wheels with +35 offset on EG
Re: (simpleEdwin)
for 16x7 you want to run 40~42 offset. Its only 5mm difference so they probably would still look ok but you may have rubbing issues and you will definitely have issues if your sporting 215 or wider tires.
Re: wheels with +35 offset on EG (simpleEdwin)
if you are using a 16x7 rim with a 205/45/16 tire and you are lowered 1-2" you will have rubbing issues at full lock or turning into a driveway (turning wheels slightly half turn) as you go up the bank.
stick with +45 if you can. and you'll be fine.
yusoslo
13
03-11-2004 09:45 AM
EP3-R
06-25-2003 01:58 PM
MikeD
07-24-2001 09:05 AM
