BUILT NOT BOUGHT!
Old Dec 19, 2010 | 04:39 PM
  #1651
da9crxsi's Avatar
Default Re: BUILT NOT BOUGHT!
throw those snow pics in the snow pic thread!
Old Dec 19, 2010 | 05:00 PM
  #1652
91_LS's Avatar
I didn't know there was one,thanks.So today i bought a complete AC setup with everything needed,white gauge coves,Halo's and projectors. All for 25 bucks.
And Yeah,so the winds are up to about 90mph here and its snowing like hell. I'm in my house and here a "BANG" and my alarm go's off. I go outside and see the drives side covered in this sick looking crap and this big *** filter to a swamp cooler next to the car.I now have this nice size dent + scratches on my door and quarter. I went to let the lady know but feel bad cause she is old and hella nice,but i need to get this fixed.
Old Dec 19, 2010 | 08:27 PM
  #1653
db1st's Avatar
this looks like a fun thread.
Old Dec 19, 2010 | 08:40 PM
  #1654
gr8integ's Avatar
looks like the wires on those gauges are cut off and did it come with the control/power box? without it, it might not work.
also, is that all you got for the projectors? looks like you're missing the projector bowl and glare shield that all projectors needs. it won't work without those other parts. from your other post, it looks like you have HID, are you trying to make a retro-fit with those projectors?
Old Dec 19, 2010 | 09:08 PM
  #1655
91_LS's Avatar
Yeah everything is there for the projectors. The covers do have the power box but i got LED inside the gauge so i don't need them to work. The projectors have the thing that blocks off the top part of the lights so they don't blind people,they also have the bottom part as well.Ill be doing a retro-fit on my stock headlights.
Old Dec 19, 2010 | 09:29 PM
  #1656
91sedan_kid's Avatar
that sucks 91_ls
Hello db1st, welcome to my thread
Old Dec 20, 2010 | 01:39 PM
  #1657
91_LS's Avatar
I know there's a DIY on how to do this,but i just want to share on how i did it.
The projectors came out of a DA one piece headlight. The one piece was broke and so i rescued the part's out of them.
Well i started by taking the bumper off. I then took the headlight off and used a blow-drier to heat it up.
I pulled the glass off the housing and got to work.
I took to OEM blocking thing out and cut the back of the projector reflector to fit over the HIDs.
Now the projectors lined up just right,so i didn't have to do much to level them.
I used a can to cut out some raps to go around the projectors so the light will stay inside and not come out making the glare spread out.
I also got some LED strips that you can cut,i put them inside just for fun. I think it came out good,you?
Now i put everything all back together and here it is.
BEFORE
AFTER
Old Dec 20, 2010 | 02:42 PM
  #1658
BrayzieEF9's Avatar
91_LS- Nice job, you went kinda ghetto with the tomato juice can though. lol
Old Dec 20, 2010 | 03:16 PM
  #1659
x2 very nice work!
Old Dec 20, 2010 | 03:19 PM
  #1660
db1st's Avatar
ouch kiale(91_LS)...you can't make a retro-fit out of any projectors, especially a 2 inch projector. you also cut away too much of the reflector bowl....doing that will eliminate ALOT of light output. you should of done more research.
Old Dec 20, 2010 | 04:57 PM
  #1661
91_LS's Avatar
Thanks guys. Yeah I'm going to have to redo it. The bowl was cut already,i only cut just enough for the bulbs to fit. Its good for now but I'm going to have to do some more cutting to get it right. But hay,its my first time and i had no help so i think i did a good jub so far.
Old Dec 20, 2010 | 05:53 PM
  #1662
db1st's Avatar
more cutting will just make the light output worse...looks like you need a whole new projector. also, 2 inch projectors are usually used for fog lights and produce less light. you're gonna have to get a 2.5 inch projector and a projector that is DESIGNED for HIDs. you can't just get a halogen designed projector and think you're gonna get good output with HID bulbs. especially in a fluted len. with the set-up you have now, your light output is as much as your signal lights.
IMO...i think you FAILED your first retro-fit. you used the wrong projectors and you damaged the reflector bowl. but look on the bright side, at lease you didn't waste too much money. like i keep on telling you....do MORE research.
Old Dec 20, 2010 | 06:03 PM
  #1663
91 crx savage's Avatar
built not bought!
Old Dec 20, 2010 | 08:58 PM
  #1664
91_LS's Avatar
Well for one,i did RESEARCH so please stop telling me that. And the projectors are not from fog light,there out of the projector one piece headlights that was fitted with HIDs,shows what you know. Just because i didn't do it you're way don't mean you have the right to bash me like you did. And like 91 crx savage said,its built not bought. I still have some work to do to get it the way i want,but you are also forgetting about the glass itself not being clear,so its not going to look like yours,so PLEASE if you got nothing to contribute to this thread other then to point out my mistakes like you and Courtney do on G2IC,don't post on this thread. I am so getting sick of it. Thanks.
Old Dec 20, 2010 | 09:19 PM
  #1665
mugendamugen's Avatar
Bash your thread um I dont think I bash it on g2 I put my .002 cents. Just like you do on ever one else thread on g2 an ever were would you like me to point it out to you? As far as on here I have not said a dam thing so I think you should keep my name out your mouth an off this thread unless I bash your thread an if you like me to bash your thread sure no problem let me know AN MY NAME IS CORTNEY NO DAM U GOT IT
Old Dec 20, 2010 | 09:28 PM
  #1666
91_LS's Avatar
I never said you do it on this forum did i? You and db1st always have to point things out or make rude comments on my posts,I've also pointed that out on G2IC but Mike wants me to take it to E-mails. And i only try helping people,so yeah i have pointed out other peoples mistakes but don't just bash nor do i bash on one guy like you guys do to me.IDK if you guys do it to make me mad or simply don't see the pattern here,but i never did a thing to you guys. And you posting a reply and even seeing mine on this thread go's to prove my point. You guys stick together and always try to prove me wrong. Case closed,if you want to carry on,E-mail me kialeh@hotmail.com Lets not blow up this thread.
Old Dec 20, 2010 | 10:29 PM
  #1667
db1st's Avatar
dude...kiale, i know a good amount when it comes to electricals and HIDs, ALOT more than you. how can you tell me that those Projectors came out of a Headlight when they're 2 inch projectors (average HEADLIGHT projectors are 2.5 to 3.0 inches). look how small they look in your headlights. Also, you said that those projectors came off an aftermarket one-pieces, but guess what...all the aftermarket one-pieces never had projectors for the low beams, they had it for the FOG LIGHTS(like what i stated previously). so that means that you are using fog light projectors. if you did research, why would you cut apart your reflector bowl or even buy projectors with a damage reflector bowl? one of the biggest rule when it comes to a retrofit...don't damage the reflector bowl, any damage to it will effect the light output. and you cutting it up shows how much you DONT know. the evidence is obvisious that you don't know what you're doing. if i don't know anything about retrofits....compare my retro-fit to yours. i know you didn't do any research because you stated on g2ic that you wanted to do a retro-fit, and that was just last week. of course im gonna point out your mistakes, i know you personally and i wouldn't want someone i know do all the wrong things. i tell you things that you need to do to do it right and you still don't listen because you like to be a know it all, then you mess-up and do exactly what i told you NOT to do, like over-reving your motor (thats how you got the white cream on your oil cap), painting your rims, and having the wrong side markers.
you're a member of this "built not bought" thread, but all you ever did to your car was add another lip to your existing lip then used skateboard grip tape to cover it, installed side skirts that ANYONE can install and bondo a monitor to your center console. you didn't even install your suspension because u has a thread on g2ic last year stating how you were able to rip-off Les Schwab for strut installation. you didn't even swap the motor to your ride, you had Redzone do the complete swap.
Originally Posted by sc34dc4
So if I buy a car and drop it off at a shop and say call me when it's finished being built then what did I even do?
sorry to tell you this 91sedan kid, but kiale(91_LS) doesnt meet the qualifications to be a member of this thread. ask BarShawn, he knows Kiale personally.
SORRY im being a dick....this has been an on-going thing for over a year.
Old Dec 20, 2010 | 11:04 PM
  #1668
91_LS's Avatar
DUDE, yeah i got my OLD set of shocks from Les Schwab,but i had changed all them out (MY SELF) with another set. And everyone knows about my swap being installed at Red zone,so who the hell cares. The rims,i painted them the way I LIKED IT and you got mad because IYO it wasn't you're stile. Id like to see you modify a screen in you're ride.I also installed my muffler and piping,strut bar,skirts,made a custom lip that wasn't done the last time you seen it,tack light,cluster LEDs,side markers that you hate cause i didn't do it you're way,my retor fitting that I'm also still working on,new clutch cause redzone ****ed me over,new speed and clutch cable and am working on installing a complete AC kit. O' also installed new seats and changed out my tails and brakes,rotors and do all my tune ups my self.Also did my alarm MYSELF and did a hole lot of other things seance the last time you seen me, GO TO HELL. And if i can find the light i took the projectors out of,you would see that they indeed had projectors in the headlights,not fogs. I took them apart so i should know. And being a know it all,look who the hells talking man, Lay off me. IDK why you guys insist on bugging me,but it needs to stop. Ever seance i moved to NV,you guys have been nothing but dicks to me,if you all miss my *** that dam much,drive up here and see me.And the milky **** was not over revving my engine,it was cause the cold that did it. I never over rev my ****,so don't be making **** up. Now can we please stop this and get back on topic? Thanks.
Old Dec 20, 2010 | 11:38 PM
  #1669
My_EFsedan's Avatar
umm..peanut butter jelly time?
Old Dec 20, 2010 | 11:52 PM
  #1670
91_LS's Avatar
yeah sorry crew,idk whats wrong with these guys but ill say know more. And 91sedan_kid,sorry about the rant man. I didn't think these guys would come on here to bash me and try making me look bad. All they needed to do is let me know what i did wrong without the smart *** remarks. If you feel I'm not worthy to be in you're crew,go ahead and take me off,no hard feelings.
Old Dec 21, 2010 | 01:49 AM
  #1671
90gs-96gsr's Avatar
kiale,
I would not trip off what some of these people are saying, first off it just seems like there are certin people here that are hating on you and it seems like they follow you from forum board to forum board. There are after market one piece projector hid headlights that have the low beam as a projector it is a matter of what company you go with. Out of all the different cars and all the different manafactures of projectors that can be chosen to use im sure you will find one.
As a example the 94 to 01 integra uses a projector low beam if the bumper is removed its a one piece case and point it can be disasembled and used. also there are one pice projectors for BMW, lexus, mercades, toyota, nissan, and the list goes on that have low beam projectors. For some one to say after market one piece headlights have never used a projector for the low beam they have obviously never expanded there knowledge base on one piece projector headlights.
Also didn't you say you removed them from a headlight assemble that someone else had put together, theres no way anyone can tell for sure where those came from. What i will say is simple a fog light does not have a halo ring but a high beam does a fog light on alot of the after market one pice headlights have more of a slight oval shape and the high beam is round and what i see you have used was the lens base of the high beam projector not a fog light. This base can be used for a low beam it just intensifies the light beam and you need to compinsate with the proper alignment of the beam as to adjust for road glare.
also there are 2 inch 2.5 inch and 3 inch projector bases. All projectors that are 2 inch are not automatically by defualt fog lights for example the early years for altezza had a halo projector with a 2.0 inch base and with the halo ring it extended to 2.5 inches.
And one final thought when people say Built not Bought i ask them this
did you slave over the kelm in your back yard to forge that p73 or p30 piston,
was it awsome to have all that machinery in your garage to design, cast, and create those valves, spring, and retainers
was it nice to have a hot tank to boil that block to clean it up and check for cracks, or even the crank and rod caster how hard was it to pour that molten metal to design those.
You see i can go on and on but my point is this at some point every single person paid to do that build
when i see built not bought that does not mean just because he had his car done at redzone he bought it. What that does mean is he had a plan he set out and accomplished his plan. motor swap, tranny build, suspension install what ever it may be not to mention the other stuff he has done and it was done the way he wanted it done to his specifications which means he had plans if he had plans that insinuates he was building something now to ricers maybe thats bought but to us OG's who have 15+ years in the scene thats built.
Answer this Jack Roush pays to have all his work done all his cars built and all his racing teams on the track is everything he personally has done Bought Hell no he personally built his entire empire..
Old Dec 21, 2010 | 02:22 AM
  #1672
No worry.
90gs-96gsr: You prove a very good point. We have been over this many many many many many many times.. and i will say it once more..
Not everyone has the knowledge or proper tools to do all the work on their cars which is COMPLETELY UNDERSTANDABLE, But the concept BUILT NOT BOUGHT in THIS thread means you HAVE put in wrench time into your OWN car not just always dumping it at a shop for every little possible thing. 90gs-96gsr im not saying your thoughts are wrong nor disrespecting you in anyway but in this thread thats what build not bought means. IF people have a problem with that then they can feel free to go look at the hundreds of other thread on H-T.
so with that being said... ITS PEANUT BETTER JELLY TIME! where he at!, where he at!, WHERE HE AT! THERE HE GO!, THERE HE GO!, THERE HE GO!
http://www.youtube.com/watch?v=Z3ZAGBL6UBA
Old Dec 21, 2010 | 02:44 AM
  #1673
00'civic's Avatar
Im on threw my phone and new on here so still getting the hang of the site but ill try getting some pics up to what's done so far to my civic. Went from stock to having halo lights,foglights,si spoiler,apexi n1 catback exhaust,off brand headers,not sure what brand rims. When winter is over I will have a fully built h22 motor turbocharged,lsd tranny. And future plans after the motor and tranny is in are 15 inch og axis rims,skunk 2 coilovers.
Old Dec 21, 2010 | 03:32 AM
  #1674
looking forward to some progress picture.
Old Dec 21, 2010 | 11:56 AM
  #1675
00'civic's Avatar
How can I upload them from my phone to get on here?
