turbo problems
Old Aug 20, 2006 | 10:35 PM
91crxracer's Avatar
Default turbo problems
i have a turbo 93 teg i just put a new turbo on it and it was smoking a blue smoke that means oil right? So i pulled my spark plugs and it showed no sign of oil. I have no oil going through my charge pipe and no leaks in my oil in or return line. So i pulled the turbo off tonight and when i unbolted the downpipe off the turbo it was all black and wet with oil would a bad turbo seal cause oil to go out the exhaust without going through the motor and still causeing smoke? i also did a compression check and every cylinder is 155 or better for compression. what do u think my problem is do i need a new turbo or turbo seal what should i do? it is an x power t3 turbo with an external wastegate and a 4.8 pound spring. Any ideas would help at this time cause i need to ge it fixed and not smoking.
thanks
Old Aug 21, 2006 | 04:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: turbo problems (91crxracer)
yes oil in the hot side will cause blue smoke out of the turbine housing.
Old Aug 21, 2006 | 04:21 AM
Mugencrxsir1's Avatar
You just answered your own question of why you are having a turbo problem........ XS POWER turbo is complete ****, I don't know why everyone continues to buy **** from them. A good used garrett/air research turbo can be bought off ebay for $200-$450, and that's a good reliable turbo, not some chinese turbo knock-off. Get a name brand new/rebuilt turbo off ebay, and your problem is solved.
Old Aug 21, 2006 | 08:14 AM
Hondacivicnut's Avatar
Oil passing into the exhaust side is a sign of a failed turbine seal.XSPower turbo's are not renouned for their quality.Some are good some are not.
However,it could be another issue.Are you running a turbo oil restrictor?A 0.060" restrictor fitted could help.
If you have the turbo rebuilt,fit a set of uprated stepped piston ring seals (stagger gap).
Or you could just junk the turbo!
rich7777
Nov 30, 2014 05:15 PM
b20beast83
Apr 2, 2009 07:36 PM
luv2boost
Jul 6, 2007 05:01 AM
hbyrd8701
Jun 16, 2007 12:19 PM
rideblitz
Nov 16, 2004 03:55 AM
