no spark
Old May 7, 2004 | 12:00 PM
dyases's Avatar
Default no spark
I have a stock d16z6 that isn't producing a spark. I took it to a trusted mechanic and he checked cap, rotor, etc and said the problem isn't there, it's somewhere else. I asked him if I could just swap out ECU's and he said that honda's have very low chance of ECU failure and that it would be a waste of time/money. Does anyone else know what could be wrong?
Old May 7, 2004 | 01:02 PM
dyases's Avatar
Default Re: no spark (dyases)
bump
Old May 7, 2004 | 01:07 PM
frankgrimes's Avatar
iam not the best trouble shooter ....but i'll try and help you out.
check your ground wires on your thermostat housing and tranny, clean off any rust and make sure there good and tight. but i would check your main relay...before swapping out your ecu
http://techauto.tripod.com/mainrelay.htm
https://honda-tech.com/zerothread?id=787638
hope this helps...
clive
Old May 7, 2004 | 01:12 PM
Jimmy's Avatar
Global Moderator
I'm thinking it's your Ignitor or your ignition coil.
Heres a few threads that i found by SEARCHING that i think will help you.
I'm almost %99.9 percent its a distributor problem, so swap dizzys with a friend to see if your problem is fixed.
Also search before creating topics PLEASE
https://honda-tech.com/zerothread?id=835119
https://honda-tech.com/zerothread?id=815195
https://honda-tech.com/zerothread?id=796269
https://honda-tech.com/zerothread?id=782375
https://honda-tech.com/zerothread?id=779162
https://honda-tech.com/zerothread?id=772911
https://honda-tech.com/zerothread?id=756955
https://honda-tech.com/zerothread?id=752079
https://honda-tech.com/zerothread?id=735400
https://honda-tech.com/zerothread?id=728025
https://honda-tech.com/zerothread?id=716702
https://honda-tech.com/zerothread?id=670239
https://honda-tech.com/zerothread?id=631032
Old May 7, 2004 | 01:14 PM
Jimmy's Avatar
Global Moderator
Also if its your main relay (if your fuel pump isnt priming)
http://www.markl.f9.co.uk/howt...y.htm
http://autorepair.about.com/cs...1.htm
Old May 7, 2004 | 01:19 PM
dyases's Avatar
Default Re: (Usdmdc2)
Fuel pump primes, mechanic told me its not a problem with the distributor.
Old May 7, 2004 | 01:21 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dyases &raquo;</TD></TR><TR><TD CLASS="quote">I have a stock d16z6 that isn't producing a spark. I took it to a trusted mechanic and he checked cap, rotor, etc and said the problem isn't there, it's somewhere else. I asked him if I could just swap out ECU's and he said that honda's have very low chance of ECU failure and that it would be a waste of time/money. Does anyone else know what could be wrong?</TD></TR></TABLE>
Your mechanic is full of ****.
He checked the cap,rotor,and button not the coil or ignitor judging by what you say.
Also what about the part where he says hondas have a very little chance of ECU failure....I see ecu problem<FONT COLOR="red">S</FONT> ALL the damn time.
Find a new mechanic.
<FONT SIZE="5">Plain & Simple.</FONT>
Old May 7, 2004 | 01:28 PM
EG6 SiR's Avatar
Default Re: no spark (Usdmdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Usdmdc2 &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking it's your Ignitor or your ignition coil.
em1gbray123
Aug 2, 2010 10:13 AM
94.Si.Lude
Mar 20, 2009 09:39 PM
hachement
Jan 18, 2004 10:15 PM
2k1_ITR_0736
17
Jan 26, 2003 04:09 PM
crxzc
Jun 9, 2002 06:50 PM
