The Official SOHC Supercharger thread...
Old Jul 28, 2010 | 11:35 AM
  #1301
mattliston's Avatar
Default Re: The Official SOHC Supercharger thread...
correct
thats why i said 250
an oem pump from a 6th gen can usually dish out 400whp for a while
250 is a little close to the edge, but still usable
BTW, I forgot to say, great number on an a6, it has low compression
Throw a d16y7 head on there to keep it nonvtec, but enjoy more flow, and more compression for more VTAKZZ KILLA POWAHZZZZ
Old Jul 28, 2010 | 01:19 PM
  #1302
Jaker's Avatar
I tried that. It didn't work. The ports on the Y7 head don't flow worth beans, and the OEM cam is even worse. I was seeing 25psi of boost with my Endyn M62 blower setup using the Y7 OEM head/cam. The boost couldn't get into the combustion chamber, and was backing up in the manifold. I'm on a Z6 head now with the Crower turbo cam, and the boost is down to 22 psi.
If you're set on non-Vtec, get a Y8 head and a Y7 head, and make a baby. Use the Y8 head casting, cam caps and valves/springs, etc..., but the Y7 rocker arms, rockers and some sort of reground Y7 cam with more lift and duration, and make a non-Vtec hybrid that'll flow decent.
Old Jul 28, 2010 | 01:33 PM
  #1303
mattliston's Avatar
I understand teh y8/y7 hybrid
I thought you were still on the A6 ehad, so from that, a Y7 would have been better.
Course, head porting would take care of the pressure problem
Old Jul 28, 2010 | 06:25 PM
  #1304
byrne_06's Avatar
Ya i have a y8 head to put on it. Were Hoping with with a new pump and y8 head we can make over 200 whp on the stock motor.
Old Jul 28, 2010 | 07:03 PM
  #1305
mattliston's Avatar
200whp sounds feasiable, but since you did this with a Z6 head, dont expect too much more.
the z6 (in stock form) has the best flowing D head.
Should be able to make more power earlier with the Y8 head, but your peak might only increase a small amount. The extra compression would have been nice, but it heats the combustion a tad more lol
Have you considered fabricating an idler setup, and making a water-to-air intercooler that bolts between the SC and the manifold adapter?
With the added cooling, some SC guys can hit 15+ more hp, but clearances in teh engine bay are of course even tighter
Old Jul 28, 2010 | 07:04 PM
  #1306
mattliston's Avatar
something like this but in a thinner, flatter scale
Old Jul 28, 2010 | 09:06 PM
  #1307
byrne_06's Avatar
you must have me confused with someone else, i have a stock d16a6 making this 178whp and i plan on putting a y8 head on it.
My plans are really this: But the 255 walbro in cause i have one laying around, put the y8 head on with arp head studs and cometic head gasket, get it retuned and hopefully make 200whp. Then daily drive it.
i just wanted something fun for this year .
Old Jul 28, 2010 | 09:37 PM
  #1308
mattliston's Avatar
my bad, lil confused lol
178 on a full a6 s an easy transition to 200 with the help of a y8
y7 valvetrain if you dont want vtec wiring or the need to do cam profiles tuning
Old Jul 29, 2010 | 06:03 AM
  #1309
byrne_06's Avatar
alright cool thanks
Old Jul 29, 2010 | 10:48 AM
  #1310
byrne_06's Avatar
hey when i mate a y8 head to a a6 block i use the y8 head gasket right ?
Old Jul 29, 2010 | 11:06 AM
  #1311
mattliston's Avatar
all 88-00 d15 and d16 headgaskets work
'thickness is what is different
z6 and y8 headgaskets are the thinnest, and produce the higehst compression
if you need lower comp, a d15b7 headgasket fits the bill.
considering we are talking only a few decimals of compression difference, go for the metal ehadgasket for a d16y8
find it on ebay
Old Aug 2, 2010 | 07:42 AM
  #1312
88B47MHF's Avatar
If anyone has a JRSC kit up for sale, hit me up on here via PM. Looking to get one ASAP. Thanks.
Old Aug 15, 2010 | 09:37 PM
  #1313
byrne_06's Avatar
Just installed the y8 head on my a6 block. before the head swap i made 179 whp and 160ft/lbs
looking to hit the 200 mark maybe a lil more would be nice
Old Aug 16, 2010 | 02:55 AM
  #1314
acura_el2000's Avatar
what other mods to the engine?
Old Aug 16, 2010 | 07:44 AM
  #1315
byrne_06's Avatar
Before
This is when it was a stock d16a6
Hpr Header with a stainless 2.5" exhaust
jrsc 9lbs crank pulley
short ram intake
aem fuel rail
Fic 550 injectors
converted to obd1
I made 179whp and 160ft/lbs on e85.
Around 5k the stock fuel pump started to get weak.
Now:
I installed a 255 walbro and y8 head
They say the y8 head flows alot better and i had it laying around
Hoping to get it tuned this week and break 200whp mark
This is my daily also lol
Old Aug 23, 2010 | 05:38 PM
  #1316
shane(showtime)'s Avatar
Broke the 200 mark with ease
https://honda-tech.com/forums/showth...14810&page=581
Old Aug 27, 2010 | 09:21 AM
  #1317
Dzanjin's Avatar
Got a 97 civic ex couple weeks ago, really looking into all possibilities for it. It's mostly stock - a brand new canvas :-)
What do you guys think about a sc in it? I'm trying to plan for the long run so I don't make the mistake of buying a bunch of crap only to engine swap or turbo or sc it later.
For quick reference the 97 ex has a d16y8 engine.
Old Aug 27, 2010 | 03:25 PM
  #1318
mattliston's Avatar
If you are thinking long term, go turbo. Long term to me= 5+ years
Old Aug 27, 2010 | 09:42 PM
  #1319
where can I pick up an upgraded boost pulley. looking for the 3.2 or 3.4 the standard one is 3.6 correct?
Old Aug 31, 2010 | 05:56 AM
  #1320
Dzanjin's Avatar
What I meant was I want to plan long term as in save most money for now and go with the best decision for most power.
ex: Save for a year and swap in a b series....or save up and get a turbo or sc.
OR should I keep it na and start slowly working on it with intake/exhaust etc. and work from there?
I've never owned a car for 5 years lol always sell before then.
I love this EX though...this will be my exception ;-)
Old Aug 31, 2010 | 08:16 AM
  #1321
mattliston's Avatar
turbo/supercharger will beat any b series, and a turbo setup can cost $800 and beat any b series setup with a full NA build
Old Aug 31, 2010 | 12:31 PM
  #1322
anyone? were can i pick up a higher boost pulley??
Old Aug 31, 2010 | 12:47 PM
  #1323
mattliston's Avatar
have one made
its cheap, probably cost $50
They only need to match the center where it mounts, and teh belt stlye
Doing this, I highly recommend using a bigger tensioner pulley to offset the higher risk of belt slippage
more tension MIGHT cause minor acceleration of belt wear, but it will stay boosting rather then slipping
A bigger crank pulley, well you should look into B series crank pulleys. Look up whetehr an N1 pulley works (Civic Type R with B16B 185hp motor)
Old Aug 31, 2010 | 12:52 PM
  #1324
mattliston's Avatar
Realize you CAN just find a bigger crank pulley that fits your belt type, say off a factory supercharged car, and you can amchine your crank to accept it
VERY risky since hodnas are internally balanced, rather then pulley/flywheel balanced
ITs a shame hodnas have such a limited supercharger field. Its the only non turbo way to get lots of useable power!
Old Sep 1, 2010 | 05:57 AM
  #1325
Arcane's Avatar
Stock blower pulley is 3.8".
