The Official SOHC Supercharger thread...
Old Mar 19, 2010 | 02:41 PM
  #1251
acura_el2000's Avatar
Default Re: The Official SOHC Supercharger thread...
Originally Posted by mattliston
is it allowing gas into the vacuum line?
replace the FMU
though I personally HATE FMU's ebcause theya re a cheap crappy "tuning" solution
maybe its time for a chipped ecu and a proper tune. would easily add horsepower simply because it can safely and speedily adjust the fuel better
I have the FMU installed but I do have a full tune and a chipped P28. I guess I can eliminate it?
this guy:
Old Mar 19, 2010 | 03:48 PM
  #1252
mattliston's Avatar
why the hell do you have an adjustable FPR and FMU?
get rid of BTOH!!! adjustable fuel pressure is useless for you!!!!
get rid of the FMU ata tuner, do a full tune.
are you using stock injectors?
Old Mar 20, 2010 | 04:54 PM
  #1253
that pic is not mine. I don't have that adjustable FPR I was just using that pic to show whats leaking. I will get rid of the FMU tho. honestly I have a lot to learn still. I have had a full tune.. and nope I'm on 550cc injectors right now.
So ive had a spell of bad luck this weekend and my belt snapped and my belt tensioner pulley seized. What was that website that sold replacement parts? My car is stranded until I can get them so I need help asap!
Old Mar 20, 2010 | 07:58 PM
  #1254
Jaker's Avatar
It'll run just fine without the belt to the supercharger. Only thing is you won't have an alternator. If your battery is good, you'll be fine for at least a full hour of driving or more.
The bypass valve will let in enough air that it'll run properly.
www.supercharger.com
Old Mar 20, 2010 | 11:20 PM
  #1255
mattliston's Avatar
no
I had a great battery in my d15b2 civic, would use less electricity, I struggled to get across town before having a friend jump and charge for a few minutes. 15 minute drive under normal conditions
Old Mar 21, 2010 | 05:51 PM
  #1256
stoptheh8's Avatar
Originally Posted by NeonPinHead
same site just click on oder by part # and enter 051-402 it's the 3.8" 3 ribbed pulley, or 051-402 is the 3.8" 4 ribbed pulley
What kind of boost will a 3.8" pulley provide? I have a y8 and I do have the JR crank pulley if that would matter.
Old Mar 22, 2010 | 01:32 AM
  #1257
mattliston's Avatar
you do realize he gave teh same part number for both?
and you can use B series pulleys as well
I would expect you to get teh motor re balanced since chaning crank pulleys means the motor becomes un balanced and can lead to issues down teh road like premature bearing problems, or excessive engine vibration
Old Mar 23, 2010 | 09:42 AM
  #1258
wes7side5o's Avatar
up
Old Mar 23, 2010 | 08:48 PM
  #1259
JUSTTURBO's Avatar
man idk about yall but i was thinking if i could ever get my jdm d15b running i mite SC it
Old Mar 23, 2010 | 08:49 PM
  #1260
JUSTTURBO's Avatar
also heard they are a little more reliable than a turbo
Old Mar 27, 2010 | 04:57 PM
  #1261
Nathan_volcom's Avatar
looking to find a supercharger for my car, anybody have any ideas ive been on craigslist and posted on marketplace i cant find anything right now.
Old Mar 29, 2010 | 12:50 PM
  #1262
TTE TEG's Avatar
Hey guys. I have a Hondata s200 I wanna finally install on my setup. Are 310s okay to run for injectors? I have the boost upgrade and see anywhere from 5psi to 8psi of boost on average.
Old Apr 6, 2010 | 07:49 AM
  #1263
gorpobr's Avatar
Hi,
I upgraded my setup(Old thread 7.5psi: https://honda-tech.com/forums/showpo...postcount=1169 ), put a Cometic Head Gasket, ARP head studs and a custom 3.11'' pulley, now the car have 9psi according to my datalog and 10psi at peak at the gauge.
Got only more 12whp in the whole rpm band and lot more torque, the car is funnier to drive now and the boost build fast. Could only tune until 7200rpm, after that my fuell injector ended and can't do more power...
Dynojet 7.5psi and 9psi
New Video with 9psi 0-180kmh
Old Video with 7.5psi 0-180kmh
Hope you enjoin!
Old May 1, 2010 | 04:42 PM
  #1264
does anyone else have an issue with the Idle Air Control Valve bunging up every couple months? I've had to clean it twice since I put the JRSC on.
Old May 6, 2010 | 01:08 PM
  #1265
c_trick's Avatar
I'm looking for a 3.4" with 3 ribs to use with my JRSC...
Someone sells it or knows where i can buy it?
Old May 7, 2010 | 06:09 AM
  #1266
92cxyd's Avatar
Originally Posted by muzzeemoto86
where can i find a supercharger kit for my y8?? preemptive thanks to everyone
I made my own setup taking the A/C out of my HB and putting an SC14 (1440cc/rev.) in its place.
Treated the s/c like a turbo as far as intercooler and piping to the tb.
Running around 12psi from 1.5K to 7k.
Old May 7, 2010 | 06:19 AM
  #1267
mattliston's Avatar
pictures! you know with a DIY or otherwise custom setup you need to show pictures
how else are we going to steal your idea?
ha ha ha
Old May 7, 2010 | 06:35 AM
  #1268
92cxyd's Avatar
ha ha ha
Already posted in other areas of this thread and other threads.
I can pm you my build thread on another site w/ more up to date info.
Old May 7, 2010 | 06:44 AM
  #1269
mattliston's Avatar
that would be cool. im stuck using a LIVE ubuntu setup on a pentium 3, so searching takes a VERY long time
hell it takes 20 minutes just to load up teh computer, considering its all RAM or cd reading. no harddrive yet lol
Old May 13, 2010 | 07:45 PM
  #1270
stiegz1983's Avatar
Originally Posted by Arcane
Welcome to my life....its kind of funny, we live in the same area and have the exact same problem.
The problem is not the pulley, its the alternator bracket itself. Jackson racing supplied a offset alternator bracket that shifts the alternator inward for clearance. If you never got it, then you would have to take the bracket off (a humongous bitch) and mill it or purchase one (if you can).
Hey Arcane,
Do you still have the Y8 alternator bracket for the JRSC for sale?
Where you ever able to figure a work around for not needing it?
I've read the full Sohc Supercharged thread and came across your posts regarding needing the JR crank pulley and lower alternator bracket for the y8.
Is it possible to just use the y8 crank pulley with the jrsc y8 kit? I don't want to lose PSI having to use the JR crank pulley if possible. I'm also missing the lower alternator bracket and I'm hoping for a work around.
Thanks!
Old May 14, 2010 | 07:55 AM
  #1271
Arcane's Avatar
Originally Posted by stiegz1983
Hey Arcane,
Thanks!
I do indeed have the lower bracket for sale. A couple people were interested but nothing ever worked out. PM if your interested.
I tried running the Y8 pulley on my S/C but from what I could gather it gave me some belt alignment issues. The Y-series kits are offset towards the passenger side for MBC and shock tower clearance. If you line the Y8 pulley and the JR one I beleive you'll find that the ribs do not match up. Thus by necessity, you'll have to run the JR one for now untill you can source a factory JR crank pulley or a smaller S/C pulley.
Hope this helps.
Old May 17, 2010 | 04:20 PM
  #1272
daveb91's Avatar
Its been said a million times in this thread about the y7/8 kits...
Old May 17, 2010 | 04:22 PM
  #1273
daveb91's Avatar
So your spinning the SC14 in reverse??
Old May 18, 2010 | 06:08 AM
  #1274
stiegz1983's Avatar
I guess I missed that. First time I read (or noticed) about alignment issues when using a y8 jrsc on a y8 engine was on page 46.
All the other alignment issues were for others using the incorrect charger for their engine.
Old May 18, 2010 | 06:47 PM
  #1275
sophocha's Avatar
How about using a Y8 or Z6 JRSC on a ZC DOHC engine with a ZCSPEED adapter.Would the pulleys align properly or not?
Thanks
