DA Integra's Only
Old Oct 1, 2009 | 10:27 AM
  #32401
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: DA Integra's Only
Originally Posted by kNOwLedGe.
It's a B18B with OEM PR3 pistons, ported B16 head w/ stage 2 cams. ITR intake manifold. TODA header. Hondata. Crazy gearing and LSD.
SHIIIIIIIIT. There has been lots of fire going around lately. My cousin and I indulged a little bit last night and ended up playing Ken Griffey'94, NBA JAM, and Mortal Kombat II for my SNES for a coulple hours.
QUALITAY!
Ahh nice simple build.
LoL wow I need to go home and play some Super NES, Ken Griffey Baseball brings back memories!
Old Oct 1, 2009 | 10:58 AM
  #32402
Colin's Avatar
Originally Posted by 1200 Hobos
h
It'd be interesting to hear a review on those ebay top-hats, they don't look too bad yet I idk if I'd trust them completely for rigorous use? The stud on the top-hat on the right looks crooked here:
It looks like it's just pressed in crooked and it would straighten out once you tighten it down, however the studs do look very low quality.
I remember having the 4x100 to 4x114 15mm ebay spacers when I had 96 spec ITR wheels, when I went to remove the studs from the spacers to use them on my 4x100 weds, all the studs had been deformed. They where leaning to the side like a lame *****... I was lucky they didn't brake loose on the track, those were very sketchy.
Yeah, the hardware looks like junk. The studs could be strong enough but just not nice looking, they look like someone cut 'em off w/ a chop saw opposed to having the normal end on the threads. And those nuts suck, they are supposed to be lock nuts of some form or another.
I'm guessing the hole is just a bit large for the stud and it's in there crooked, like you said, it'd probably straighten out. For light use I wouldn't hesitate, but for track or tons of daily driving it might not be the best way to go. I don't think many people have 'em yet so getting a good review on durability is gonna be tough...
Old Oct 1, 2009 | 11:47 AM
  #32403
da9leo's Avatar
I <3 DA's
i had them, they suck the hardware strips easily
the bushings are crap, dont fit on konis struts
its extends the strut about 3/4 in
i would rather get some GC ones or some custom extensions
Old Oct 1, 2009 | 12:41 PM
  #32404
1200 Hobos's Avatar
There we have it. Thanks for the heads up.
  #32405
Colin's Avatar
Yeah, you were the one who bought them on g2ic, right? So your set is ruined now? I wonder if it'd be worth it to buy a set of these just for the aluminum. Buy the hardware separately and I already have ES bushings.
Old Oct 1, 2009 | 01:02 PM
  #32406
1200 Hobos's Avatar
They're so cheap it'd probably be worth it.
Old Oct 1, 2009 | 02:14 PM
  #32407
1200 Hobos's Avatar
Originally Posted by Mattyg2
245's on edomotos DA is t3h s3x. I'm going to try to run a "similar" setup whenever I can drive my DA again.
Funny story. NASA Honda Challenge actually changed their rules after we had done that. Technically, according to the rules at the time, H4 cars are completely free in the suspension and tire department without going over a 16" rim and changing suspension mounting locations. After they found out we stuffed 245s under there, they changed the rules to say: No tire bigger than 225 in H4! lol. So now, H4 cars can't go bigger than 225s and we moved on to H2 with a built b20z and 245s.
Old Oct 1, 2009 | 02:44 PM
  #32408
kNOwLedGe.'s Avatar
Found one more pic with the TODA bling cam gears:
Old Oct 1, 2009 | 03:17 PM
  #32409
da9leo's Avatar
I <3 DA's
yeai bought them, i was gonna use them on my konis, but they didnt fit, the strut rod thing was too fat. So i ended up using them on my skunk pro s
my car is barely driven so i was surprised to see that the bushings had started to crack/fall apart
the problem with the hardware was that it stripped on itself and then it would just spin when i tried taking them off. i figured out that the bolt was not secured right to the tophat, so it just spun. it would probably work better with oem hardware, and some tack welds to keep it from spinning
im just gonna get my stock top hats extended or see if ground control can make me custom sized ones
Old Oct 1, 2009 | 03:24 PM
  #32410
1200 Hobos's Avatar
^Ah yes, cheap metal has the tendency to do that. Colin I take back what I said, it wouldn't be worth it. Even if you press in your own hardware the cheap aluminum used for the actual top hat could strip aswell. The stud will just spin like what happend to Leo.
Old Oct 2, 2009 | 12:30 PM
  #32411
da9leo's Avatar
I <3 DA's
yeah i would just get the stocks extended or some custom GC
Old Oct 2, 2009 | 12:49 PM
  #32412
kNOwLedGe.'s Avatar
I have some stock front tophats left over if anyone wants an extra set to extend.
Old Oct 2, 2009 | 12:54 PM
  #32413
Hydro_Da's Avatar
recent shot from this weekend, crappy cell pic ftmfl.
Old Oct 2, 2009 | 01:06 PM
  #32414
Mattb16teg's Avatar
Community Builder
Looks good, still a fan on the 92-93 bumper myself.
Old Oct 2, 2009 | 01:13 PM
  #32415
da9leo's Avatar
I <3 DA's
same here unless it has on OEM lip
Old Oct 2, 2009 | 01:24 PM
  #32416
1200 Hobos's Avatar
Just ordered some Koni/GCs
Old Oct 2, 2009 | 02:14 PM
  #32417
Brice.Hayden's Avatar
wow that is super clean. won't take much to make that awesome.
Old Oct 2, 2009 | 02:25 PM
  #32418
ChaseIntegra's Avatar
I'm back from England Brice, where you at boy?
Old Oct 2, 2009 | 02:29 PM
  #32419
Colin's Avatar
Yeah, that makes sense about the stud stripping the aluminum, I hadn't considered that. And welding wouldn't be an option since the top hat is aluminum and the stud would be steel.
Car looks good Suren, can't wait to see your progress!
Old Oct 2, 2009 | 02:44 PM
  #32420
1200 Hobos's Avatar
Thanks Brice, thanks Colin. All I need now is -Infinity-'s Rega's and I'll be happy for awhile.
Old Oct 2, 2009 | 02:48 PM
  #32421
no not 15" get some 16" regas
Old Oct 2, 2009 | 03:11 PM
  #32422
Mattb16teg's Avatar
Community Builder
Get some Work Rsz-r's lol!!
Old Oct 2, 2009 | 03:16 PM
  #32423
1200 Hobos's Avatar
If they're not 15/16x7 I can't use them since I want to run 225/45 series tires. The 16x7s are an option but the tires will be $100 more per tire every time I need tires. Too much for a grassroots guy like me.
Old Oct 2, 2009 | 03:35 PM
  #32424
hb420's Avatar
Old Oct 2, 2009 | 03:37 PM
  #32425
1200 Hobos's Avatar
Sick. Lol at the smiley face.
