Need some quick help
Old Jan 11, 2005 | 10:38 AM
adictionbass's Avatar
Default Need some quick help
Whats up guys? Im in the middle of putting my rc 750 injectors on my edelbrock intake manfiold (stock fuel rail) and having some trouble. I switched over the studs from the stock gsr intake manifold and everything was going fine until i got the injectors in and when to bolt on the fuel rail. The studs arent long enough?!?! The injectors are fully seated in the fuel rail, and in the intake manifold. Am i doing something wrong, or do you have to put different studs/bolts in? TIA, josh
Old Jan 11, 2005 | 10:40 AM
underpressure02's Avatar
Default Re: Need some quick help (adictionbass)
Are you sure they are all the way in? I put msd 756 in my b16 head and had no issues at all.
Old Jan 11, 2005 | 10:42 AM
93turbo16's Avatar
pictures speak a thousand words sometimes. Maybe just get longer studs.
Old Jan 11, 2005 | 11:14 AM
Default Re: (93turbo16)
yea i know i need pics, i have my cam, but i dont have the program or the connectors here at my dads to put them on the comp.
Old Jan 11, 2005 | 11:16 AM
Default Re: (adictionbass)
Should be fixed. I back out the studs 3 or 4 threads, enough to get the nut started. Put it all back on, and torqued it down. I did 10 ft lb with a deep socket... should be good. Had no idea those little gromets would compress that much. Thanks
Old Jan 11, 2005 | 11:36 AM
93turbo16's Avatar
lol yea. Nice little fix.
Old Jan 11, 2005 | 07:56 PM
well since i started this, i figured id post pics of it together, and some other pics from the day.
Anyone want a gsr intake mani and/or injectors?
This is how the injectors ended up being seated.
This is how a real man does wiring...
In here:
And out here:
BTW, anyone have a quick fix for this???
Old Jan 11, 2005 | 08:05 PM
T4eg's Avatar
the fuel pressure regualtor of certain 90-93 integras the part the the return line goes to is bent as 90degree angle. Thats what i was using while i ran the stock regulator.
Chris
Old Jan 11, 2005 | 08:18 PM
SkRiBLaH's Avatar
Default Re: (BlueHatch00)
you gotta flip the regulator upside down. derrrrrr
Old Jan 11, 2005 | 08:21 PM
Default Re: (SkRiBLaH)
that'll work... derrr. Just didnt put much thought into it
98civtec
May 14, 2009 05:47 AM
aznboi_2
Oct 22, 2008 10:47 PM
vaporboy12
Oct 26, 2004 03:21 AM
AzntaggeR
Apr 3, 2004 07:30 PM
aemciv
Mar 24, 2003 10:54 PM
