The Official SOHC Supercharger thread...
Old Jul 7, 2009 | 09:33 PM
  #1126
acura_el2000's Avatar
Default Re: The Official SOHC Supercharger thread...
I have been running my JRSC for the past month or so and I have noticed that my belt works its way off of one rib on the pulley... After readjusting it and starting the car the belt almost immediately does it again. I have noticed that the alternator pulley is causing it because its a few millimeters out of alignment when the belt is properly adjusted on the supercharger pulley.
I will attempt to grind the mounting surface of the current pulley to move it in, hopefully aligning it better.. I can't be the only one with this issue. Failing that Anyone know where to buy a new alternator pulley?
Old Jul 8, 2009 | 04:54 AM
  #1127
Arcane's Avatar
Welcome to my life....its kind of funny, we live in the same area and have the exact same problem.
The problem is not the pulley, its the alternator bracket itself. Jackson racing supplied a offset alternator bracket that shifts the alternator inward for clearance. If you never got it, then you would have to take the bracket off (a humongous bitch) and mill it or purchase one (if you can).
Old Jul 8, 2009 | 10:02 AM
  #1128
solsi2000's Avatar
ok so i put on the supercharger and my exhaust is spitting out a lot of white smoke. its almost misty like. i have a base tune and i did not drive the car around at all. I was just trying to bleed the radiator to get the idle down. I dont think that it could be the headgasket because i only ran the car for a few minutes. There are no leaks from the rubber hoses I know that for sure. can anyone help?
Old Jul 13, 2009 | 01:02 AM
  #1129
I'm taking it into a shop to see what can be done I'll keep you updated.. do you have any more info on the JR bracket? what are you doing to fix it?
Old Jul 17, 2009 | 09:01 AM
  #1130
DEVINEER's Avatar
Im looking to purchase a complete jrsc kit for a d16z6. If anyone know of a kit for sale or is selling a complete kit please p.m. me with the details..Thankyou!
Old Jul 17, 2009 | 10:32 AM
  #1131
Arcane's Avatar
I've milled my stock alternator bracket but I'm still running the stock crank pulley, so I'm going to throw on the JR one to see how that helps things. If it still doesn't line up, I'm going to have to take the bracket out and mill it some more.
Old Jul 18, 2009 | 08:13 PM
  #1132
daveb91's Avatar
Sounds like you guys are running a Y8/Y7 bracket.....
Old Jul 19, 2009 | 04:50 AM
  #1133
yeah its the stock bracket... Y8 for me... what should I have??
Old Jul 19, 2009 | 10:59 AM
  #1134
daveb91's Avatar
I think in the beginning of this thread its been a while.... I think if you run a y8 kit you also need the supplied crank pulley.......... everything has a slight offset.
Old Jul 23, 2009 | 02:48 PM
  #1135
civy123's Avatar
For the D16Y8 kit you will need to use the JR crank pulley and the JR modified alternator bracket to properly align the belts. If not your belt will skip one rib. This would be the same for the D16Y7 motors. The Z6 is the only D series motor that does not need the crank and alt brackets because of the way the intake manifold is cast.
Old Jul 23, 2009 | 02:51 PM
  #1136
civy123's Avatar
Jackson supplied a milled alt bracket with the kit to move the alt. 1/16" toward the tranny side of the engine to properly align the belt to the snout pulley. You will also need the crank pulley for this kit...
download the parts list for the D16Y8 kit and call Moss Motors to order the parts you need. The kits are as follows:
1996-98 = 989-200
1999-00 = 989-201
Old Jul 23, 2009 | 02:55 PM
  #1137
civy123's Avatar
It sound like you connected a coolant line to a vacumm port during your installation. Check your coolant level and double check your hose connections.
Old Jul 30, 2009 | 12:42 PM
  #1138
boosted_zc's Avatar
Anyone have any 3 rib pulleys for sale. i'm running the stock 4.0, i'll take anything smaller. Let me know what you have. Thanks
Old Aug 2, 2009 | 07:02 PM
  #1139
1996-98 = 989-200
1999-00 = 989-201
thanks for your help! the only Moss Motors I can find seem to deal with British cars.. I assume I've got the wrong one!!
I believe I already have the crank pulley, its just the alternator bracket I need
Old Aug 6, 2009 | 12:59 PM
  #1140
shandalo's Avatar
TRIAL USER
looking for a kit for a 98 civic, d16y7. pm me if you have a setup that will work. thanks for a great thread read btw guys.
Old Aug 9, 2009 | 10:12 PM
  #1141
Perkul8r's Avatar
Very curious about the Supercharger setup. Everyone in my area is running turbo, i wanna do something different. I'm staying with my D15B7, but doing a complete rebuild on it, Anyone know if they make a kit for that motor and where to buy one? if not, what do i need to put on together? thanks
Old Aug 10, 2009 | 06:59 PM
  #1142
byrne_06's Avatar
just puchased a jrsc kit for my y8 and im wondering if any one has the instructions for one, cause im not sure how the double pulley bracket mounts to the motor. thanks
Old Aug 13, 2009 | 09:24 AM
  #1143
civy123's Avatar
PM me your email and I can send them over to you. You can also find them by googling jackson racing 989-200 instructions
Old Aug 13, 2009 | 09:31 AM
  #1144
civy123's Avatar
Moss motors is known for mazda miata and british car parts but they have also taken over the Jackson Racing roots style superchargers. Try this site:
www.supercharger.com
Old Aug 25, 2009 | 08:05 PM
  #1145
spliftacus's Avatar
am supposed to be getting mine back this weekend. cant wait to see how it performs. d16z6 jrsc on 8psi! fingers crossed that everything runs right. will let yall know
Old Sep 7, 2009 | 05:19 PM
  #1146
does anyone know about intercooling? I'm not familiar with how to set it up compared to a turbo
Old Sep 8, 2009 | 08:43 AM
  #1147
Arcane's Avatar
Stock JR kits came with no intercooling. Due to the close proximity between the supercharger and the block, there is really no way to run a normal air to air intercooling setup.
JRSC guys have two options. The LHT Laminova water-air intercooler setup or water/meth injection. The cost/benefit of the LHT setup isn't great at all, given the prices LHT wanted. I asked about having them fab an intercooled m62 setup; I was told flat out NO.
So I've got the water/meth route.
BTW I've fixed my belt issues and the car holds 9-10psi all day long.
Old Sep 8, 2009 | 07:20 PM
  #1148
daveb91's Avatar
you tuning for the w/m???
Old Sep 9, 2009 | 06:41 AM
  #1149
Arcane's Avatar
Yes. The car will be tuned for w/m on Neptune. I'm just debating whether to run a smaller s/c pulley or not.
Old Sep 17, 2009 | 06:15 AM
  #1150
Arcane's Avatar
Has anyone adapted an automatic belt tensioner to our JRSC setups?
