need help with wiring for b16a
im getting power at the dizzy and i got spark at the coil but im not getting any spark at the spark plug wires or spark plugs. i checked the sending unit/dist cap/rotor and its all got clean connections. thx
Re: need help with wiring for b16a (c jackson)
i checked all the grounds cleaned them and beeped them out on the ecu to make sure they were pinned out correct and i still get no spark.
Re: (Sammex)
alright i rewired my entire ecu pin to pin and still no spark is there any one out there that can give me a wire schematic of the hf and the si-r
Modified by hachement at 1:28 AM 1/12/2004
as hachement said, checked grounds. But, the car has been started and will idle... Only problem is when shooting the timing, the timing marks jump back and forth on its own... We check cam gears and they are aligned perfectly... belt not loose... Any ideas?
Also, would TDC sensor not working cause this problem?
Thanks
Thanks
