DA Integra's Only
Old Oct 29, 2010 | 11:00 AM
  #43801
DumaDA's Avatar
Default Re: DA Integra's Only
i love to see that red da with some oem bumper lights and clear sidemarkers
Old Oct 29, 2010 | 11:04 AM
  #43802
nels00n's Avatar
c_mack9 SO CLEAN MAN
Old Oct 29, 2010 | 11:05 AM
  #43803
c_mack9's Avatar
theyre konig kandy in a virtual chrome finish. you cant see em in these pics, heres more: http://forums.g2ic.com/showthread.php?204872-Isla
i would like some OEM bumber lights but the sidemarkers will stay amber.
Old Oct 29, 2010 | 11:06 AM
  #43804
c_mack9's Avatar
thanks for the love (/hugs)
Old Oct 29, 2010 | 11:07 AM
  #43805
Mattb16teg's Avatar
Community Builder
Community Influencer
I like em, hella polished! Did you polish them or did they come that way?
I love my orange bumper lights! "ricey"" or not!
Old Oct 29, 2010 | 11:10 AM
  #43806
c_mack9's Avatar
they came that way, i think its an exclusive finish from JLB. in person they look like a mirror. i use invisible glass as wheels cleaner...
Old Oct 29, 2010 | 11:52 AM
  #43807
Mattb16teg's Avatar
Community Builder
Car looks good, what's the motor setup like?
Old Oct 29, 2010 | 11:54 AM
  #43808
c_mack9's Avatar
LS/vtec with CTR pistons and stock gsr head, ITR hydro tranny, light flywheel, and retardly stiff clutch.
Old Oct 29, 2010 | 12:07 PM
  #43809
Mattb16teg's Avatar
Community Builder
Good stuff, nice basic setup!
What do you mean stiff? As in the clutch peddle is hard to depress?
If so that is not right and the pressure plate is probably binding up.
Old Oct 29, 2010 | 12:08 PM
  #43810
c_mack9's Avatar
yeah when i press the pedal it smashes me back into the seat.
Old Oct 29, 2010 | 12:12 PM
  #43811
Mattb16teg's Avatar
Community Builder
Is it an ACT clutch and flywheel by any chance?
it should not be that hard and is most likely an indication of a problem. Although since your Hydro it could be numerous things though. Maybe something simple.
Had the same problem years ago with an ACT unit.
Most aftermarket clutches are easier to depress than stock units. I have a CC 6 puck in my DA, when I had my stock CRX, the clutch in that was harder to depress than the DA.
Old Oct 29, 2010 | 12:14 PM
  #43812
kNOwLedGe.'s Avatar
Originally Posted by EFcivicJDM
my DA6 made speedhunters yay hahaha
California plates add the nice USDM touch!
Old Oct 29, 2010 | 12:19 PM
  #43813
c_mack9's Avatar
im not even sure, it was in there when i got it. i was curious about it being the hydro conversion too. ive never known it to be any other way though. can you replace the pressure plate without replacing the whole clutch or does it all come together? ive never had to replace a clutch before.
Old Oct 29, 2010 | 12:21 PM
  #43814
Mattb16teg's Avatar
Community Builder
So your not sure if it's really hydro????
You can purchase a pressure plate separately but for what it's worth it's easier to do both at the same time while you have it apart.
Old Oct 29, 2010 | 12:24 PM
  #43815
EFcivicJDM's Avatar
thanks man anyway of finding out on your end what the plates are actually off???hahaha
Old Oct 29, 2010 | 12:28 PM
  #43816
kNOwLedGe.'s Avatar
It's just a generic plate number for a passenger car. It follows the standard pattern of one number, then three letters, then three numbers. Since the first number is a 6, its a pretty recent plate.
Not sure where I could look up the plate to see the exact vehicle it came from, though.
Old Oct 29, 2010 | 12:34 PM
  #43817
kNOwLedGe.'s Avatar
You run that thing on pump gas?
If by a "gsr" head you mean one from a B18C1 (P72), your compression ratio is around 12.5:1 with stock bore and stock headgasket.
Old Oct 29, 2010 | 12:53 PM
  #43818
projectTeG's Avatar
not to mention the possible piston to head contact. if i were you i would install a tad thicker head gasket.
Old Oct 29, 2010 | 01:17 PM
  #43819
EFcivicJDM's Avatar
oh right cause in ireland theres a website you enter the reg it gives you the make and model ...it has oct 09 tags i think?oct on the left and 2009 on the right in blue got them off ebay?
Old Oct 29, 2010 | 01:39 PM
  #43820
ummda9guy's Avatar
Originally Posted by DA9parling
UMMDA9GUY is that your rear view going across your windshild? i want one lol
yes sir! its really sweet! you can see everything. yupp, ebay i think i paid 25 for mine.
Old Oct 29, 2010 | 01:54 PM
  #43821
negusjuda's Avatar
whats so basic about ctr pistons with a gsr head lol not a combo i would do personally to risky with piston dome to head clearence
Old Oct 29, 2010 | 01:56 PM
  #43822
negusjuda's Avatar
oh didnt notice 2 other people posted about that combo yea i would be very carfull with that combo and i wouldnt run anything under 93 octane. does it ping like crazy
Old Oct 29, 2010 | 02:09 PM
  #43823
negusjuda's Avatar
hey c mack how much those konig kandys run you im thinking of getting them but in gold
Old Oct 29, 2010 | 02:16 PM
  #43824
ncsi's Avatar
Woot friday!
Old Oct 29, 2010 | 03:55 PM
  #43825
c_mack9's Avatar
it has a cometic head gasket but not sure what thickness. its tuned on hondata for 93 octane. i beat my friend in his s2000 in a first gear roll, i pulled in every gear. i didnt build the engine, he said the head and block were milled to fit flush so that would probably raise compression a tad as well. i dont know much about engines but i can tell you it runs pretty damn well.
the kandys in gold should be around 100 each, call dustin flickner at JLB and tell him youre an HT member, he gives discounts. super awesome place to buy stuff from.
