DA Integra's Only
Old Apr 17, 2011 | 11:58 AM
  #46951
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: DA Integra's Only
and as also mentioned, I've had problems with components inside my distributor and with my turbo manifold.
Again, the distributor is one of those maintenance parts, things fail in distributors. And again, an OEM piece.
The manifold broke, it sucks and ever the nest of manifolds crack and have issues. That's the only thing I could see as being an issue due to the part selection but as I mentioned it happens. I mean I could brace the crap out of it if I really cared that much and that MAY help.
Old Apr 17, 2011 | 12:02 PM
  #46952
be18see1's Avatar
Originally Posted by Mattyg2
Not really. If it's built right it wouldn't have so many problems.
This is what I was talking about before.
Old Apr 17, 2011 | 01:17 PM
  #46953
MONTE EF's Avatar
What Lip is on that Black DA in Mattyg2's pic.
Old Apr 17, 2011 | 02:29 PM
  #46954
tougetuned_ef's Avatar
hey guys. i just picked up an obd1 jdm b16 intake mani from my buddy and wanted to get it mounted up to my b16 and when i took the obd2 intake mani off the motor i went to swap the iacv over and the holes dont line up. i then check the obd2 iacv with my ls one and they are the same. i then went onto an acura parts catalog to compare the iacv from a b17 with the ls and they look the same. im baffled as to what iacv i need to use to run this manifold. the obd2 one doesnt have an intake air temp sensor port on it and i dont want to have to drill and tap on in if i dont have to. oh and i did search for the answer and didnt find it obviously.
Old Apr 17, 2011 | 02:44 PM
  #46955
g2_teg_'s Avatar
Sorry dude, I just thought I noticed a bunch of big problems with the car lately. I'm sure its built right. But, on.another note, I would consider oil pump failure critical. That's pretty serious and even over 6 years I wouldn't expect it to break.
Old Apr 17, 2011 | 02:45 PM
  #46956
Bond's Avatar
Agreed, not really sure why you got to ride EVERYONE.
Matt your pump failing is not a result of how it was built. I'm sure you have everything balanced and you never ran low on oil. Unfortunately you really have zero control over a failure like this as the obvious precautions had already been taken. Aside from maybe an oil cooler (no idea if you have one) it really is a wear item. It's not a stock motor and something like this can easily be seen as a replacement item.
Correct precautions IMO would be:
-Fully balance motor (including flywheel, dampener, pressure plate, and rotating assembly)
-Oil cooler (to keep oil temps down and from oil breaking down as easily)
-Good oil filter (to many anti drain back valves don't work and cause dry start ups)
-Correct oil level and type (talking weight and correct level. Synthetic and non or not huge factors when the oil is changed often)
-Correct bearing clearance
I'd love to see how you could have done more to prevent this from happening as I doubt yours was slapped together. I'm sure you have atleast 4 out of 5 I listed.
Old Apr 17, 2011 | 05:13 PM
  #46957
BMXVTEC's Avatar
hey guys...i just want some thoughts on exhaust systems cause i cant seem to make up my mind! I'm pretty sure everyone wants that sound where its deep and not raspy what so ever which is also what i'm looking for. What opinions do you guys have on any of them? I was thinking, greddy ti-c, rs-r exmag, obx-r..from youtube videos they sound good..but has anyone heard these in person or any other systems that sound good with out getting pulled over lol
Old Apr 17, 2011 | 05:20 PM
  #46958
90HondaDA's Avatar
Hey guys enter you pics to PW JDM contest on facebook.
Here's my pic, like please fellas, and i'll do the same.
http://www.facebook.com/photo.php?fb...type=1&theater
Old Apr 17, 2011 | 05:24 PM
  #46959
hb420's Avatar
I had a few thermal exhuast's and they aren't to loud and sound good
Old Apr 17, 2011 | 05:33 PM
  #46960
BMXVTEC's Avatar
i had some exhaust system on it...never new the name but it sound mad nice...not loud at all deep sound...but it came on the car lol so never new the name didnt really bother to ask the guy before me...then that broke off thanks to nyc streets ...then had a flow master it was ok but raspy n couldnt take it anymore...then just put a vibrant muffler but way to loud at high rpms!!!! i couldnt take it lol...at low rpms its alright but i want a nice exhaust system. not alot of da's over here to hear from so i cant seem to make up my mind
Old Apr 17, 2011 | 07:01 PM
  #46961
Mattb16teg's Avatar
Community Builder
Yea but it was in a contained environment and luckily I have an oil pressure gauge.
Ehh actually for the use it's seen I don't see how it lasted this long.
LoL, if anything oils always been a tab over filled.
And everything on your list except the cooler, so 4 out of 5.
Motors been running fine for 3 years on this current build. Built it before I got the turbo setup on it.
Dave has one, sounds good to me. He may have vids.
Old Apr 18, 2011 | 02:55 AM
  #46962
hondahead_dave's Avatar
yea I have a little vid, but I really want to get a video with someone in another car and me going through gears, hee is my only vid.....
http://www.youtube.com/watch?v=KVHlu0NWJvQ
Old Apr 18, 2011 | 03:16 AM
  #46963
DA9_DAD's Avatar
Hey guys and ladies. I hardly post on H-T, didn't even know this little thread even existed. So I thought I'd share some pics with you of my lil daily. She's very rough and needs a lot of work, so don't hate. Just know that in a few mo's time many things will be changing on her.
Gonna start from the beginning with the pics and then progress to today. Changes though are very subtle...mainly with wheels.
enjoy
First set is ATECH Weapons
Second Set is Enkei RP-02
Third Set is Konig Kaiten
Fourth set is Vesta Sebring Sprint by RAYS Engineering
Old Apr 18, 2011 | 03:17 AM
  #46964
DA9_DAD's Avatar
Fifth set is ASSO A701 Same mfg as the Regamaster only these were made in Japan.
Finally how she sits.
Sixth set is Volk Racing Fortesst 2 Group AV
Old Apr 18, 2011 | 06:36 AM
  #46965
Mattb16teg's Avatar
Community Builder
Old Apr 18, 2011 | 06:41 AM
  #46966
Mattb16teg's Avatar
Community Builder
Old Apr 18, 2011 | 09:16 AM
  #46967
OldSkoolDa91's Avatar
that first pic is awesome matt
Old Apr 18, 2011 | 10:12 AM
  #46968
Mattb16teg's Avatar
Community Builder
That type of stuff is why we are all here!!!!
Old Apr 18, 2011 | 10:43 AM
  #46969
i really wish i coulda been involved in "the scene" back in the day when it was really starting to kick off. would have been soo much fun
Old Apr 18, 2011 | 10:21 PM
  #46970
tegman23's Avatar
My fs thread, some da parts
http://www.hondamarketplace.com/show...2#post45102072
Andy I think it would of been fun to be there too,but I bet alot of headaches, they prob broke alot I would think with all the different things they tried
Old Apr 19, 2011 | 12:13 AM
  #46971
Mattyg2's Avatar
enjoy
I'm still running the Enkei RP02's , you make me want to hurry and lower my car more. Do you still have the front oem optional lip?
Old Apr 19, 2011 | 04:52 AM
  #46972
z0om's Avatar
I just finished putting in a new motor last week, took some nice pictures:
Old Apr 19, 2011 | 05:04 AM
  #46973
hb420's Avatar
Great looking Da man, loving the cpf's on it to.
Old Apr 19, 2011 | 05:55 AM
  #46974
Mattb16teg's Avatar
Community Builder
Holy crap that car is clean but more importantly where are those pics taken?
Old Apr 19, 2011 | 07:25 AM
  #46975
hondafr33k's Avatar
what up everyone! Can anyone point me in the right direction with my teggy i already have intake, full exhaust and chipped stock ecu getting a 65mm TB and skunk2 Intake manifold what else?
