***Official All-Motor Stock Sleeve B20VTEC Thread***
Old Apr 1, 2010 | 04:12 AM
  #1276
hey man's Avatar
Default re: ***Official All-Motor Stock Sleeve B20VTEC Thread***
didnt know he was going to run 92 fuel .
Old Apr 1, 2010 | 06:11 AM
  #1277
negusjuda's Avatar
he ca nrun it but he is gonna lose power due to timing being fixed to compensate for that type of fuel now if he went with 93 or higher he could gain more hp from it but i still wouldnt go that high on 93 thats just my personal prefrence
Old Apr 1, 2010 | 02:54 PM
  #1278
slide inside's Avatar
so i should shoot for what compression at 92 oct? 11.5.1?
Old Apr 1, 2010 | 03:43 PM
  #1279
209lsr_ly's Avatar
here's one of my builds
Gsr head pnp I think was done by DNR
Dual valve springs retainers supertech flat face valve
Skunk2 stg3 tuner cams
VictorX manifold rc440s
Arais 85mm 14:1 compression (stock sleeves)
Eagle h beams
Stock crank
Profab headers
TypeR tranny 4.7 final
Running on e85
simple build nothing special
See signature for whp and last time tested
We will be testing again this 11th at cmi. Will post pic up asap
Old Apr 1, 2010 | 05:20 PM
  #1280
negusjuda's Avatar
if its a daily driver thats what i would run just to be safe. what kind of cams you running
Old Apr 2, 2010 | 11:51 AM
  #1281
thanks. i was gonna go with the blox p1 cams, skunk2 pro1 copy
Old Apr 4, 2010 | 09:30 PM
  #1282
System Lord's Avatar
I have a fully stock bottom end b20z with a fully stock gsr head boosted on 9 psi 292 hp with 450 dsm's more potential with bigger injectors, full sleeper here's a pic enjoy
Old Apr 5, 2010 | 07:00 AM
  #1283
hey man's Avatar
keep this thread alive !
Old Apr 6, 2010 | 08:42 AM
  #1284
hey man's Avatar
i got a quick question . i just got my gsr harness im using for my b20vtec setup . would i be able to use my headlight harness from my 1.5 and just use my gsr body harness ? would it work ?
Old Apr 7, 2010 | 02:21 AM
  #1285
secretcitizen's Avatar
Originally Posted by m2theizzy
secretcitizen---- build is looking awesome, but what is that on your sleeves? looks like some homemade block guard or something
It is block welded
Originally Posted by Romo Pyro
I
<3
This
nohomo.
lol thanks
The tune is this Saturday (4/10) hoping for some good numbers
Old Apr 7, 2010 | 05:01 AM
  #1286
dirtyharryhatch's Avatar
A Digital Frontier
Your in the wrong section.
Old Apr 7, 2010 | 05:08 AM
  #1287
A Digital Frontier
Bump cause i rode in my friends b20v with
JE 11.1 compression pistons
Skunk2 pro2 cams
E85
Hytech replica Tri-y header.
Made 230whp probably the funnest car ive ever riden in.
Old Apr 7, 2010 | 04:32 PM
  #1288
Apprentice-X-'s Avatar
A basic B20 VTEC build.
190whp 145tq
GSR Head
B20 Block
84.5mm 12:1 RS Machines
Stock Rods w/ ARP Rod Bolts
ITR Camshafts
Skunk2 Camgears
Skunk2 Pro Series IM
BDL 68mm TB
AEM short ram
Hytech Replica Header
60mm RSR catback (I like quiet rides)
2.5" Test Pipe
Chipped P28 tuned on Crome
Next plans:
Upgrade camshafts.
Headwork
Hondata S200
And then that's it for now.
Old Apr 7, 2010 | 05:07 PM
  #1289
what type of dyno was that run on? ^^^^^^ Dynojet I see sorry
You might want to look into getting some 3" intake tubing and a velocity stack.
Old Apr 7, 2010 | 05:12 PM
  #1290
hey man's Avatar
anyone ?
Old Apr 7, 2010 | 06:35 PM
  #1291
Any particular velocity stacks you recommend?
Old Apr 8, 2010 | 03:12 AM
  #1292
I would say blox because you can find one that will come with a filter that will not take away from the entire purpose of the velocity stack.
Old Apr 8, 2010 | 03:42 AM
  #1293
negusjuda's Avatar
and its fairly cheap in price i picked one up a few weeks ago. i must tell you though the filter is huge lol i hope you have or can make room for it
Old Apr 8, 2010 | 03:45 AM
  #1294
negusjuda's Avatar
190whp 145tq
GSR Head
B20 Block
ITR Camshafts
Skunk2 Camgears
BDL 68mm TB
AEM short ram
2.5" Test Pipe
Next plans:
Upgrade camshafts.
Headwork
Hondata S200
these are the numbers im hoping for at the least but im running 11:1 compression and skunk2 tuner 1 cams and a rmf replica header
Old Apr 8, 2010 | 06:17 AM
  #1295
A Digital Frontier
those ITR cams are holding that setup back sooooo much.
Old Apr 8, 2010 | 05:50 PM
  #1296
k thanks I'll check them out.
Yeah luckily got lots of room in my engine bay.
Yeah I know, I didn't have a choice, the GSR head I bought came with them and I'm on a strict budget haha
Old Apr 8, 2010 | 06:06 PM
  #1297
DDTECH's Avatar
No need to really upgrade from crome there buddy.. it does a good job..
I'm currently using it on my b20vtec - which will be pro2ed here shortly....when i get a chance to upgrade I'm going to eCtune - i suggest you do the same.
Old Apr 13, 2010 | 05:40 PM
  #1298
hey man's Avatar
anyone selling a skunk 2 2nd gen manifold for a gsr head lol im in desprit need a.s.a.p
Old Apr 14, 2010 | 10:39 AM
  #1299
how are the pro series cams with daily city driving and say upgraded clutch?
Old Apr 14, 2010 | 12:29 PM
  #1300
neverstop's Avatar
don't get the blox velocity stack, get the BPI one. its not much more, comes with a much better air filter and blox 100% just ripped that off from BPI. I wouldn't support thieves like blox and for only $40 more I get a quality K&N that is probably worth 1hp on its own. plus the bpi was designed for that filter where as the blox is just a cheap copy. I've had both (current car came with blox one) and the blox already has signs of stress cracks where as the BPI one was much older and never showed any signs of wear
