turbo oil feed line on b18c1
help could i use the oil line off the head on the gsr next to the vtech solenoid and how much oil pressure suppose to be there ??
Re: turbo oil feed line on b18c1 (newstyd)
I personally wouldn't use that as a source for an oil feed line for the turbo sence there is only oil pressure there when vtec comes on but I could be wrong..
Adi
Adi
Re: turbo oil feed line on b18c1 (newgsr)
we have Golden Eagle Turbo Oil Feeds in stock with many different fittings and can make Aeroquip SS lines upon requests too
Re: turbo oil feed line on b18c1 (intercooledJRSC)
Don't tee off block by vtec solenoid!!
You need to tap into oil sending unit on back of block near bottom, sorta down and to the left of oil filter.
Contact Flamenco_T aka Stan for oil feed and return lines. Good guy, very helpful, good prices and shipping.
Re: turbo oil feed line on b18c1 (mike1114)
there isn't a whole lot of pressure fromt he VTEC solenoid to supply the oil to the turbo, you'll have a good pressure coming off the oil pressure sending unit on the back of the block
stan
stan
