Most you would boost without tuning??
Old Jun 25, 2003 | 03:17 AM
tampabud's Avatar
Default Most you would boost without tuning??
I live in Germany, and there is not a single dyno anywhere within a days drive.
I currently have a stock EM1 that will be boosted SOON. Engine management:VAFC hack. I also have 255lph fuel pump and 440cc injectors goin in. Whats the most you think I could boost safely?? Turbo kit is from SFP, the regular t3/t4 intercooled combo etc... Skunk2 IM Skunk2 exhaust already on the car. Leave your opinion please.
Old Jun 25, 2003 | 03:41 AM
freakie's Avatar
Default Re: Most you would boost without tuning?? (tampabud)
0 psi. Dont boost until u can tune on the dyno and on the road. unless u want to buy a new motor
Old Jun 25, 2003 | 03:49 AM
ekb18c's Avatar
ZERO psi...
Old Jun 25, 2003 | 03:53 AM
swlabhot's Avatar
Get some sort of a/f monitor if you don't have a wideband. Mine is untuned at 8-9psi on hack.
Old Jun 25, 2003 | 04:34 AM
tampabud's Avatar
For guages I have Greddy electric boost, exhaust temp, oil pressure, fuel pressure. What should I be looking for to ensure no detonation. There have been several people in the local area who have gone the forced induction route without problems. However, they have all been posted back to the States, and the only other person who is boosted I can't rely on for good advise...
Old Jun 25, 2003 | 04:37 AM
PM-Performance's Avatar
Default Re: (tampabud)
i wouldnt boost at all untuned.
Old Jun 25, 2003 | 07:53 AM
mamaboy's Avatar
you maybe running abit too rich....but if it was me I'd go on ebay and get my hands on a cheap Vortech FMU with a 12:1 disc and install that ...keep your stock injectors...and disconnect your VAFC just for the moment.....and drive to wherever your going....$40-50 isn't too bad if you think about it....and sell it back on ebay......get a missing link as well.....install that back on when you get there and tune it out on a dyno with a WB02..and install the intank and drive it to wherever you can tune the SOB.....boost as little as possible....
Old Jun 25, 2003 | 09:22 AM
-iLLuZioN-B18C1's Avatar
Default Re: Most you would boost without tuning?? (mamaboy)
not to jack the thread or anything:
when breakin in a motor, i heard you need to punch it to a certain rpm every once in a while:
ex.b/w 200-400 miles, dont pass 3500 rpm but zip to 5500 rpm every so often.
well, how does this pertain to me if i just rebuilt and boostin, but didnt tune yet?
(with hondata)
Old Jun 25, 2003 | 09:28 AM
Pengo's Avatar
unless ur running a complete kit, i would try not to boost at all yet untuned, esp with the afc hack. at the least i'd say spend the money to get a wideband standup or find someone who has one so that you can safely tune ur A/F
Old Jun 25, 2003 | 10:08 AM
TurboJesse
Guest
Posts: n/a
Default Re: (Pengo)
i know it istn' prolly the safest thing to do and that every engine is different, but ive seen some people running the hack find someone with a similar setup and use there setttings. A wideband o2 would be nicce though
Old Jun 25, 2003 | 10:19 AM
ion_four's Avatar
Default Re: (Mpir3)
I think you are all pussies and liars if you say you didn't boost before going to the dyno. What, did you build your car on the dyno?
If you are confident in the quality of your injectors and hook-up of afc, I would just run it rich and not COMPLETELY wail on it. Just hook up a voltmeter to your o2 sensor and make sure it stays above 0.900v and that your egt's look normal (don't know what they should be in C, but less than 1400F when boosting, I'd say). You could retard your timing a couple degrees for extra safety and run premium grade fuel. With that, 5-7psi all day.
Old Jun 25, 2003 | 10:41 AM
MachAF's Avatar
Default Re: (ion_four)
someone posted about their friend having the greddy kit on their car with blue box for 50k miles with no problems.
I would stay at 6psi until you can get it tuned
MatthewMenze
Oct 23, 2013 09:06 PM
teddy_dc2
Aug 6, 2006 07:10 AM
bigdgsr
Jul 7, 2006 09:09 AM
justinb
Jun 25, 2005 04:40 PM
Snafu-Si
Jul 12, 2003 10:12 AM
