Holset users unite!
Old Sep 4, 2005 | 09:51 AM
  #351
rhd's Avatar
rhd
Default Re: (_Morphius_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Morphius_ &raquo;</TD></TR><TR><TD CLASS="quote">http://www.superhonda.com/tech....html
I don't see a B18C5 making 210.
Make an apples to apples comparison. Non-Vtec 2.0L DOHC to Mits 2.0L DOHC.
Honda-126-143HP. Mits-135. Again, I simply asked for a link to cylinder head flow for hondas. </TD></TR></TABLE>
ok...stock 96 ITR head flowed 256cfm
Old Sep 4, 2005 | 10:49 AM
  #352
_Morphius_'s Avatar
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">
ok...stock 96 ITR head flowed 256cfm </TD></TR></TABLE>
Stock 90-94 DSM 2.0L DOHC head (tested by polk performance)
Lift CFM
.050 48.91
.100 94.21
.150 139.62
.200 181.24
.250 216.94
.300 241.11
.350 261.52
.400 271.14
.450 280.45
Who's motor flows more?
Old Sep 4, 2005 | 11:05 AM
  #353
rhd's Avatar
rhd
hmm..giant square ports..
but either way...honda enges are much more effiecent. considering all vtec engines are over 110% VE, we can get away with bigger turbos
Old Sep 4, 2005 | 11:43 AM
  #354
kasso's Avatar
Default Re: (drumking15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">and kasso if youd ever taken a ride in my teg...youd never wanna see an rsx...theyre slow pigs...unless moded...</TD></TR></TABLE>
thats the kind of motivation i need
my car already pulls really hard non turbo on 9.7:1 dished pistons and ls tranny. just put my bid for the h1c. ill probably run it compressor on driver side.
ps: what would be the advantage if i had a manifold made that joins runners 1 and 4 and 2 and 3 for the twin scroll?
Old Sep 4, 2005 | 11:55 AM
  #355
LoSt is BlaCk's Avatar
Default Re: (kasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kasso &raquo;</TD></TR><TR><TD CLASS="quote">
ps: what would be the advantage if i had a manifold made that joins runners 1 and 4 and 2 and 3 for the twin scroll?</TD></TR></TABLE>
a true twin scroll will give you an even faster spool time
Old Sep 4, 2005 | 01:05 PM
  #356
drumking15's Avatar
yep faster spool...but ill tell you this boost just comes on so quick...its sick...i think the most satisfying result of my project...is that i can go out and blow by kids who have dumpted 10-20g's into their cars...and i built mine all myself w/ my own research etc...i stepped off the beaten path in the footteps of dsms...and ran a holset...the best part of it all at the last meet we had...a dodge truck pulled a trailer in w/ a honda...i asked him to pop the hood...and showed the comparision...of takin his turbo and movin it to my honda...everyone got a kick outa that...and ive been couped up inside all day...i think its time for a full boost run...be back in a few...hopefully i dont get pulled over...knock on wood
Old Sep 4, 2005 | 04:41 PM
  #357
sqad_7's Avatar
does anybody know if the A/R's on any of the holset turbo's?
Old Sep 4, 2005 | 10:34 PM
  #358
Root79's Avatar
Default Re: (sqad_7)
Have question about stock H22A engine. For safe tuning I'm looking for some good pressure ratio in manifolds. If 14 psi intake manifold then not more than 6psi in exhaust manifold. For H22A stock stroke and stock compr. rate.
Which Holset turbo do I need to looking for?
Thank's
Old Sep 4, 2005 | 10:36 PM
  #359
wantboost's Avatar
Who is Mr Robot?
Default Re: (Root79)
sorry for my shitty spelling but im shitfaced rightnow (16 beers or something.. i dont remember too well)
you could go with like an h2c or something, but it might be a tad bit laggy. you could go with an hx40, it would give a nive powerband
Old Sep 4, 2005 | 10:38 PM
  #360
Root79's Avatar
Default Re: (wantboost)
Thank's
16 beers How much voltage?
Old Sep 4, 2005 | 10:40 PM
  #361
wantboost's Avatar
Who is Mr Robot?
lolol. i can barely tyoe, cant walk or sit ujp, cant walka straight line or talk so id guess about 120 volts at least y0, lol
Old Sep 5, 2005 | 06:49 AM
  #362
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 &raquo;</TD></TR><TR><TD CLASS="quote">Have question about stock H22A engine. For safe tuning I'm looking for some good pressure ratio in manifolds. If 14 psi intake manifold then not more than 6psi in exhaust manifold. For H22A stock stroke and stock compr. rate.
Thank's </TD></TR></TABLE>
id go w/ what wantboost suggested... a hx40 w/ a fairly big housing...16-18cm to controll wheelspin...
gettin drizzy nothign beats its...
speculated a/r's on holsets:
hx35
w/ divider about a .55 a/r
w/ divider removed about a .63 a/r
Old Sep 5, 2005 | 07:38 AM
  #363
sqad_7's Avatar
do you have any A/R's on the Hy35 or the HX30?
Old Sep 5, 2005 | 10:50 AM
  #364
drumking15's Avatar
the hy im willin to bet is around a .45...its a 9cm housing...about 3cm smaller than the hx35....and the hx30 i have no clue....
Old Sep 5, 2005 | 12:16 PM
  #365
Si Shane's Avatar
i was under the impression 12cm2~.7-.8 and the 9cm2 was around .6
Old Sep 5, 2005 | 12:33 PM
  #366
drumking15's Avatar
i actaully am takin my facts from a user who used this turbo back in the day...kinda gave me inspiration to go this route...he actually sealed off the housing and measured it....
and the boost response of it...being a .82 etc...seems way to big for how well it responds to my lil ls/vtec....god i love my car...its really startin to scare the **** outa me...4th gear redline pull...w/ ice in the air/water resivior...i was seeing intake temps around 70ish...w/ ambient about 85....thing is all ballz...im just awaitng the cops showin up to my house now....the only place long enough and staight enough is going by this autoshop...wizzin by at about top of 3rd...and its loud as fauck...i am so eager to finally get crome running again so i can up the boost to 15psi...that when **** is gonna start breaking....and ill seriously start consdiering an lsd...this troque steer crap is is drivin me mental!
Old Sep 5, 2005 | 09:42 PM
  #367
sqad_7's Avatar
sounds nice. Your running a Hx35 right?
Old Sep 6, 2005 | 03:57 AM
  #368
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sqad_7 &raquo;</TD></TR><TR><TD CLASS="quote">sounds nice. Your running a Hx35 right?</TD></TR></TABLE>
yep
if i only had a camera...i could sho wyou how mean this turbo really is!
hopefully gettin some track time w/ someone video taping...that'll really show you how capable this turbo is...
Old Sep 7, 2005 | 11:26 AM
  #369
KeyserSoze's Avatar
Wahooo, this guy at work has a 03' dodge with a manual tranny and upgraded his turbo a couple of years back. He said that I could have his old stock holset for free. Anyone know which holset came on an 03' dodge with a manual tranny??
Old Sep 7, 2005 | 11:56 AM
  #370
Paul_VR6's Avatar
Default Re: (KeyserSoze)
Um, take it anyway
Pretty sure by '03.5 they were using some different stuff, so depending on build date it's either an HX35 like everyone else is using, or something FUNKY.
Old Sep 7, 2005 | 12:03 PM
  #371
KeyserSoze's Avatar
Default Re: (Paul_VR6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul_VR6 &raquo;</TD></TR><TR><TD CLASS="quote">Um, take it anyway
Pretty sure by '03.5 they were using some different stuff, so depending on build date it's either an HX35 like everyone else is using, or something FUNKY.</TD></TR></TABLE>
Lol, of course I'll take it no matter what it is! I'm just tryin to concieve a gameplan so I can know what I need to prep for.
Old Sep 7, 2005 | 04:47 PM
  #372
drumking15's Avatar
from searchin around...im willin to bet its a hx35
Old Sep 7, 2005 | 05:05 PM
  #373
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">from searchin around...im willin to bet its a hx35 </TD></TR></TABLE>
THAT'S what I want to hear. Thnx.
Old Sep 8, 2005 | 07:25 PM
  #374
rorik's Avatar
What is the a/r on an hx40? Do they come with different turbine housings like the hx35?
Old Sep 9, 2005 | 05:01 AM
  #375
wantboost's Avatar
Who is Mr Robot?
Default Re: (rorik)
i'm looking into having an hx60 hybrid made, with an hx40 or 35 turbine side
