Holset users unite!
Old May 22, 2005 | 01:43 PM
  #126
Jockobo's Avatar
Default Re: (95cxh22a)
if you remove the internal wastegate section where can you find a flange to build a dp off of? it looks like a standard 5 bolt...is it anything close to that?
Old May 22, 2005 | 02:51 PM
  #127
drumking15's Avatar
just get a 3" vband its so much easier...
Old May 24, 2005 | 05:59 AM
  #128
drumking15's Avatar
Holset snail rebuild kits
http://cgi.ebay.com/ebaymotors...=WDVW
Old May 24, 2005 | 10:23 AM
  #129
Paul_VR6's Avatar
Default Re: (drumking15)
Hey if anyone has a spare 16cm^2 turbine housing shoot me a PM. Need one for another install on a 6cyl
Old May 24, 2005 | 02:14 PM
  #130
drumking15's Avatar
finally open'd up the 3" dp...
oooo its mean
lil damp around here today and traction was a problem...
1st & 2nd are just sick...anything over 1/4 yes 1/4 throttle i was all over the place wheel hop etc...
3rd spikin to 14psi w/ a 38mm gate set for 7.5psi..2nd holds 10 untill the break loose....
and its ****** insanely loud! race car backfires...ooo im loving it!
Old May 24, 2005 | 03:05 PM
  #131
DragSource's Avatar
When are you seeing full boost by drum?
Old May 24, 2005 | 05:10 PM
  #132
drumking15's Avatar
heh it comes on so fast i really cant tell...
open dp
2nd gr 3800-4000 7-10psi
3rd gr 4-4200 7-10 psi and climbing...spikes to about 14 after i loose traction...
closed dp...restricted down to 1.8" stock exhuast
about 4300-4500 full boost 7psi 2nd & 3rd
Old May 24, 2005 | 05:14 PM
  #133
DragSource's Avatar
I'm just trying to get a general idea.
I'll be running it on an 83mm LS. . p&p, camed, etc - but I have a feeling it's going to be a fight to stay in boost with my ability to rev high still being hindered a bit. (I'll probably go to 8.5k max)
Seeing a good deal of boost by 5k?
Old May 24, 2005 | 08:53 PM
  #134
95cxh22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">heh it comes on so fast i really cant tell...
open dp
about 4300-4500 full boost 7psi 2nd & 3rd</TD></TR></TABLE>
video video video
Old May 25, 2005 | 09:28 AM
  #135
DragSource's Avatar
open dp
This gives me hope
Old May 25, 2005 | 11:07 AM
  #136
dodgywrx's Avatar
this is my first post on hondatech, i have had no real reason to try to contribute anything to the honda world because I know nothing about them, but, I do know alot about what you guys are talking about right now which is the holset turbo, and have been actually using it on my current car for a little while now.
I bought the holset hy35 for my WRX which is a turbo that not too many of you (if any) have put on your hondas.
its a 2.4 liter motor with all the goodies inside, 8.3 to 1 compression, revving only to 7000RPMs with all the boltons and also management and fuel needed.
I have been doing alot of tuning for the last little while, making it run well on the car, and I can say that I am SO damn impressed!!
at 10 psi its faster than my old 62-1 at 10 psi
my 62-1 was 10 times laggier with the smallest housing turbonetics could sell me for the P trim wheel which was .58 a/r. I was seeing 20 psi at about 5500-6k
at 18 psi its running better than my 62-1 did at the same boost, the difference is that this turbo can go up to 35-40 psi and remain within its compressor map.
Im seeing 7 psi at 3k 14psi at 3500 rpms, and at just under 4k I have 18-20 psi. I have not had it at the track yet, or on the dyno, but its making really good power at just about 1.1 bar. with 3200 lbs of weight Its hitting 60 in about 4 seconds, and running up to 100 in 11 seconds or so. Im planning on turning it up to 25 on 100 octane, and hopefully that will net me alittle over 420-450 whp. (550 or so at the flywheel)
Anyways, I just wanted to post up my experience with this turbo and I hope that some of you might be able to use this info.
Another thing that I wanted to post, for you guys who want the fastest spool up possible, this company, http://www.bullseyepower.com sells a turbine housing for these with t25 inlet and basically mitsu downpipe, with t3 and also t4 flanges, that are the equivelant to 6/7 cm versus the larger 9 and 12 cm housings. These would be very viable options for the 1.5-1.6 guys wanting good spool up.
that housing has made 500 whp with hx35 turbos on eclipses and 600 with the hx40 compressor wheel and housing.
Old May 25, 2005 | 11:09 AM
  #137
dodgywrx's Avatar
heres a pic of the turbo installed in my car http://memimage.cardomain.net/...l.jpg
Old May 25, 2005 | 12:40 PM
  #138
95cxh22a's Avatar
Default Re: (dodgywrx)
nice pic, good to see some variety also
and we do appreciate your information.
Old May 25, 2005 | 01:22 PM
  #139
prelittlelude's Avatar
Default Re: (DragSource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource &raquo;</TD></TR><TR><TD CLASS="quote">
This gives me hope </TD></TR></TABLE>
his car was freakin mean,, though that spike to 14 kinda worried me , even when he had just the the block off plate still on and then t off to the stock exhaust but runing open right before the stock cat we saw it creeping to about 10 psi..
Old May 26, 2005 | 03:53 PM
  #140
soon2brb240's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dodgywrx &raquo;</TD></TR><TR><TD CLASS="quote">this is my first post on hondatech, i have had no real reason to try to contribute anything to the honda world because I know nothing about them, but, I do know alot about what you guys are talking about right now which is the holset turbo, and have been actually using it on my current car for a little while now.
that housing has made 500 whp with hx35 turbos on eclipses and 600 with the hx40 compressor wheel and housing. </TD></TR></TABLE>
Thanks for the GREAT info man! I actually have an hy35 in my garage right now, waiting to be put on my 1.8 non-vtec honda. I'm only hoping for a max of 300whp when tuned, so i'm sure this turbo will be just great for me. Have you got any vids or sound clips of your car in action?
Also, along the lines of my turbo progression, I found that I need to clock the hy35, and am not entirely sure how to do it. I'm in the process of getting an aftermarket crossmember/traction bars for my DA, and a civic half size radiator, this is a big turbo. Anyway, thanks for the post, and keep the good info coming!
BTW, if anyone can get me a deal on a crossmember for my car, send me a pm...Thanks
Old May 26, 2005 | 03:58 PM
  #141
drumking15's Avatar
clsoking it is cake...loosen the clamp/bolts on the exh or compressor housing and rotate
Old May 26, 2005 | 04:25 PM
  #142
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">clsoking it is cake...loosen the clamp/bolts on the exh or compressor housing and rotate</TD></TR></TABLE>
Yea, the thing is though, on the hy, there aren't any "bolts" on either side. The turbine side is held on with a vband clamp, and it looks like the compressor housing is held on by a huge snap ring. The ring is kinda rusted, so I soaked it in wd40, we'll see if it comes off when I try to get it off in a few days.
Old May 26, 2005 | 05:23 PM
  #143
95cxh22a's Avatar
Default Re: (soon2brb240)
try pb blaster
Old May 26, 2005 | 06:39 PM
  #144
dodgywrx's Avatar
youll have to compress the snap ring on the compressor if youve got to clock that part, otherwise, if you only ahveto clock the turbine, just loosen that vband clamp and turn. I had to hit mine with a hammer till it turned, and mine was a really newish turbo..
on the vids, yes, I have some 0-100 0-130, some roll ons and a few full boost launches with the good ole auto trans, but my frind has no way to put them on his computer. he tells me hes just got to buy a wire to go from the cam to the computer, but he has yet to do that.
this turbo spools better every time I tune, Im seeing 20 psi at about 3600 in fourth gear now.
Old May 26, 2005 | 07:34 PM
  #145
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dodgywrx &raquo;</TD></TR><TR><TD CLASS="quote">this turbo spools better every time I tune, Im seeing 20 psi at about 3600 in fourth gear now.</TD></TR></TABLE>
Amazing...and yea, all I have to clock is the compressor side, so, i'll get to work
Old May 28, 2005 | 04:28 PM
  #146
drumking15's Avatar
wow its nice drvign around w/ dry roads...1st day in 2 weeks...traction is nice!
Old Jun 3, 2005 | 04:47 PM
  #147
drumking15's Avatar
how are you guys doin w/ your setups?
Old Jun 3, 2005 | 05:28 PM
  #148
DragSource's Avatar
Working hour 70 hour weeks now. . . yeeeehaw - I'm delusional, but I'm stacking my chips for the remaining $2500 I have to spend.
I'll be hx'ing it in no time @ this rate
Old Jun 3, 2005 | 07:21 PM
  #149
LoSt is BlaCk's Avatar
i just need to paypal the guy for mine...
keep the updates come'n
Old Jun 3, 2005 | 08:23 PM
  #150
drumking15's Avatar
great deal for all you peeps who still need a snail
no flange either just straight vband...ooo so sexy
