New Welding Thread!
Old Feb 18, 2004 | 12:06 PM
  #1051
dfoxengr's Avatar
Default Re: (Redlineracer)
would the 2" 2.0x ID pipe be too much?
Old Feb 18, 2004 | 12:23 PM
  #1052
EFb18b's Avatar
Default Re: (hybridvteceg)
well according to my pocket ref., schedule 40 1.5in has an OD of 1.9in and 2in schedule 40 has an OD of about 2.375 which means its over 3/8in bigger so I'm pretty sure it won't work and is probably overkill on a hole thats barely 1.5in anyway.
Old Feb 18, 2004 | 02:31 PM
  #1053
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redlineracer &raquo;</TD></TR><TR><TD CLASS="quote">well according to my pocket ref., schedule 40 1.5in has an OD of 1.9in and 2in schedule 40 has an OD of about 2.375 which means its over 3/8in bigger so I'm pretty sure it won't work and is probably overkill on a hole thats barely 1.5in anyway.</TD></TR></TABLE>
really if you go any bigger there is going to be a drop in pressure ,like u said the hole is barely 1.5 and even though the turbo is creating back pressure the pressure differential from the head to the piping going to a 2" primary will be too much and when theres a drop in pressure theier is a cooling of the air wich in a turbo setup you do not want. anyway if you look a big v8 look at the piping diameters in thier setups it only 1 5/8 to 1 7/8
thats just my .02 cents
Old Feb 18, 2004 | 02:34 PM
  #1054
dfoxengr's Avatar
Default Re: (b18cls1)
ok but i said heder. meaning. NA. same im sure though . thanks
Old Feb 18, 2004 | 08:10 PM
  #1055
EFb18b's Avatar
I would stick with 1.5in then because you want the exhaust velocity to be high enough so that when the intake valve opens you don't suck it back into the chamber creating that vortex thingy that I have been reading about in fluid dynamics books.
Old Feb 18, 2004 | 11:43 PM
  #1056
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
ok.. hehe.. i played around at work today. with my big lincon MIG welder.
then, played around with tubular stock.
so then.. some of the guys at work, were asking me what the hell i was doing.. lol, so then we got on the subject somehow of ARC welding.. well... started on that now.. thats fun stuff.. HUUUUGE flashes, and lots of sound.
then, after knocking off all the slag.. not too shabby of a weld.. super ******* strong.. alot stronger than a MIG anyday.
Old Feb 19, 2004 | 01:11 AM
  #1057
hondaboii's Avatar
Default Re: (hulkhb)
Hello,
I have a question, someone said this quote "piping only comes in 1/2" sizes: 1/2", 1", 1.5"...... etc.
Its 1.5" sch 40 found through mcmastercarr"
what do those numbers mean? Sorry, but im new to this piping and welding..I dont have a welding machine, but I would like to start learning about the pipes..
can someone explain to me what 1.5" is on the manifold? is that the diameter of the pipe? how thick are those pipes anyways? what is the "SCH40"?? is that the thickness? oh yeah, I have another question...how thick are usually those turbo manifolds? and also, would a MIG welder be efficient to build a turbo manifold?
thank you in advance for any inputs..
Old Feb 19, 2004 | 07:09 AM
  #1058
sporkcrx's Avatar
Default Re: (Built B16A)
God damn Chris that first weld is beautiful. I swear I give up on welding, lol. Looks like you guys are productive there
Old Feb 19, 2004 | 10:21 AM
  #1059
Built B16A's Avatar
Default Re: (sporkcrx)
hey.. some of our best work comes when we're playing around.. beats doin actual work.. hahaha!
but yeah, im pretty slick with the mig, but if you need to weld up .5" or more.. arc is your method. penetrating as hell, but you always have to make 3 passes or more.
Old Feb 19, 2004 | 10:24 AM
  #1060
Built B16A's Avatar
Default Re: (hondaboii)
mig would be fine to build a manifold.
however the shc. # found on pipes, maybe some vetran welders here can explain better than i can.. i heard its 1 of 2 things.. 1 it being actuall tube wall, 16-18 ga. ect. 2 being the volume it can hold.. its PSI. might only be true in PVC, but i dunno.. somoene in this thread knows.
Old Feb 19, 2004 | 10:27 AM
  #1061
hybridzOr's Avatar
dont be hatin....
&lt;n00b at welding....started with oxyacetelyne welding....
i'll try to get some pics of my work tommorow bwahahaha
Old Feb 19, 2004 | 10:35 AM
  #1062
sporkcrx's Avatar
Default Re: (Hybrid Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Racer &raquo;</TD></TR><TR><TD CLASS="quote">started with oxyacetelyne welding....
me too, that's the best welding I can do. I suck at MIG But with the good ol' torch I have much more control than the stupid gun.
Old Feb 19, 2004 | 10:38 AM
  #1063
hybridzOr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">
me too, that's the best welding I can do. I suck at MIG But with the good ol' torch I have much more control than the stupid gun.</TD></TR></TABLE>
&lt;been working at puddles real hard...lol
might start doing some filler rod tommorow.....
Old Feb 19, 2004 | 11:59 AM
  #1064
skierGT's Avatar
thought i would make my contribution
these are some of my first oxy acetylene welds
heres the penetration of the last one
Old Feb 19, 2004 | 12:07 PM
  #1065
skierGT's Avatar
Default Re: (skierGT)
heres a pic of my first TIG welds (kinda crappy havent gotten the hang of it yet but hey it was my first time ever trying) there on steel by the way.
Old Feb 19, 2004 | 05:00 PM
  #1066
lazerus's Avatar
Tig welded isuzu manifold.. Trying to improve my skill with an olld miller Mig/Tig/Stick. I dont have that really nifty pulsing feature which the new tigs have, so i've improvised by trying to master the skill by "pulsing" with the amperage pedal manually.. i think it really increases the weld penetration, quality.. and has a lower heat input to boot!
Old Feb 19, 2004 | 10:32 PM
  #1067
Built B16A's Avatar
Default Re: (lazerus)
damnit.. i wish i had a TIG machine..
oh well, i'll put up some of my mig welds up against some of these TIG's ive seen... heh
Old Feb 19, 2004 | 11:29 PM
  #1068
hondaboii's Avatar
Thank you for replying..much appriciated.
So its ok to use MIG to build a custom made turbo manifold. Thats good to know
How thick are those manifolds usually (in gauge measurement? 12ga?, 14ga?) and how big are those pipes suppose to be (in diameter 1.5", 2.0" or 3"?) Are pipes measured by the inside diameter or outside? ALso, how thick are the flanges suppose to be? (how many inches?).
Thank you in advance for anyone who can answer my questions...have a good day!
Old Feb 19, 2004 | 11:34 PM
  #1069
lazerus's Avatar
i always use 1/2 inch flanges, and i use 8 gauge piping, wether it be standard cold rolled, or 304L stainless...
Old Feb 20, 2004 | 12:02 AM
  #1070
DownBoyDown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">i always use 1/2 inch flanges, and i use 8 gauge piping, wether it be standard cold rolled, or 304L stainless...</TD></TR></TABLE>
What diameter piping would be used for a b-series manifold?
Old Feb 20, 2004 | 12:11 AM
  #1071
hondaboii's Avatar
thanks for the reply...
umm..what does "standard cold rolled" mean or "304L stainless"?? all I know is stainless steel metal or low carbon metal...even those, im not so sure! haha
but thank you again for helping...1/2" thick is good? alright...I heard people use 3/8" thick, will those be efficient enough?
Thank you again...
Old Feb 20, 2004 | 12:58 AM
  #1072
lazerus's Avatar
i preffer 1/2 inch to 3/8 because it tends to warp less, but many people use 3/8s without problem, its just my preference based on experience. (that and i hate sanding down flanges)
Almost any 4 cylinder honda is easiest to use standard 1 1/2 inch OD pipes and slightly oblong them at the header flange to fit...
you can obtain most anything you need pipe wise from http://www.mcmastercarr.com...
if there is one peice of advice for welding anything.. make sure the peices being welded are CLEAN and free of mill scale.. Standard practice for me now is to have every peice i welded sandblasted, and constantly clean using a wire brush before welds to ensure that there will be no foreign material in the weld..
Always keep a peice of scrap metal to set your machine properly, and use a rythm while you weld, it makes it more uniform!
While on this topic.. Lets talk about aluminum welding, i've been practicing lately and trying to figure out the most consistent and penetrating welds.. Try and describe your techinques!
Brad
Old Feb 20, 2004 | 02:16 AM
  #1073
hondaboii's Avatar
Hi Brad,
Thank you for taking the time to reply and answer my questions. I am now learning more about what type to use and such. I never knew that there are soo many differnt metal to use for manifolds. Any specific type of metal for the pipe of the manifolds? How about the flange? what type of metals are good too? Something that is good quality but not very expensive in pricing? I checked that site that you refered, and I kinda got lost! haha, soo much things..didnt know where to start. Do you usually make your own flange? if so how do you usually start? would there be like a site that would show somehow how to make a manifold? Im just planning on starting to make a LOG style for now..just as a beginner one, would it be hard to make one?
Thank you again for your help...much appriciated!
Edit: I checked at the site you refered and ebay and found these...
2x 304L Stainless Steel Butt-Weld Pipe Fitting 1-1/2" Pipe Size, Tee, Schedule 10 (p/n 45735K255)
2x 304L Stainless Steel Butt-Weld Pipe Fitting 1-1/2" Pipe Size, 90 Deg Elbow, Schedule 10 (p/n 45735K215)
1x http://cgi.ebay.com/ebaymotors...78521 (block flange)
1x http://cgi.ebay.com/ebaymotors...76968 (turbo flange)
1x http://cgi.ebay.com/ebaymotors...33742 (for the wastegate flange)
I was wondering if these materials would be good to create a turbo manifold? If so, would there be anything else (materials) required to make this?
Thank you again...
Modified by hondaboii at 3:30 AM 2/20/2004
Modified by hondaboii at 3:43 AM 2/20/2004
Old Feb 20, 2004 | 02:46 AM
  #1074
mckenzie's Avatar
i like this thread, getting interested in welding and i stumbled upon this. keep up the good work. hopefully i can show my work one day.
Old Feb 20, 2004 | 07:27 AM
  #1075
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboii &raquo;</TD></TR><TR><TD CLASS="quote">2x 304L Stainless Steel Butt-Weld Pipe Fitting 1-1/2" Pipe Size, Tee, Schedule 10 (p/n 45735K255)
Thank you again...
Modified by hondaboii at 3:43 AM 2/20/2004</TD></TR></TABLE>
you need to be usning schedule 40. 10 is too thin
