traction
Old May 30, 2009 | 03:30 PM
lsrcrvtec's Avatar
Default traction
i have an ek with 320hp and i cant get my first or second gear to grip, is there a good tire that will hook without having to go 235/60/15. i have traction bar and my tires are 205/50/15 bf drag radials. thanks h-t.
Old May 30, 2009 | 04:18 PM
nfereorhatch's Avatar
Default Re: traction
225/50/15?
Old May 30, 2009 | 04:19 PM
lsrcrvtec's Avatar
what brand?
Old May 31, 2009 | 07:44 PM
Topdawgg's Avatar
one of your only options would be to get a good fuel management or good boost controller that allows you to boost per gear or boost per mph.. That way you can limit the boost out of the hole and then step it up in a higher gear..
Why would you wanna hammer 1st and 2nd without slicks on anyways... doin some street racing are ya?
Old May 31, 2009 | 08:28 PM
tegman23's Avatar
Welcome to having a turbo fwd with a decent amount of power lol......get a good boost controller and setup boost by gear, thats about all you can do
Old May 31, 2009 | 08:44 PM
BoostnEK6206's Avatar
i have a boosted gsr ek and i dunno what numbers i put down but ran a 12.17 on nine pounds. and with lsd i dont even hook in first and second. its just gonna happen.
Old Jun 1, 2009 | 04:13 AM
bigdgsr's Avatar
My 400hp DC2 hooked 2nd gear on running MT 205/50/15 drag radials, full race traction bars, ITR LSD, and stock mounts. I had a pair of 205/50/15 BFG drag radials before and the car wouldn't hook until 3rd gear.
Old Jun 1, 2009 | 05:01 AM
EddieCRX's Avatar
Keep saying this, haven’t you guys herd of Race Logic traction control, google it and see what peole have to say.
http://www.racelogic.co.uk/?show=Traction_Control
It’s perfect for road use, totally programmable unlike factory systems. You can even put down power in the wet if programmed properly.
This saves tyres, equally it will perform better with good tyres, if you go to the track, switch it off, simple, not invasive but will modulate the power instead of working the right foot.
I tried boost by gear soft compound tyres that last no time on the street.
Old Jun 4, 2009 | 05:01 PM
lsrcrvtec's Avatar
ok thanks for the help, lmk h-t if i should go with 235/60 mt ET Street Radial I or 225/50mt ET Street Radial II thanks. i'ill be making 4xxhp soon.
Old Jun 4, 2009 | 05:32 PM
marcj's Avatar
a laggy turbo helps
Old Jun 4, 2009 | 06:54 PM
boosted91crx's Avatar
the answer is simple feather the throttle, lift a little, there is no rule that says you must be WOT the entire time. i have 510 whp in a EG on 205 40 16s and i do just fine on the street.
Old Jun 4, 2009 | 07:14 PM
tegman23's Avatar
Good point craig..Even at the track for me last year, 1st and 2nd gear never was full throttle really, was feathering the gas trying to get it to hook..
Old Jun 4, 2009 | 09:56 PM
TheoneTheycallVille's Avatar
boost by gear for sure!!
Old Jun 5, 2009 | 04:18 AM
Topdawgg's Avatar
Originally Posted by marcj
a laggy turbo helps
how do you find that?
not on a vtec motor...
Vtec and full boost at the same time = even less traction
Old Jun 5, 2009 | 06:51 AM
96 GSR-T's Avatar
If you want to dead hook 1st gear go buy a Mustang
Old Jun 5, 2009 | 07:58 AM
marcj's Avatar
^ truth
Old Jun 5, 2009 | 11:04 AM
92EGminihatch's Avatar
plz dont buy a mustang. yuck. just get some amazing tires and boost by gear.
Old Jun 5, 2009 | 06:50 PM
lsrcrvtec's Avatar
to have it boost by gear do i have to take it to my tuner or can i buy something online? let me know more info on boosting by gear? thanks for the help h-t.
Old Jun 5, 2009 | 07:37 PM
tegman23's Avatar
What engine managment are you running? program like hondata s300 you can do boost by gear...You should probley take it to your tuner as well, there is some ecu work to be done also
Old Jun 6, 2009 | 07:07 PM
lsrcrvtec's Avatar
chrome
Old Jun 7, 2009 | 06:16 AM
96 GSR-T's Avatar
Originally Posted by lsrcrvtec
crome
fixed that for ya
Old Jun 7, 2009 | 03:59 PM
dantamparacer's Avatar
mt 205/50/15 drag radial and hope your axles hold up to the punishment
Old Jun 7, 2009 | 04:56 PM
amimaxima's Avatar
modify your ecu to accept a boost solenoid do boost by gear, setup your suspension right and get some mt et drags
Old Jun 7, 2009 | 05:32 PM
Ultimat777's Avatar
any one have any experience on that racelogic system on a honda/acura?
Old Jun 7, 2009 | 06:29 PM
bada9's Avatar
a 2-step rev limiter would help for your launches as well
heetstroke
Jan 27, 2012 08:26 PM
umair
Oct 30, 2010 07:01 AM
dirtySOHC's
Aug 18, 2005 06:50 PM
B00STED Si
Jan 11, 2005 08:11 PM
