What is a boost controller?What dose it do?
Old Aug 25, 2004 | 02:48 PM
bodea_florian's Avatar
Default What is a boost controller?What dose it do?
Hy guy's I am new at this and I cheep hearing about this boost controller(from greddy).What is it.How do you use it?
thank's 4 any reply's
Old Aug 25, 2004 | 02:55 PM
madd's Avatar
Default Re: What is a boost controller?What dose it do? (bodea_florian)
it prevents over boost...and i think helps with boost spikes...does some other stuff im sure but i dont quite know off the top of my head...
Old Aug 25, 2004 | 06:01 PM
H2290's Avatar
Default Re: What is a boost controller?What dose it do? (madd)
First questions is do you have turbo? If not don't worry about it. If so then I agree with what madd said.
Go in the Forced Induction forum and just read every post in the first 5 or 6 pages. You will become a turbo GOD!!!
Old Aug 25, 2004 | 06:54 PM
lowboost's Avatar
a boost controller adjusts the amount of boost that gets to the wastegate actuator. it helps keep it closed longer so that the turbo spools faster and can attain a higher peak boost level. say your turbo kit makes 5psi but you want to make 8 without changing the wastegate spring, then you would use a boost controller.
r1lorenzini
Feb 19, 2004 11:54 AM
incognitoracerr
Jan 10, 2003 05:42 PM
1tyme
Nov 27, 2002 05:32 PM
Snafu-Si
Mar 5, 2002 02:07 AM
Cyrio
Dec 4, 2001 07:00 PM
