AWD EJ2 Build
Old Feb 4, 2012 | 04:25 PM
  #701
purpej2's Avatar
Default Re: AWD EJ2 Build
i love what you did with the arches, did you by the over fenders or make them? they give the car a much better look. do you work for a motorsport company?
Old Feb 5, 2012 | 03:01 AM
  #702
purplecivicturbo's Avatar
Thanks mate. I bought the over fenders, need to modify them to ft the car perfectly.. Then cut away some of the original arch so the tyre will clear..
Nah i dont work for motorsport, wish i did- this is just for fun. i have started making electronics for people...
Old Feb 5, 2012 | 08:38 AM
  #703
MrDomino's Avatar
Originally Posted by purplecivicturbo
I know.. Most parts are compatible with EG6, some are compatible with the 4dr.. Certain things can be a pain in the ****..
Small update for tonight, The lower dash panels have arrived, so ive been assembling them all..
Please excuse the rough edges on the steel support structure, it still needs alot of work to fit and get it just right...
Had to use the laptop to backlight it lol.. Also the lower AWD dial text wont be lit as the pots are too big. Ill have to hunt for some compact ones..
That's really awesome. I'm not going to steal your design but I have a few questions since I'm already working on something similar for my Spec E30 car.
How did you get such a nice square for the LCD screen? I've been trying to figure out a way to cut a similar hole for a 20x4 LCD in sheet metal but so far I think the best way I've come up with is chiseling out a hole. It looks like you might have used a different material.
As for the cool labeling that you did- how exactly did you do that? I'm probably going to end up using my label maker and sheet metal to achieve something similar but I'm curious as to how you got such a nice effect.
Where do you buy your toggle switches from? I've been struggling to find a place that doesn't charge $4-6 for a stupid toggle switch that I'm sure costs $0.10 to make.
Old Feb 5, 2012 | 08:49 AM
  #704
MrDomino's Avatar
Also, a few more questions- these are electronics based.
Those shifter LEDs. Where did you find such a nice case for them? I'm going to be using an Arduino UNO to illuminate LEDs but so far all my work has been on breadboards. It'd be nice to have an enclosure that I can actually use in my car.
How does the anti lag work? How did you get it to interface with Hondata?
Old Feb 5, 2012 | 10:09 AM
  #705
The panel is actually a painted sheet of clear acrylic that has been laser etched by a mate. The laser can also be used to cut- hence the straight edges.. It was all CAD modelled..
The switches are from an electronics wholesaler ovr here called rapid electronics.. They also supply the project boxes..
I built the anti lag to piggyback the ECU
Old Feb 5, 2012 | 12:07 PM
  #706
MrDomino's Avatar
I found some project boxes from a supplier over here and already ordered some. Thanks. Are the LEDs just wired into a breadboard inside the box?
As for the anti-lag- You're just intercepting and modifying signals to the ECU, right? How did you wire it so that the signal is unaffected during normal operation while still allowing you to change the signal during anti-lag? I'm going to be doing something similar with an Arduino Uno and I'm not sure how fast it'll be so I want to pass the signal through unaffected during normal operation and then intercept it during full throttle starts.
I guess I forgot to add that your build is awesome. I'm doing a lot of similar things but nowhere near as complex or refined. I can't wait to see the end result.
Old Feb 5, 2012 | 05:11 PM
  #707
purpej2's Avatar
i may have to buy some electronics off you, or anything else you sell for the ej2
im thinking about getting into the motorsport side but not sure which way to go about it, i might pop to glyndwr university and see if they have any courses there to help.
Old Feb 5, 2012 | 08:54 PM
  #708
Naterror's Avatar
Chris I just noticed the camera above your cooling fan control board. Where is that video feed going? Never mind, I see it's actually your laptop's camera.
Old Feb 5, 2012 | 09:48 PM
  #709
DirtyDA9's Avatar
You are by far the most innovative person to grace this forum! Hats off to you man, big time. The stuff you do and design is simply mind blowing! Truely an artist! The time and effort you put in to this thing is freakin amazing, and it will pay off. Definately the most unique and innovative stuff I have ever seen. You should definately be an engineer or working for major shops/companies
Old Feb 6, 2012 | 04:54 AM
  #710
Thanks alot for that, im pretty sure there are others on this forum too.. I have really enjoyed reading plenty of builds on here!
I would love to work in motorsport, especially development. Williams F1 offered me a job following an interview but for various reasons i had to turn it down..
Mr Domino: ill drop you a PM later on.. I dont really want to broadcast how ive done certain things..
Old Feb 6, 2012 | 08:01 AM
  #711
DirtyDA9's Avatar
WHAT! YOU TURNED IT DOWN!? But like you said, I'm sure you had your reasons. But man that would have been awesome for you. I think you would be a great asset to any team/company.
Old Feb 6, 2012 | 10:07 AM
  #712
I would love to do it mate.. Unfortunately its hard to sa on a CV lol
Old Feb 6, 2012 | 02:09 PM
  #713
MrDomino's Avatar
Understandable. Whenever you get a chance drop me a line. I'll let you in on what I'm working on too since I'm keeping it under wraps until I get it working or at least to a stage where it isn't just some notes on pieces of paper.
Old Feb 7, 2012 | 03:14 PM
  #714
purpej2's Avatar
im going to have to start attempting to make mine ?unique?
thing is im hopeless with electics could i give one of you two a shout if i need help with somethin?
Old Feb 7, 2012 | 06:09 PM
  #715
MrDomino's Avatar
Post on here so everyone can see. I'm sure we or someone else will be able to help.
Old Feb 8, 2012 | 07:17 AM
  #716
nikko040103's Avatar
Great build! Esp the electrical stuff! :D
Old Feb 8, 2012 | 10:21 AM
  #717
No worries mate, as said, if you post it on here if I cant help there are plenty of people on here who can help..
Thanks alot mate!
Old Feb 8, 2012 | 01:12 PM
  #718
purpej2's Avatar
Cheers, i'm going to start doing stuff within the next few weeks.
Hows the build going?
I know weather has been pretty crap here, had to do my cousins alternator and i could not feel my hands, freezing.
Old Feb 9, 2012 | 11:21 PM
  #719
Good stuff mate- youll have to start yourself a build thread!
The build is going slowly at the moment.. Scrimping everything to pay for the respray but as you know things are tight at the moment..
It was -2C in the garage the other day when i was working on a loom for someone. I ended up dog sick until yesterday.. Going to have to be more careful in future lol
I know what you mean, cold metal is very unforgiving..
Old Feb 10, 2012 | 11:55 AM
  #720
DDR_SI-PETE's Avatar
Keep up the nice work
Old Feb 12, 2012 | 11:20 PM
  #721
Thanks alot mate!
Old Feb 15, 2012 | 10:23 AM
  #722
Started doing the drive bv wire computer, this does the power supplv for the servo, the power steering speed control.
The screen is to adjust the various throttle position settings, idle and anti lag speeds..
Old Feb 15, 2012 | 01:42 PM
  #723
codenamezero's Avatar
Why don't you build the next supercar instead? lol
Old Feb 15, 2012 | 02:28 PM
  #724
Lol id love to but building a 95 civic is proving to be pricey lol
I would have loved to work on the bugatti 16.4 development- a beautiful machine...
Old Feb 16, 2012 | 12:15 PM
  #725
purpej2's Avatar
all seems to be going well mate
