Would this setup be able to achive 400 hp at 15psi
Old Jan 24, 2004 | 08:15 PM
Black DC2's Avatar
Default Would this setup be able to achive 400 hp at 15psi
is a 98 b18c1
setup is
9-8-1 je pistons eagle rods and a GE blockguard
max rev manifold sc61 76 trim
580 injectors hondata s200
3 inch thermal cat back
looking to make 400 at most is not sleeved so i really don't want 2 go 20 psi to
achieve my goal
Modified by Black DC2 at 12:51 AM 1/25/2004
Old Jan 24, 2004 | 08:16 PM
99blackcivicSi's Avatar
Default Re: Would this setup be able to achive 400 hp at 15psi (Black DC2)
To many factors involved but i would have to say yes it will be pretty close. make sure you have the good rod bolts though
Old Jan 24, 2004 | 08:26 PM
boosted_dc2's Avatar
Default Re: Would this setup be able to achive 400 hp at 15psi (99blackcivicSi)
the high compression may get you there with good tuning, but to go conservative on the tune and be safe i doubt youll get there. im going to run 9.3:1 sleved with 15 psi with a sc61 and am only looking for 350 at most.....
Landon
Old Jan 24, 2004 | 08:28 PM
Black DC2's Avatar
Default Re: Would this setup be able to achive 400 hp at 15psi (boosted_dc2)
i just got the regular rod bolts that come wit hthe eagle rods
Old Jan 24, 2004 | 08:57 PM
BoostedSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black DC2 &raquo;</TD></TR><TR><TD CLASS="quote">i just got the regular rod bolts that come wit hthe eagle rods </TD></TR></TABLE>
eagle rods come with arp bolts and yes, they are fine.
Old Jan 24, 2004 | 09:01 PM
Default Re: Would this setup be able to achive 400 hp at 15psi (BoostedSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedSi &raquo;</TD></TR><TR><TD CLASS="quote">
eagle rods come with arp bolts and yes, they are fine.</TD></TR></TABLE>
you do know that there are differant kinds of ARP bolts right? just saying. if they are the new ones i beleive they upgraded the bolts so you should be fine
Old Jan 25, 2004 | 02:26 AM
Distorted's Avatar
Fear detonation if your unsleeved. At that compression with the turbo your using flowing as much air as it will at 15psi, your going to be taking the risk of destroying a cylinder wall upon any sustained detonation. Good chance you can do it with careful tuning, personally id recomend patience and sleeving as if your shooting for 400whp you wont regret the wait and the money spent for the piece of mind and ability to push it further if you so wish, but hey, if you do it thats awesome man, love to see someone else run good tuning on stock sleeves.
Good luck
Old Jan 25, 2004 | 03:30 PM
Black DC2's Avatar
Default Re: Would this setup be able to achive 400 hp at 15psi (Distorted)
i would love 2 see it 2
dutch@69
Apr 15, 2006 01:34 PM
quicksol95
Dec 29, 2004 02:17 PM
94B18B1Teg
Feb 10, 2004 11:03 AM
JunIntegra
14
Oct 29, 2003 01:12 AM
Halo
Dec 2, 2001 08:24 AM
