The Fight for Traction...
Old Jan 11, 2005 | 03:33 PM
B00STED Si's Avatar
Default The Fight for Traction...
Hey, im looking for some advice on getting traction. I currently am running falken azenis 205/50R15 on my stock Si wheels, which are pretty decent tires as well as an Eibach pro kit and KYB AGX Adjustable struts/shocks. First gear @ 8 lbs of boost is worthless, and i wheel hop or spin all the way through second. 3rd gear is fine @ both 8 and 12 lbs of boost. I dont even bother bumping up the boost though lower than 3rd gear cuz i cant even hit it @ 8 lbs. Im not sure what i can do, if there even is anything i can do, to get traction. Someone i work with was telling me taller gears, but im not sure. Anyone in my situation and do anything about it? or can i only race from a 50 roll...
Old Jan 11, 2005 | 03:42 PM
eddyboy's Avatar
Default Re: The Fight for Traction... (B00STED Si)
Here are a few options.
LSD
Motor Mounts or Inserts
Traction Bars
Gear/Speed dependent boost controler.
Your "right" foot
All will help with your tractions issues. Obviously the last option would be the cheapest.
Old Jan 11, 2005 | 03:49 PM
hondaguyef's Avatar
Race from a roll on the street and Get some slicks for the track.
Phil
Old Jan 11, 2005 | 04:06 PM
93turbo16's Avatar
Default Re: The Fight for Traction... (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Race from a roll on the street and Get some slicks for the track.
Phil</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddyboy &raquo;</TD></TR><TR><TD CLASS="quote">
Your "right" foot
Obviously the last option would be the cheapest. </TD></TR></TABLE>
I believe my friend runs traction bars and they knocked a few tenths off his 60ft.
Old Jan 11, 2005 | 04:13 PM
The Destroyer's Avatar
Default Re: The Fight for Traction... (93turbo16)
I personally will be getting the FR Traction bars. Better 60fts, and more room in my engine bay.
Old Jan 11, 2005 | 04:17 PM
turbosi03's Avatar
ahhh, god damit... I was planning on using my Si rims with the same tires
I have inserts right now but I was thinking of just getting new motor mounts. I wonder how much of a difference that makes for traction? not trying to thread jack or anything...
Old Jan 11, 2005 | 05:20 PM
mildly.interesting's Avatar
225/50/15 BFG G-Force Drag Radials are absolutely bar-none the best investment I have made in my setup. When you don't spin in the top of every gear, you wouldn't believe how much faster you can be...
Old Jan 11, 2005 | 05:29 PM
MrSmith's Avatar
Default Re: (mildly interesting)
Camber settings are also important imo. If youre low with with 2-3 degrees of negative camber you wont get the full contact patch of the tire on acceleration.
Old Jan 11, 2005 | 05:37 PM
GSC Motorsports's Avatar
Default Re: (MrSmith)
replacement motor mounts (not just inserts) big help
traction bars big help
James Innes
Old Jan 11, 2005 | 06:27 PM
1.8tgsr's Avatar
I would say Motor Mounts and BFG drag radial help out majorly! I have the Hasports in my 2000 GSR-T with 205/50r15 radials and no more wheel hop! and as for spinning I spin in 1st but feather the gas until traction and then 2nd gear grabs with no spinning. Before those two, I'd spin all through 1st, 2nd, and halfway through 3rd. Also, tractions bars would be an awesome and great investment!
Old Jan 11, 2005 | 08:11 PM
B00STED Si's Avatar
Default Re: The Fight for Traction... (1.8tgsr)
thanks guys, looks like im getting some new motormounts/traction bars and drag radials by the spring.
1.8tgsr - i see youre in laurel, md. where are some good spots around here for cruising or meeting up? other than ritchie hwy and glen dirrty.
umair
Oct 30, 2010 07:01 AM
lsrcrvtec
Jun 7, 2009 06:29 PM
LST2
Sep 11, 2007 06:02 AM
DLB1994
Sep 27, 2003 11:34 PM
ludelvr
Jun 24, 2002 12:31 AM
