how much hp or psi are eagle h-beams good for
Re: how much hp or psi are eagle h-beams good for (gsrt2c)
ive heard from numerous engine builders that they are not to be trusted over 15 psi. if you want more than that get go crower, manley, pauter, something nice...
Re: how much hp or psi are eagle h-beams good for (BoostedSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedSOHC »</TD></TR><TR><TD CLASS="quote">ive heard from numerous engine builders that they are not to be trusted over 15 psi. if you want more than that get go crower, manley, pauter, something nice...</TD></TR></TABLE>
False info...it really depends on how its built...if built correctly, the H beams can hold up to 600hp! Just make sure you torque the ARPs up to proper specs and use the proper moly. You can even buy stronger ARP bolts for the Eagle rods...I am only boosting 12psi's due to other limitations in my setup...but once I get past htat barrier, I will be doing about 15psi (not daily though)
Re: how much hp or psi are eagle h-beams good for (MiraiZ)
My motor made 450whp on eagle rods, stock off the shelf with the smaller rod bolts. I wouldn't trust them anything over 500whp. Paul
Re: how much hp or psi are eagle h-beams good for (boosted3g)
I am going against everyone so it seems .. I run crower cams and eagle rods in my motor.. The rods have been in since day1 of my boosting career and I have never had a problem with them. The cams are a different story, but I will give crower the benifit of the doubt and am currently trying their 2nd gen of cams.. currently with absolutely no problems.
I am a bad person
Re: how much hp or psi are eagle h-beams good for (GSRev)
some more info on breaking eagles. all motor broken rods>>>
https://honda-tech.com/zerothre...28622
i run eagle rods everyday and make 536 to the wheels and i have never had a problem yet raced it enough to push them to the limits i might even try another 2-3 pounds to see if i can get closer to the 600 mark depends on the motor builder done the right way the have no problem
