**skipunk4's mr dc4 2010 refresh - Spoon / Enkei / Innovative / ASC Metal Fab**
Page 1:
- Purchased car - Rotas and Tenabe springs - Trunk stripped - ITR lip - Enkeis' on, Rotas gone - Tokico Illuminas and H&R springs - Mugen knob and dstuning mats - Clock block off, amber clock, Si deck - Milano red side skirts installed - OEM column cover - OEM splash guards - ITR lip painted ( by me ) - Few pics so far - Throw back shot - More pics Page 2: - Factory door speaker - Couple of pics - More pics - And more pics Page 3: - Polished OEM exhaust - Started tearin down for the mild tuck - NEW OEM GSR strut bar w/ hardware - Sleeving and heat shrink picked up - Lots of pics Page 4: - Some crummy rolling shots - Driverside harness finished up - New knob and airbag tray - Driverside harness in - Just about done with the passenger side FINALLY Page 5: - Before and after pics - Bay cleaned up a bit - Car is running again! - Bay all finished and put back together - GS-R Strut bar on - New Parts - ASR subframe - ITR sway bar - Blox adjustable endlinks Page 6: - Rear suspension parts on - Few pics - Moisture leak in headlight Page 7: - "Custom" air duct - LOTS of pics - Throwback shot Page 8: - Random pic - Some SPOOOON - New parts on the way! Page 9: - Roof rack - Lots of pics - Package from JHP :thumbdown: Page 10: - ITR header - DEI heat wrap kit - Spoon filter, socks, crane decal - EMRacing rear strut bar - Parts installed - UPDATES - NRG quick release - BLOX test pipe - Spoon crane decal Page 11: - Bummer - NRG short hub - OEM Snorkel Page 12: - RECARO - RECARO - RECARO - Some sick shots and chops by Eran Page 13: - Night Interior pic (shot by Jason) - BOWLIN with some buddies! (shot by Jason) - NGK plugs/wires - ASC 4130 strut bars :O - More sick shots by jason! - R.I.P spoonef's dc *cry* (car was one of my idols) hence the similarities ;) Page 14: - Tear down #2 a starts - Car stripped - A/C removed - Collecting parts :) - Engine harness out - Brand new OEM car cover - purchased from old skool :thumbup: great seller! - 949 lugs and stems - Old vs new - Stems on Page 15: - Updates - Spoon n1 silencer - Obd2 - 1 jumper harness - Progress on the engine harness - Brake cleanup Page 16: - "L" bracket for relocatin my resevoir - Cleaned up the good ol' B18b - Tucked hood prop cable - OEM plugs/AC ish - Harness progress - Core support painted - FATMAT sound deadening - Harness complete/installed - Bay goin back together - Ground controls :thumbup: Page 17: - Fatmat down - Koyorad radiator - Honda Access mats - New dipstick - EDM fog switch - Exploded Enkei RPF1 :thumbdown: - Wheel teaser Page 18: - REGAMASTERS - BF Goodrich G-forces - Mounted the regas Page 19: - Yellow Raybrigs Page 20: - sick rolling shot by yellobus Page 21: - New OEM I "HEART" MY HONDA window cling - Mariners cap and N W P stickers - Ohlins engine torque damper - Few shots from N W P cruise - Odyssey battery Page 22: - Nothin new :( Page 23: - Ichiba 20 and 15mm wheel spacers - Function7 lca's - ITR checkered mats - Mugen loop and speedo - Spoon n1 and Mugen loop SOLD - Spoon gen 1 street muff - Another bum day for red (timing jumped) Page 24: - Enkei NT03's - ITR intake mani/TB - virgin p28 - B16a3 head - Exedy stage 1 clutch - Competition 11lb flywheel - Spoon ventuli IM gasket - Moroso baffled pan - ARP rod bolts/head studs Page 25: - Motor out - B18C1 - ITR intake arm - ITR "big 4" 4x114 setup - Early style Bride Zetas - Block clean up - OEM s2000 clutch master - Bay stripped Page 26: - Bay sprayed fresh r81 - Rywire clutch line - "illest" decals - More bay! Page 27: - Re-coated wheel wells - OEM harness plug/hole - Custom battery mount - Block all cleand - Mocked up brake lines - MFactory shifter bushings - Clear euro Integra signals - OEM CTR N1 crank pulley - 08 Spoon Sports catalog Page 28: - Painted brake lines - Painted booster - Mocked up rear lines -Installed items in the bay: - Booster/master cylinder - OEM ek harness plug - heater control switch - NEW front brake lines - Block disassembled - PR3 pistons - Front undercoating finished -Coated some parts in semigloss black - Front lower section - Front tow hooks - Front brake lines installed Page 29: - Black Spoon Duracon - B16 dual valve springs - Misc. OEM grommets pluts etc.. - OEM PR3 piston rings - Custom 3' ASC Intake pipe - Canibeat plate frame/lanyard - Front brake lines done! - OEM ITR throttle cable installed - Rywire soft clutch line installed - OEM hood prop hardware installed Page 30: - ACL race bearing kit/thrust washers - ARP head/rod bolts - Engine back from machine - Spoon oil cap - Spoon rad cap - 2x Spoon black rad stays - Polished gsr crank Page 31: - Spoon socks - Supertech valve stem seals - Techflex harness loom and shrink - Longblock mock up - VC stripped - ARP rod bolts and rods off to machine - Head off to assembly - Nylon black hole plugs for bay - Engine assembly supplies - Summit order delivered - Painted fpr - Fuel rail mocked up Page 32: - Front brakes refreshed - Front subframe cleaned and reassembled - Earl's PS loop - Fuel hardline converted to softline - New filter and lines installed - OEM ITR checkered trunk mat Page 33: - Wheel wells stripped - POR15 w/ brushes - SEM trim paint - OEM exhaust mani refreshed - Head partially reassembled - ARP 9mm rod bolts installed - Front/rear wheel wells stripped - OEM ITR arm rest Page 34: - Top/bottom end gasket kit - TB/water pump/tensioner/spring - Thermostat - Oil pump - F7 lca - ASR subframe brace - Honda Access ITR pedal covers - Bum engine rebuild update Page 35: - ASC rear strut bar installed Page 36: - Energy rear trailing bushings - PIC stiffened bushing kit - Innovative billet B street mounts Page 37: - POR15 coated in wells - OEM AC delete duct - Front hubs and rear arms refreshed Page 38: - Rear ITR seat reinstalled - ITR checkered trunk mat installed Page 39: - Short block assembled - LHT master cylinder brace - Rotors resurfaced - Long block preview Page 40: - Head parts cleaned - New head gasket installed - Head w/ valvetrain installed - New oil pump installed - Rear main seal installed - Oil pump/tray installed - Moroso pan installed - New water pump installed - CTR N1 crank pulley and TB tensioner installed - Alternator cleaned and installed - H20 jacket recoated and installed w/ new thermostat - Spoon Ventuli IM plate w/ gasket installed - Cusco E-brake button - Small Spoon collection Page 41: - Bolt Boys B engine bolt kit - Spoon gen 1 DC tow hook Page 42: - cams installed - longblock almost complete - subframe installed - Spoon tow hook installed - Spoon pile Page 43: - Spoon cluster full size Page 44: - Interior pieces powder coated - Nardi Deep Corn 350 - Horn "collection" - New Spoon duracon - Engine harness headache - Spoon crane etched - Bezel complete Page 45: - Complete cluster pic Page 46: - New headlight grounds - New pedal hardware - Energy Suspension rear trail arm bushings - Russell stainless braided brake lines - Pedals installed - Brake rotors installed - Car progress pic Page 47: - New parts from Honda - Throwback shot - Spoon ITR intake with arm - New engine bay hardware - MC brace modified - E-brake button modified Page 48: - New front lower ball joints - USDM ITR seats - JDM ITR Recaro SRD's - Stuff to powder coat - Blox camber kit - New Honda brake pads Page 49: - SSR stainless b series header - Car shot Page 50: - Bushing day - New super low wedge seat rails - Dash installed - Spoon shot Page 51: - Bay shot - Russell brake lines installed - Headlight wiring finished - Engine off the staned - Competition flywheel installed - Exedy clutch installed - New package - Spoon N1 muffler Page 52: - Fuel line work - ASR/F7 combo installed - Beach vaca - Interior wire harness re-taped - Grommet for Spoon cluster - Seats cleaned - Tranny installed - OEM Si deck installed - Seat rails mocked up Page 53: - Seat mount block plates - Spoon cluster installed - Steering wheel mocked up - Stuff back from pwder coat - LHT MC brace installed - Spoon cluster lit up Page 54: - Window cowling cleaned and installed - Front upper arm mounts refreshed - Front camber kit installed - Front LCAs cleaned/installed - Spindles installed - Rear poly RTA bushings ready - Rear RTA bushigns installed - Rotors tossed on - Wheels mocked up Page 55: - ITR calipers installed - Harness work - New front mud flaps - New tires - Bridgestone Potenze re760sport - Engine/tranny cleaned - VC mocked up - Header mocked up Page 56: - Spoon models - Spoon gen 1 mirrors - UKDM ITR signal lights - New tool box/tools - Rays duranuts - JDM valve stem caps - Quick disconnect battery terminals Page 57: - Enkeis cleaned up - Wheels/tires loaded up - Wheels/tires mounted - Koyorad cleaned - Spoon rad stays - Rad mounted up - 1998 Integra service manual - Alt brackets refreshed/installed - Clutch slave refreshed/installed - Half shaft refreshed - Wheel/tire mock up Page 58: - The gf - New axle seals - Half shaft installed - More harness work - CTR cams - Bumper cleaned - New bay hardware - Harness progress Page 59: - JDM ITR injectors - Throwback shot - UKDM signals refreshed - Quick disconnect plug w/ pins Page 60: - OEM OBD2 vtec distributor - More harness progress - Spoon horn button - OEM plug wire cover w/ signed TypeOne decal Page 61: - VC mocked up - Distributor refreshed - ITR injectors polished up - Floating car shot - ICB sticker tossed on - CTR cams polished up - AC block plug project started __________________________________________________ __________________________________________________ ______________________ I picked up this 98, clean titled single owner, milano red Integra about 2 years ago and have just starting to make a lot of progress on it. Any comments and suggestions would be greatly appreciated https://honda-tech.com/forums/images/smilies/emthup.gif So this is what it looked like when I first picked it up: http://a652.ac-images.myspacecdn.com...d246e92ccb.jpg What it looked like for a while after I got it. Removed the spoiler, swapped the logos, dropped it on Tenabe springs w/ Rota GT3s http://a121.ac-images.myspacecdn.com...2d7895b9a8.jpg Stripped out my rear seats, cleaned it up a bit and laid down some sound dampening carpet. Total cost 16 bucks http://a322.ac-images.myspacecdn.com...a646622ce9.jpg Picked up an OEM ITR front lip from a local HT member http://a385.ac-images.myspacecdn.com...c42d735d80.jpg I got really really sick of the Rotas and decided to order some 15" Enkei RPF1s, Tokico Illuminas and some H&R race springs Sold the Rotas for $600 and installed these Notice the height before suspension was on: <img src="http://a10.ac-images.myspacecdn.com/images01/20/l_e518f33e05a75b94c5e92c1ed80183d1.jpg"> And after: http://a235.ac-images.myspacecdn.com...2b606dfd2a.jpg Stuff Installed: -Momo champ wheel w/ Mugen horn button -Momo hub -98 spec JDM ITR cluster -ITR boot and armrest -Mugen 5mt knob (blue) -Amber climate control -New DStuning mats -JHP plate frame http://a526.ac-images.myspacecdn.com...f32f1e9155.jpg http://a845.ac-images.myspacecdn.com...6782abe19c.jpg http://a785.ac-images.myspacecdn.com...3250e6c930.jpg So after a little while I traded a guy straight up for an amber clock then bought an Si deck (which was a pain to install) so the whole dash lights in amber http://a581.ac-images.myspacecdn.com...8ab84637fc.jpg Worth it IMO Love these wheels!! http://a629.ac-images.myspacecdn.com...e03abba4fc.jpg http://a693.ac-images.myspacecdn.com...614a71944c.jpg I don't know why, but I really like this pic ^ http://a185.ac-images.myspacecdn.com...314b378de8.jpg Purchased a new steering column cover to replace my old scratched up one: Old: http://a274.ac-images.myspacecdn.com...725ede6a79.jpg New: http://a218.ac-images.myspacecdn.com...06a81eff81.jpg New: http://a304.ac-images.myspacecdn.com...36b1e7ef57.jpg It was finally a nice day in Oly, so I figured I'd clean the car up and take some pics. http://a89.ac-images.myspacecdn.com/...8cd0189d20.jpg http://a41.ac-images.myspacecdn.com/...be5a598968.jpg Cluttered bay http://a80.ac-images.myspacecdn.com/...d15ebb8037.jpg |
Re: **Milano Red DC4 Project** (skipunk4)
good progress https://honda-tech.com/forums/images/smilies/emthup.gif
Re: **Milano Red DC4 Project** (Locc)
Damnit i want to know how that lip came out http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif
Re: **Milano Red DC4 Project** (9KRevLimitDC2)
car looks really good. Some OEM fogs would make it complete.
what exhaust do you have? |
subscribed! love the progress. i should start one of these for mine.
Re: (Thorgs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Locc »</TD></TR><TR><TD CLASS="quote"> good progress https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9KRevLimitDC2 »</TD></TR><TR><TD CLASS="quote">Damnit i want to know how that lip came out http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif </TD></TR></TABLE> lol I have a lot of pics from that coming very soon https://honda-tech.com/forums/images...es/emsmile.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brice.Hayden »</TD></TR><TR><TD CLASS="quote"> car looks really good. Some OEM fogs would make it complete. what exhaust do you have? </TD></TR></TABLE> I'm not a huge fan of the OEM fogs so I'm probly just gonna leave it with the lip. But its stock as of now https://honda-tech.com/forums/images/smilies/emsad.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thorgs »</TD></TR><TR><TD CLASS="quote"> subscribed! love the progress. i should start one of these for mine. </TD></TR></TABLE> lol DO IT!! So I will be posting up quite a few of new pics tonight... especially of my paint job on the lip. Check back a lil bit later for some updates https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (skipunk4)
Picked up some brand new splash guards up for half price so I couldn't pass that up.
http://a639.ac-images.myspacecdn.com...ba044adf16.jpg http://a940.ac-images.myspacecdn.com...86dc78dec3.jpg http://a194.ac-images.myspacecdn.com...b24fe21e89.jpg So I have decided to just paint the front lip myself because every body shop I went to was gonna charge me from $130 to $150, CRAZY!! Plus it's so close to the ground its gonna just get all chipped up anyways since its my DD. So yesterday I went out and bought some supplies for the job. Heres how the lip sat when I first got it: http://a385.ac-images.myspacecdn.com...c42d735d80.jpg Everything cost me around $25 bucks, so even if it doesn't turn out perfect I'm not out anything https://honda-tech.com/forums/images/smilies/emthup.gif and if it does turn out well then I'm set https://honda-tech.com/forums/images/smilies/emthup.gif So this is what I got: Any helpful comments would be greatly appreciated https://honda-tech.com/forums/images...es/emsmile.gif -3 5 oz cans of Milano Red Duplicolor -1 5 oz can of clear coat (may need one more?) -2 sheets of finer grit wet/dry sandpaper http://a836.ac-images.myspacecdn.com...fb3acac8cb.jpg So once I got home I started wet sanding it, then I dried it off let it off and let it sit for like 10 min so it would fully dry. Then I dry sanded it and this is how it sits now: http://a990.ac-images.myspacecdn.com...d07e96a645.jpg http://a158.ac-images.myspacecdn.com...f765e1b1a5.jpg So today I made A LOT of progress on the lip. Check it out: First coat: Looks pink https://honda-tech.com/forums/images/smilies/emsad.gif http://a395.ac-images.myspacecdn.com...c9c6a2dfb2.jpg Second coat: Starting to look better http://a32.ac-images.myspacecdn.com/...d5f7d89757.jpg Third coat: Coming along http://a852.ac-images.myspacecdn.com...b02a4eab6b.jpg Ran out of paint https://honda-tech.com/forums/images/smilies/emsad.gif so I went and bought some more https://honda-tech.com/forums/images...es/emsmile.gif also got some 1500 grit sand paper for wet sanding. http://a765.ac-images.myspacecdn.com...f0b12c2ad4.jpg Sprayed those 2 cans on and still needed more. So before I left to go buy more I popped the lip on to see how it matched up. http://a793.ac-images.myspacecdn.com...755592c130.jpg http://a718.ac-images.myspacecdn.com...05f61cbd1d.jpg At the end of the night this is what I had: Total of 9 cans of paint, some dirty fine grit sand paper, and some nasty red tack cloth, oh ya and an ITR lip painted to match https://honda-tech.com/forums/images/smilies/emthup.gif http://a851.ac-images.myspacecdn.com...e6e918a052.jpg http://a419.ac-images.myspacecdn.com...83b62a73aa.jpg http://a200.ac-images.myspacecdn.com...f4a255f2ff.jpg Paint is complete, so tomorrow after school I'm going to wet sand, clear coat and polish https://honda-tech.com/forums/images...es/emsmile.gif Total cost around $50 bucks, plus it was a fun learning experience https://honda-tech.com/forums/images...es/emsmile.gif I love doin stuff myself! BUMP if you view https://honda-tech.com/forums/images...es/emsmile.gif Modified by skipunk4 at 1:57 AM 4/29/2008 |
Re: (skipunk4)
Wow that looks so close if not a perfect match to the milano red on the front bumper good work nice attention to detail i cant wait to see what it looks like with a thick clear on it https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (9KRevLimitDC2)
I like it...Nice do something about your engine bay. https://honda-tech.com/forums/images...es/emsmile.gif
Re: (JDMkidGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9KRevLimitDC2 »</TD></TR><TR><TD CLASS="quote">Wow that looks so close if not a perfect match to the milano red on the front bumper good work nice attention to detail i cant wait to see what it looks like with a thick clear on it https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
Ya I think the 9 cans really did the job lol. I was crazy to think 3 cans would work. But I got the clear on today. Check it out! <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMkidGSR »</TD></TR><TR><TD CLASS="quote">I like it...Nice do something about your engine bay. https://honda-tech.com/forums/images...es/emsmile.gif</TD></TR></TABLE> Thanks https://honda-tech.com/forums/images/smilies/emthup.gif and I am dying to get that thing cleaned up. YOU HAVE NO IDEA lol So today I made some progress on the lip today. I ended up using 3 cans of clear, and it turned out pretty good IMO. I also took off the bumper for getting it all mounted up easily. Take a look: The pictures don't do it justice http://a544.ac-images.myspacecdn.com...f85295df9f.jpg http://a325.ac-images.myspacecdn.com...9dbc1918bc.jpg http://a401.ac-images.myspacecdn.com...79fa49a868.jpg http://a110.ac-images.myspacecdn.com...2439c8f20d.jpg http://a104.ac-images.myspacecdn.com...071383473f.jpg http://a233.ac-images.myspacecdn.com...53ca54e6a8.jpg http://a333.ac-images.myspacecdn.com...3fb88ba474.jpg As for tomorrow I will be doing the wet sanding with 2000 grit to get it nice and smooth and buffing it to bring out that shine. BUMP IT! |
Re: (skipunk4)
Re: (zacatkings)
Yea a wet sand will make that biatch pop nice work a very cost effective yet quality job https://honda-tech.com/forums/images/smilies/emthup.gif http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
Re: (9KRevLimitDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zacatkings »</TD></TR><TR><TD CLASS="quote"> love it https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
thanks https://honda-tech.com/forums/images/smilies/emthup.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9KRevLimitDC2 »</TD></TR><TR><TD CLASS="quote">Yea a wet sand will make that biatch pop nice work a very cost effective yet quality job https://honda-tech.com/forums/images/smilies/emthup.gif http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif </TD></TR></TABLE> So I wet sanded it and I think it needs some more clear coat https://honda-tech.com/forums/images/smilies/emsad.gif but we'll see. I'll rock it for a while how it is. PLUS I'm gonna buff the shit out of it tomorrow after class https://honda-tech.com/forums/images/smilies/emthup.gif we'll see how it looks after that. So it went from this: http://a444.ac-images.myspacecdn.com...0a9b436a13.jpg To this: http://a939.ac-images.myspacecdn.com...c2637cddfa.jpg http://a766.ac-images.myspacecdn.com...785477815d.jpg http://a863.ac-images.myspacecdn.com...fc405fcece.jpg I think it needs more clear https://honda-tech.com/forums/images/smilies/emsad.gif we'll see what happens after I buff it more tomorrow. http://a706.ac-images.myspacecdn.com...3e48c94359.jpg http://a506.ac-images.myspacecdn.com...56a6676591.jpg I don't what to do about center caps http://images.honda-tech.com/set1//smile/emcrook.gif http://a136.ac-images.myspacecdn.com...fb020317cf.jpg http://a164.ac-images.myspacecdn.com...899dab684b.jpg WOOP WOOP Modified by skipunk4 at 11:06 PM 5/1/2008 |
that car is looking damn good https://honda-tech.com/forums/images/smilies/emthup.gif
where did u buy the itr lip?
Re: (nightrise420)
nice and clean... https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (Fern413)
ooo good stuff here https://honda-tech.com/forums/images/smilies/embeer.gif
Re: (A's 94 GSR)
It looks vvery nice https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (9KRevLimitDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcnotec1 »</TD></TR><TR><TD CLASS="quote">that car is looking damn good https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
Thanks https://honda-tech.com/forums/images/smilies/emthup.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrise420 »</TD></TR><TR><TD CLASS="quote">where did u buy the itr lip? </TD></TR></TABLE> I got it from a local HT member. He was chill. Damn good price too https://honda-tech.com/forums/images...es/emsmile.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fern413 »</TD></TR><TR><TD CLASS="quote">nice and clean...https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> Just the way I like it https://honda-tech.com/forums/images/smilies/emthup.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A's 94 GSR »</TD></TR><TR><TD CLASS="quote">ooo good stuff here https://honda-tech.com/forums/images/smilies/embeer.gif </TD></TR></TABLE> Yeah buddy https://honda-tech.com/forums/images/smilies/embeer.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9KRevLimitDC2 »</TD></TR><TR><TD CLASS="quote">It looks vvery nice https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> Thanks mang https://honda-tech.com/forums/images/smilies/emthup.gif Sooo I have decided that I love the lip lol. I'm pretty happy with how it turned out. Opinions would be greatly appreciated https://honda-tech.com/forums/images/smilies/emthup.gif Anyways here's a few pics after a good wash and wax https://honda-tech.com/forums/images...es/emsmile.gif http://a843.ac-images.myspacecdn.com...430e3d8932.jpg http://a307.ac-images.myspacecdn.com...0f45f6343a.jpg http://a463.ac-images.myspacecdn.com...5f42403986.jpg http://a397.ac-images.myspacecdn.com...5e3d948da4.jpg http://a249.ac-images.myspacecdn.com...50320c0950.jpg http://a297.ac-images.myspacecdn.com...a8375917c0.jpg Family Hondas https://honda-tech.com/forums/images/smilies/emwink.gif http://a855.ac-images.myspacecdn.com...de6d5a5146.jpg Bumpity Bump |
Re: (skipunk4)
w00t w00t for a local! https://honda-tech.com/forums/images...s/emsmileo.gif
Re: (A's 94 GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A's 94 GSR »</TD></TR><TR><TD CLASS="quote"> https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif</TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Numba1 B Series »</TD></TR><TR><TD CLASS="quote">w00t w00t for a local!https://honda-tech.com/forums/images...s/emsmileo.gif </TD></TR></TABLE> w00t, whens the next local meet? So I'm trying to figure out what kind of exhaust to get. There is soo many choices. I have almost made up my mind, but I just wanted some opinions. Here are my choices: 1. Mugen twin loop 2. Spoon N1 3. T1R Power 63 4. Apexi ws2 "You stay classy San Diego" |
CLEAN DC , NICE BUILD KEEP UP THE GOOD WORK
Re: (crazyc@SRTmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyc@SRTmotorsports »</TD></TR><TR><TD CLASS="quote">CLEAN DC , NICE BUILD KEEP UP THE GOOD WORK</TD></TR></TABLE>
THANKS! I LOVE CAPS LOCK TOO! LOL |
Re: (skipunk4)
what kind of lug nuts and valve stems are those on the enkei's?
