oil line
Old Nov 27, 2001 | 09:16 AM
lswithvtec's Avatar
New User
Default oil line
hey there i am planning to turbo mine ls/vtec motor.. and i was wonder how r u guys running ur oil line to the turbo? thanks alot.
Old Nov 27, 2001 | 09:20 AM
Flamenco-T's Avatar
Default Re: oil line (lswithvtec)
get a 1/8" npt tee fitting, and screw that in the factory oil pressure sender, then screw in the factory oil pressure and tee the other line using a -4an to 1/8" npt union and run the -4an line to the turbo...
Old Nov 27, 2001 | 10:11 AM
lswithvtec's Avatar
New User
Default Re: oil line (Flamenco-T)
yah i knoe.. i arlite got that tee off.. remember i am ls vtec. so that is tee off for mine oil line to the vtec head. i was wonder can i tap it when the head is at where the allen copper key near the distributor? if i tap it there i have hear that it might not give enought oil for the turbo or that it will not give enought oil for the vtec to active. or can i run a other fitting at the back of mine block so i will have 2 lines commin off the oil pressure? do u think that will work??
Old Nov 27, 2001 | 11:06 AM
b18b98's Avatar
either way will give more then enough oil for the turbo...
madcrx69
Apr 17, 2010 05:31 AM
allanonjj
Oct 19, 2006 11:18 AM
GaVO311
Sep 12, 2006 08:30 PM
newstyd
Jun 16, 2003 10:56 AM
DR. ON POINT
Sep 19, 2002 09:31 AM
