every other month for a few days to work on it i should have it done by next spring. I'll be here until wed so i should be able to get a few things taken out. Throwback pic
Old Jul 6, 2011 | 01:23 PM
  #48161
DumaDA's Avatar
do it, go boost, that would be dope, if you piece together a decent kit you could probably install it in a day no problem and just throw on a base map till you can tune
Old Jul 6, 2011 | 02:03 PM
  #48162
EFcivicJDM's Avatar
anyone know of a decent ITB setup for a obd0 B16A?
new to the whole ITB thing ha
its for my da6 need to know what ecu to run,fuel pump etc
thanks
Old Jul 6, 2011 | 02:06 PM
  #48163
OldskoojdmDA9's Avatar
Originally Posted by Snazzy95eg8
oldschooljdmda9 ur car is amazing.......love it
Thanks homie, same with yours. Those starks are looking super fresh! That last pic you posted is my favorite of them all, had to re-post it to the new page
Old Jul 6, 2011 | 02:24 PM
  #48164
Mattb16teg's Avatar
Community Builder
thanks
Honestly, why ITBS?
Whats the purpose of the car and why did you pick ITBS?
I would recommend going with a good manifold, throttle body and intake setup. Can be cheaper and make better power or similar power to ITBS.
Give me some specs on the motor and I can help.
Old Jul 6, 2011 | 02:46 PM
  #48165
EFcivicJDM's Avatar
Originally Posted by Mattb16teg
Honestly, why ITBS?
the engine spec is at the end of this feature
http://speedhunters.com/archive/2011...a-dreamin.aspx
mainly cause of the wire tuck id love polished ITBs but i wouldnt mind a wrinkle black intake?mabye skunk?i honestly dont know?
car will be a show car/weekend car.odd track day?..so be nice to have the power there if i need it
what you reccomend thanks
Old Jul 6, 2011 | 03:46 PM
  #48166
Mattyg2's Avatar
No, I'm putting the clutch in that I bought from ebay. I just haven't started it yet because I was doing other things and working on everyone else's cars and waiting for 4th of July to pass. Going to be starting on it today. I'm doing a YS1 build soon anyways so it doesn't matter. Just need the car running so I can drive and do the track event later this month.
Old Jul 6, 2011 | 03:56 PM
  #48167
Mattb16teg's Avatar
Community Builder
Ah, didn't realize it was you.
Honestly for a stock B16, from a performance standpoint I would stick with what I mentioned and not ITBS. But if you're into the whole show thing I guess it will look cooler. At the end of the day it's your call.
If you do pick ITBS at least choose TWM, TODA or Jenvey.
Again for a stock B16 A skunk 2 would be sufficient, you could just paint it to match your preference. I like the Omni cast throttle bodies(less issues with them such as sticking), a 68mm will be fine, and a 2.5 inch pipe with a velocity stack kit on the end.
I also like the edelbrock performer X for all motor cars, I haven't seen any tests of that mani of a B16 but on mild GSRs it out performed all other manifolds.
Nice man, get to work!
What YS1?
Old Jul 6, 2011 | 04:10 PM
  #48168
Mattyg2's Avatar
I'm trying to get a YS1 that's literally down the street form me but the guy is laggin like a **** and it's super clean.
Old Jul 6, 2011 | 04:15 PM
  #48169
ncsi's Avatar
Little bit better pic with my cracked finish panelName:  2011-07-06_20-07-16_232.jpg
Old Jul 6, 2011 | 04:18 PM
  #48170
DumaDA's Avatar
is it a gsr or b16 trans?
Old Jul 6, 2011 | 04:30 PM
  #48171
Mattyg2's Avatar
It's going to be a regular LS long geared, but I'm building it with type r gearing and type r final drive with type r lsd.
Old Jul 6, 2011 | 04:32 PM
  #48172
DumaDA's Avatar
so why dont you just pick up a bare casing since you're switching everything out anyways
Old Jul 6, 2011 | 04:42 PM
  #48173
Mattyg2's Avatar
Because I just want everything intact as if it wasn't messed with.
Old Jul 6, 2011 | 04:50 PM
  #48174
DumaDA's Avatar
so why did you choose type R vs gsr or b16 gearing, i would think with autox the short b16 gears would be perfect
Old Jul 6, 2011 | 04:56 PM
  #48175
da9leo's Avatar
I <3 DA's
If i ever get rid of my treasures matt you'll be the first to know
