16x7 5zigen offset Pictures +42 or +33.......which on for my EG
Old Mar 5, 2004 | 06:45 AM
yusoslo's Avatar
Default 16x7 5zigen offset Pictures +42 or +33.......which on for my EG
My car is lowered ~3.5 inches up front and 3 in the rear.
I will be running 205-45-16's
I do not want the tires to stick out too far or be in too far as well.
THe rims come in +33 and +42 offsets
I am thinking the 42's are what I want, but does anyone have pics of this rim/offset
Old Mar 5, 2004 | 07:37 AM
silverEH2's Avatar
Default Re: 16x7 5zigen offset Pictures +42 or +33.......which on for my EG (yusoslo)
those wheels are super clean
Old Mar 5, 2004 | 07:47 AM
Phantastic's Avatar
nice wheels
yusoslo's Avatar
Default Re: 16x7 5zigen offset Pictures +42 or +33.......which on for my EG (silverEH2)
I know I love em, just wanna get the right offset for my drop
I am tucking 175-70-13 tires if that makes a difference
I guess that would mean on a 16x7 i will tuck all the tire and 1 in of rim.
anyways
Bump for tech and pics
Old Mar 5, 2004 | 08:18 AM
nerdsports's Avatar
correct if i'm wrong but going with +33 offset, the wheel is gonna be flush with the fenders and in turn you'll rub, whereas the +45 offset will tuck inside the fenders...
figured this out by looking at many GAB wheels with +35 offset [or similar] and the wheels sitting flush if not almost sticking out....
Old Mar 5, 2004 | 08:36 AM
yusoslo's Avatar
Default Re: 16x7 5zigen offset Pictures +42 or +33.......which on for my EG (nerdsports)
well would a 42 stick in too much and look weird?
Old Mar 6, 2004 | 08:27 AM
yusoslo's Avatar
bump
Old Mar 6, 2004 | 09:11 AM
BUKKAKE-ADAM's Avatar
an +33 offset is to much, the most offset you can run on an eg is +35 like my old te-37s...and i had rubbing problems with those also
Old Mar 10, 2004 | 12:53 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: (enkei rpf1)
so the larger the offset # means the wheels won't stick out as much???
Old Mar 10, 2004 | 07:56 AM
StevenTran305's Avatar
Default Re: (92 civic VX B18c)
Yep
Old Mar 10, 2004 | 08:33 AM
teal_dx's Avatar
i have different rims but they are 16x7 w/ 40mm offset. heres some pics to give you an idea what the 42mm would look like (just add 2mm
i barely rubbed w/ that setup, and it was always w/ the outer edge of the tire rubbing fender lip. so 42mm might be perfect
(that 1st image is imagestation so it may not work)
edit: i also used 205/45/16
Old Mar 10, 2004 | 09:38 AM
accurate's Avatar
those are some nice wheels
Old Mar 10, 2004 | 12:52 PM
teal_dx's Avatar
just noticed something else.... you are prob gonna rub w/ that drop unless there are really nice roads where you live. my drop was about 2 5/8" and I rubbed some. if you have coilovers though you can always adjust after you get the wheels on, if you have springs id go w/ a 205/40/16 series tire which will give you the factory outside diameter on your tire. ride will be a little more harsh and less sidewall to absorb potholes compared to 205/45. but rubbing sucks!
Old Mar 11, 2004 | 09:45 AM
yusoslo's Avatar
Default Re: 16x7 5zigen offset Pictures +42 or +33.......which on for my EG (teal_dx)
it does look like a +42 will be perfect then.
thisguyhere
Honda Civic (2001 - 2005)
16
Jun 11, 2009 08:15 AM
simpleEdwin
Dec 29, 2004 09:23 PM
Ya@inlinePRO
10
Feb 24, 2004 02:20 PM
EP3-R
Jun 25, 2003 01:58 PM
bhcvc
May 24, 2002 01:16 AM
